jjude
How big "delay_number" |
Posted: Wed Sep 09, 2009 9:12 am |
Sorry bad english.
How big delay number can is?
delay_us(1500) is Ok.
delay_us(15000), is this OK??
#DEFINE number 1500
void clock_nyppy()
viive=number;
if(input(raja_cw) == 0) viive=number*10;
pulssi_on;
delay_us(viive);
pulssi_off;
delay_us(viive);
Its OK? |
asmallri
Joined: 12 Aug 2004 Posts: 1634 Location: Perth, Australia
Posted: Wed Sep 09, 2009 10:42 am |
it depends on the PIC.
on an 18F (PCH compiler) delay_ms accepts a 8 bit variable. But is a constant is used then it can 16 bit constant. _________________ Regards, Andrew
jjude
Posted: Wed Sep 09, 2009 11:15 am |
16F526 |
Posted: Wed Sep 09, 2009 12:09 pm |
Actually in version 4.xxx of the compiler, you can use either a constant
or a variable up to 16-bits. This works in PCM, PCH, etc.
From the manual:
Quote: |
delay_us( )
Syntax: delay_us (time)
Parameters: time - a variable 0-65535(int16) or a constant 0-65535
delay_ms( )
Syntax: delay_ms (time)
Parameters: time - a variable 0-65535(int16) or a constant 0-65535 |
