| View previous topic :: View next topic   |
			Chen Guest
				| Programmable auto-reload Timer output? |
				 Posted: Thu Feb 06, 2003 12:38 pm     |
				I am using PIC18F8620, and I need a varible clock to pace my operation.
Is there a programmable auto-reload timer output? (up to MHz range)
___________________________
	Original Post ID: 11365 |
			Neutone
				| Re: Programmable auto-reload Timer output? |
				 Posted: Thu Feb 06, 2003 12:52 pm     |
				:=I am using PIC18F8620, and I need a varible clock to pace my operation.
:=Is there a programmable auto-reload timer output? (up to MHz range)
If I get your question right.
Concider doing this from main;
Use the internal 16 bit timer
while(true)
{  if(timer overflow interupt flag is set)
   {  Set_timer(variable time)
      Clear timer interupt flag
      Perform what oprtations you must
This does not require using an interupt. It only checks the interupt flag. You basicly gate your operatios to a time interval that is variable with the value you load into the timer.
	Original Post ID: 11366 |
			Chen Guest
				 Posted: Thu Feb 06, 2003 1:18 pm     |
				Thanks for your suggestion, but
I prefer no PIC is involved at all after the clock started
Also, your approach seems to change the clock a little depending on when the Set_timer(variable time)is called.
:=If I get your question right.
:=Concider doing this from main;
:=Use the internal 16 bit timer
:=while(true)
:={  if(timer overflow interupt flag is set)
:=   {  Set_timer(variable time)
:=      Clear timer interupt flag
:=      Perform what oprtations you must
:=This does not require using an interupt. It only checks the interupt flag. You basicly gate your operatios to a time interval that is variable with the value you load into the timer.
	Original Post ID: 11368 |
			Sherpa Doug Guest
				 Posted: Thu Feb 06, 2003 1:40 pm     |
				:=:=I am using PIC18F8620, and I need a varible clock to pace my operation.
:=:=Is there a programmable auto-reload timer output? (up to MHz range)
:=while(true)
How about subtracting a fixed value from the timer instead of setting it.  Then it can count a few ticks before you poll the flag with no accumulated error.
The only stand-alone chips that I know of that do this are dedicated synthisizer chips which generally work at many MHz and draw lots of power.  Look at an AD9853 for example.  I briefly looked at it for a project untill I saw it takes 500mA supply current!!!
	Original Post ID: 11370 |
			Richard Slater
  Joined: 08 Sep 2003 Posts: 12 Location: Cambridge, UK
				 Posted: Mon Feb 10, 2003 2:07 am     |
Maybe a programmable frequency synthesiser from Cypress is what your looking for?  Look under 'Programmable Clocks' on their website.  I am currently including their CY22150 in a project, available for a few dollars from Digikey.
Good luck
Richard
Richard
	Original Post ID: 11467 |
