How to rotate a string ?
wedilo
PostPosted: Mon Nov 24, 2003 8:27 am     Reply with quote
Hello to all,
I would like to monitor the status of a button via RS232. The character for high (button pressed) should be '-' and for low '_'. So that I can see on the terminal for example: ___-_-_-_-____
But I see : nnnnpnpnpnpnpnnnnn
Please have a look to the code:
#include <18f452.h>
#use delay (clock=20000000)
#use RS232(baud=19200, xmit=PIN_C6, rcv=PIN_C7)
long lStartUp = 3017;
struct {
   short int Button_1; // RC0
   short int Button_2; // RC1
   short int Button_3; // RC2
   short int Button_4; // RC3
   short int unused : 4; // RC4-7
} port_c;
#byte port_c = 0xF82
char sButton_1[31] = "______________________________";
char sLow[2] = "_";
char sHigh[2] = "-";
#int_timer1
timer1_isr() {
   int ni;
   setup_timer_1(T1_DISABLED);
   set_timer1 (lStartUp);
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
   for (ni=0;ni<=29;ni++) {
      sButton_1[ni] = sButton_1[ni+1];
   if (port_c.Button_1 == 0) {
         sButton_1[30] = sHigh;
   else {
         sButton_1[30] = sLow;
void main()   {
   set_timer1(lStartUp);
   putc(12);
   For (;;) {
      printf("Status of button 1: %s", sButton_1);
I think the mistake is in the isr where I rotate the characters.
I heard lots about pointers but can't use them. Embarassed
Is there an easier way for that problem?
Thank you very much for any help
73 Sven
KerryW
PostPosted: Mon Nov 24, 2003 9:05 am     Reply with quote
When you define this:
char sLow[2] = "_";
And use this:
buff[10]=sLow;
you are using the address of sLow, not its value.
Change the definition to:
char sLow = '_';
char sHigh = '-';
And use this:
buff[10]=sLow;
or use
char sLow[2] = "_";
sLow[0] when you want a '_' character and sHigh[0] when you want a '-' character.
The first one (char sLow = '_'; ) will use less memory.
wedilo
PostPosted: Tue Nov 25, 2003 2:56 am     Reply with quote
Hello KerryW,
I can't understand why, but it works. Very Happy
Thank you very much
73 Sven
KerryW
Understanding pointers and arrays is crucial.
PostPosted: Tue Nov 25, 2003 2:00 pm     Reply with quote
If you don't understand them, these problems will occur again and again.
Here is a thumbnail sketch of how it works.
char a; // location=0, 1 byte
int b; // location=1, 2 bytes
float c; //location 3, 4 bytes.
char *pa; // location 7, 1 byte
int *pb; // location 8, 1 byte
float *pc; // location 9, 1 byte
char x[2]; // location 10, 2 bytes
int y[2]; // location 12, 4 bytes
float z[2]; // location 16, 8 bytes
a=100; // location 0 contains 100
b=101; // location 1 contains 0, location 2 contains 101
y[0]=0x123; // location 12 contains 0x23, location 13 contains 0x01
pa=&a; // ‘&a’ mean ‘address of a’, or 0. Location 7 contains 0
pb=&y[0]; // location 8 contains 12
pb=y; // a synonym for ‘pb=&y[0]’, location 8 still contains 12.
*pb=102; // ‘*pb’ means ‘the location whose address is in location 8’. Location 8 contains 12, so it puts 0 in 12 and 102 in 13, because the compiler knows that pb points to a 2 byte integer.
pb++; // Location 8 was 12, but since it points to a 2 byte number, the compiler adds 2 instead of 1, so location 8 now contains 14.
If this doesn't do it for you, let me know. It's hard to explain in just a few lines.
wedilo
PostPosted: Thu Nov 27, 2003 2:18 am     Reply with quote
Hello KerryW,
I was surprised about so much information. I will work through your message and will going to understand it completely.
It's hard stuff, but your are right: "it will occur ever and ever"
Thank you very much for your response Very Happy
73 Sven
Mark
PostPosted: Thu Nov 27, 2003 9:24 am     Reply with quote
KerryW,
CCS is a little different that most compilers:
int b in CCS is 1 byte
long c is 2 bytes
int32 is 4 bytes
Mark
KerryW
My compiler is old.
PostPosted: Thu Nov 27, 2003 10:24 am     Reply with quote
I'm using something like 2.7?
I don't even have int32, although I knew that the newer ones had it. I wasn't sure how they had implemented if, if they had made int a 16 bit and long a 32, or what. I'm also not sure in they use high byte/low byte or low byte/high byte format. (I knew at one time, but I never remeber such things. If it becomes important, I just take a peek and see)
So many things to forget, and so little time. Wink
