IK1WVQ Guest
#org default |
Posted: Fri May 16, 2003 5:02 am |
hi,
my application (18F252) use a "loader" for remote (gsm) program upload..
the program code are trasmitted and stored in a external EEPROM,
and then the program call my loader() function what copy from
external eeprom to internal flash (with exclusion, off course, of
loader code) and restart the processor..
This is my loader function:
#org 0x7d80,0x7fff AUTO=0 DEFAULT
void loader(void)
#use i2c(master,fast,sda=pin_c4, scl=pin_c3, restart_wdt)
int16 indirizzo;
int8 n;
restart_wdt();
disable_interrupts(global);
disable_interrupts(int_rda);
disable_interrupts(int_rtcc);
disable_interrupts(int_timer1);
disable_interrupts(int_ext);
restart_wdt();
i2c_start();
i2c_write(0b10101110);
i2c_write(0x00);
i2c_write(0x40);
i2c_start();
i2c_write(0b10101111);
for (indirizzo=0x0200;indirizzo<0x7d80;indirizzo=indirizzo+64)
for(n=0;n<64;n++){restart_wdt();g_stg[n]=i2c_read();}
WRITE_PROGRAM_MEMORY((int32)indirizzo, g_stg, 64);
n = i2c_read(0);
i2c_stop();
reset_cpu();
#org default
The program run very good...
What is the problem ???
the "entry point" of the loader is not 0x7d80 (the start of the reserved space), but
another:
.................... loader();
2C7A: CALL 7E4C
due to the fact that this function STAY UNCHANGED FOREVER, if a future change in
compiler philosophy will move this "entry point", the future call to loader()
will point to another location, and the new program version will crash when
will point to the loader() function...
Then, is possible to FORCE a fixed entry point address of a function,
avoiding any problem in future compilation ???
thanks
Original Post ID: 144514503 |
Andy Drummond Guest
Re: #org default |
Posted: Fri May 16, 2003 10:00 am |
Hello. I have done something almost identical. i think that the compiler is inserting the i2c code before your loader routine. What I did was to leave a small amount at the end for the i2c by using:
#org 0x7800, 0x7E80 DEFAULT
Then the I2C when in at the end. But at the very start of the program I put
#org 0x100,0x77FF
which "used up" all the program space thus preventing the compiler from putting the i2c code anywhere else.
Good luck,
Andy Drummond
:=hi,
:=my application (18F252) use a "loader" for remote (gsm) program upload..
:=the program code are trasmitted and stored in a external EEPROM,
:=and then the program call my loader() function what copy from
:=external eeprom to internal flash (with exclusion, off course, of
:=loader code) and restart the processor..
:=This is my loader function:
:=#org 0x7d80,0x7fff AUTO=0 DEFAULT
:=void loader(void)
:= #use i2c(master,fast,sda=pin_c4, scl=pin_c3, restart_wdt)
:= int16 indirizzo;
:= int8 n;
:= restart_wdt();
:= disable_interrupts(global);
:= disable_interrupts(int_rda);
:= disable_interrupts(int_rtcc);
:= disable_interrupts(int_timer1);
:= disable_interrupts(int_ext);
:= restart_wdt();
:= i2c_start();
:= i2c_write(0b10101110);
:= i2c_write(0x00);
:= i2c_write(0x40);
:= i2c_start();
:= i2c_write(0b10101111);
:= for (indirizzo=0x0200;indirizzo<0x7d80;indirizzo=indirizzo+64)
:= for(n=0;n<64;n++){restart_wdt();g_stg[n]=i2c_read();}
:= WRITE_PROGRAM_MEMORY((int32)indirizzo, g_stg, 64);
:= n = i2c_read(0);
:= i2c_stop();
:= reset_cpu();
:=#org default
:=The program run very good...
:=What is the problem ???
:=the "entry point" of the loader is not 0x7d80 (the start of the reserved space), but
:=another:
:=.................... loader();
:=2C7A: CALL 7E4C
:=due to the fact that this function STAY UNCHANGED FOREVER, if a future change in
:=compiler philosophy will move this "entry point", the future call to loader()
:=will point to another location, and the new program version will crash when
:=will point to the loader() function...
:=Then, is possible to FORCE a fixed entry point address of a function,
:=avoiding any problem in future compilation ???
:=thanks
Original Post ID: 144514510 |
