Alejandro
WDT timeout to 30 seconds |
Posted: Mon Apr 18, 2011 8:20 pm |
Hi, I need to configure the WDT timeout to 30 seconds, it is possible?
How I can do this, I am using the PIC18F452, 20Mhz |
Posted: Mon Apr 18, 2011 9:35 pm |
The maximum WDT timeout is 2.3 seconds (nominal) with the 18F452.
If you upgrade to the improved version of that PIC, which is the 18F4520,
then you can go up to 131 seconds timeout for the WDT. |
Joined: 01 Jul 2010 Posts: 9149 Location: Greensville,Ontario
Posted: Tue Apr 19, 2011 5:23 am |
Or you could add a 74123,R,C for your own hardware WDT.It'll take a couple of pins but you program it for whatever time you want. |
