Function used but not defined
Goto page Previous  1, 2
PostPosted: Wed Feb 09, 2022 2:47 pm     Reply with quote
hmmmm.....
void set_tris_b(int8 value)
int x;
I bet 'set_tris_b()' is a reserved word and YOU can't make up a function with the same name ???
I don't know C but BASIC has 'reserved' words that you can't use.
The C experts here will know for sure. Now I'm curious is the manual has an appendix with a list of reserved words ? If not, it should !!
PostPosted: Thu Feb 10, 2022 2:15 am     Reply with quote
You do have a path even in Linux, and they do have a library for the
actual code here.
It is $PATH in Linux.
TTM
PostPosted: Thu Feb 10, 2022 4:40 am     Reply with quote
Well, not a reserved keyword (as if, then, etc ..) but a "built in function".
If it compiles (and links properly), it clearly shows that the function is not present in the function library provided by CCS (well, this is what I think)
TTM
PostPosted: Thu Feb 10, 2022 4:44 am     Reply with quote
actual code here.
Yeah of course :-)
What I meant is that the path doesn't need to be specifically setup in order to hold the compiler directory in that case, because I' running the program from the installation location
And this location contains both the executable (ccsc) AND the lib (pcm.so)
PostPosted: Thu Feb 10, 2022 4:58 am     Reply with quote
Does the application itself have the permissions needed to write to the
compiler directory?.
It normally doesn't.
It has been ages since I played with the Linux version, but historically
you could _not_ run it inside it's own directory. You had to have your own
working directory, with write permissions, put the sources there, and then
call the compiler from here.
TTM
PostPosted: Thu Feb 10, 2022 6:22 am     Reply with quote
Yes it does have the rights.
Again, compilation process works fine for any other source code files not having these specifics built in function
PostPosted: Thu Feb 10, 2022 6:24 am     Reply with quote
I hate these new computers and OSessss....
It's MY machine, I should have 100% TOTAL permission to do what I want ,'24/7' !
There's too many 'layers' and 'others' stopping me ..grrrr.... Laughing
Let's go back to the good old dayze !! Teletypes, 7 bit ASCII, 20ma current loops, ASSEMBLER...
PostPosted: Thu Feb 10, 2022 8:16 am     Reply with quote
I'm the opposite. I started with IBM, working on their first Unix port. Their
own systems had good security and Unix was the same. It has always given
me the screaming abdabs' how users on PC's can interfere with parts
of the actual OS....
Page 2 of 2
