ds18b20 glcd problem? Help!
Goto page 1, 2  Next
oburak90
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Sat Nov 19, 2011 3:07 pm     Reply with quote
I want see temperature on glcd, but I can't.
My problem is ds18b20 and glcd 128x64 ks0108.
I take the codes http://www.ccsinfo.com/forum/viewtopic.php?t=28425
When I use 16f877a and 2x16 lcd I can read temperature but I use 16f877a and 128x64 glcd I can't read it (I read 0.0).
I use same codes, only change is:
#include <lcd.c> >==> #include <hdm64gs12.c>
and #include <graphics.c>
printf(lcd_putc,"%s ", c_temp); >==> glcd_text57(1,1,c_temp,1,on);
I need help. Thanks.
Codes for 2x16 lcd:
#include <16F877A.h>
#fuses xt,nowdt,noprotect,nobrownout,nolvp,noput,nowrt,nodebug,nocpd
#include<lcd.c>
#include<1wire.c>
#include<ds1820.c>
float f_temp;
char c_temp[15];
setup_comparator(nc_nc_nc_nc);
setup_psp(psp_disabled);
setup_timer_1(t1_disabled);
setup_timer_2(t2_disabled,0,1);
setup_adc_ports(no_analogs);
setup_adc(adc_off);
setup_ccp1(ccp_off);
setup_ccp2(ccp_off);
lcd_putc("\f");
while (1)
  f_temp = ds1820_read();
  lcd_gotoxy(1,1);
  sprintf(c_temp,"TEMP: %2.1f C",f_temp);
and codes for 128x64 glcd;
#include<HDM64GS12.c>
#include<graphics.c>
#include<1wire.c>
#include<ds1820.c>
float f_temp;
char c_temp[15];
setup_adc(adc_off);
glcd_init(on);
while (1)
  glcd_init(on);
Ömer Burak ÖZKESKİN
PostPosted: Sat Nov 19, 2011 4:19 pm     Reply with quote
Since your program works fine with the 2x16 LCD the problem is either the graphics LCD or the driver.
Perhaps the pins chosen for the GLCD are not correct ?
I'd write a 'Hello World' program just to confirm the GLCD is OK.
I don't use GLCDs so I can't test that part of your code. The DS16B20 and 16F877 do work for me though.
oburak90
PostPosted: Sat Nov 19, 2011 5:15 pm     Reply with quote
I must use glcd. This codes for begin my project. My glcd's output "TEMP: 0.0 C" 2x16lcd works fine, but glcd don't work with ds18b20.
is not working with glcd.
I erase f_temp = ds1820_read(); and write f_temp=23.5
I see it on glcd =(
How I can? =) Tthanks your write temtronic. I think use 4x20 but I draw some graphic, it's too easy but not working. =(
Ömer Burak ÖZKESKİN
oburak90
PostPosted: Sat Nov 19, 2011 5:16 pm     Reply with quote
my english is bad.. sorry for this =)..
Ömer Burak ÖZKESKİN
necati
PostPosted: Sun Nov 20, 2011 12:39 am     Reply with quote
data = (float)isi ;
glcd_rect(57,24,110,40, YES,0); //arayi sil
sprintf(str,"%4.1f",data);
glcd_text57(60,25,str,2,1);
necati
PostPosted: Sun Nov 20, 2011 12:42 am     Reply with quote
data = (float)f_temp;
glcd_rect(57,24,110,40, YES,0); //arayi sil ** burasi 0 ise
glcd_text57(60,25,str,2,1); //**burasi 1 olacak
//veya tersi
arayı silmez isen yazilar üst üste cikar
glcd_rect(57,24,110,40, YES,0); //siyah yaziyi sil yeşil yap
glcd_rect(57,24,110,40, YES,1); //siyah icindekiyaziyi sil siyah yap
glcd_text57(60,25,str,2,1); // yesil ustune siyah yaz
glcd_text57(60,25,str,2,0); // siyah icine yesil yaz
oburak90
PostPosted: Sun Nov 20, 2011 1:02 am     Reply with quote
float tipinde data diye bir değişken tanımladım,
str diye 15 elemanlı bir char dizisi tanımladım,
glcd_rect(57,24,110,40, YES,0); //arayi sil ==> yazımızı glcd den temizledik..
data=(float)f_temp; kodu ne işe yarıyor onu anlamadım..
while (1)
  data=(float)f_temp;
  glcd_rect(57,24,110,40,1,0); //arayi sil
diye birşey çıktı orataya ama buda 0.0 gösteriyor =(
birşeyleri eksik yada yanlışmı yapıyorum? şimdiden yardımın ve ilgin için teşekkür ederim.
Ömer Burak ÖZKESKİN
oburak90
PostPosted: Sun Nov 20, 2011 1:22 am     Reply with quote
//veya tersi
şimdi Necati burası 0 ise burası 1 veya tersi dediğin glcd ye sadece yazılar aktif kalanı pasif piksel veya tersi olması içinmidir?
arayı sil diyorsun hangi arayı sileyim? yoksa yeni uyandım diyemi çalışmıyor kafam anlamadım birşey =)
Please use English on the forum.
For Turkish discussions, please use PM's.
- Forum Moderator
Ömer Burak ÖZKESKİN
oburak90
PostPosted: Sun Nov 20, 2011 2:02 am     Reply with quote
.. I understand it. but i have same problem still. i read 0.0 on glcd. but i erase glcd codes and use 2x16 lcd the problem solved(i read the temparature (example: 23.0).. i want use glcd because i write lots of things on glcd..
Ömer Burak ÖZKESKİN
ezflyr
PostPosted: Mon Nov 21, 2011 11:42 am     Reply with quote
It seems clear that something about the GLCD is adversely effecting your DS18b20 readings. I assume that the 2x16 and the GLCD are not connected simultaneously, so you've made a lot of wiring changes to go from one configuration to another. This is a prime area for investigation. Also, we have no idea which PIC pins you are using for the DS18b20, or the GLCD. Perhaps there is a conflict in your pin selection?
I think you'll have to provide a more complete description of the wiring you are using (providing a link to a schematic would be optimal), and also the pin defines used for your DS18b20, and your GLCD.
Good luck!
John
oburak90
PostPosted: Mon Nov 21, 2011 5:29 pm     Reply with quote
Firstly thanks John..
2x16 lcd schematic and codes;
-Click for schematic
-Click for codes
128x16 glcd schematic and codes;
-Click for codes
Download all of the files (pjt,dsn,hex,c)
-Click for 1wire and ds1820 drivers - http://www.ccsinfo.com/forum/viewtopic.php?t=28425
-Click for 2x16 lcd
-Click for 128x64 glcd
Also codes here..
2x16 lcd pins are default(lcd.c) portd ds18b20 data pin to porta.0
#include<lcd.c>
#include<1wire.c>
#include<ds1820.c>
   float f_temp;
   char c_temp[15];
   setup_adc(adc_off);
   lcd_putc("\f");
while (1)
  lcd_gotoxy(1,1);
128x64 glcd pins are default(hdm64gs12.c) ds18b20 data pin to porta.0
#include<1wire.c>
#include<ds1820.c>
float data=0,f_temp=0;
int8 str[5]={};
   setup_adc(adc_off);
glcd_init(on);
while (1)
  data=(float)f_temp*1;
  glcd_init(on);
Ömer Burak ÖZKESKİN
ezflyr
PostPosted: Tue Nov 22, 2011 7:44 am     Reply with quote
A quick question. Is this a "real" project, ie. you are actually building and testing physical hardware, or is this strictly a "virtual" project, ie. you are simulating it exclusively using Proteus?
Thanks,
John
oburak90
PostPosted: Tue Nov 22, 2011 11:23 am     Reply with quote
both =).. i try on proteus its dont work i search on google and i cant found anything after i use 2x16 lcd it is work.. i thinks proteus have a bug i build it on board and try it. i build on board glcd version and its dont work i change glcd to 2x16lcd and codes it is work =(.. i say "i have a problem =)" and i write this topic =)
also i try sht11 on proteus. i is work with 2x16 lcd but dont work on with glcd on glcd only static values its dont increase or decrease.. glcd is a big problem =) or glcd is a very big problem for me =(
Ömer Burak ÖZKESKİN
ezflyr
PostPosted: Tue Nov 22, 2011 2:32 pm     Reply with quote
The DS18b20 and the SHT11 use a completely different hardware interface, so it's somewhat suspicious that they both seem to exhibit the same failure! It suggests that you might be overwriting something in memory, or that you've got a wiring error. Can you post a couple of pictures of your actual hardware?
Thanks,
John
oburak90
PostPosted: Tue Nov 22, 2011 4:28 pm     Reply with quote
sht11 only build on proteus and i see on temp=-40.0 HUD=-4.6 and not change =( glc is a problem.
Ömer Burak ÖZKESKİN
Goto page 1, 2  Next
Page 1 of 2
