18F45K22 SPI SDCARD Read Speed Problem
Goto page Previous  1, 2
eaydin
PostPosted: Sun May 29, 2022 11:38 pm     Reply with quote
VCC 3.7V lion battery. I use 0.1uF capacitor on power stage. I try more capacitor in space assembly on circuit breadboard.
PostPosted: Tue May 31, 2022 12:19 am     Reply with quote
A nominal 3.7v Li-ion battery can be up to 4.2v when freshly charged.
Even at 3.7, it is above the rated maximum for an SD card. The SD card
spec has a rated voltage range of 2.7 to 3.6v (SD2 cards down to 1.8v).
asmallri
PostPosted: Tue May 31, 2022 10:48 pm     Reply with quote
Drop your SPI speed down to 5 MHz and retest. If that works successfully try increasing it to 10 MHz. It is rare to find a PIC implementation of an SD card using the SPI bus with an SPI speed above 10 MHz. At these speeds PCB layout becomes critical as is RF noise generation.
Regards, Andrew
eaydin
PostPosted: Wed Jun 01, 2022 12:24 am     Reply with quote
Li-On bat has mid charge. Has a 3.5V
asmallri wrote:
Drop your SPI speed down to 5MHz and restest. If that works successfully try increeasing it to 10MHz. It is rare to find a PIC implementation of an SD card using the SPI bus with an SPI speed above 10MHz. At these speeds PCB layout becomes critical as is RF noise generation.
How to run 5MHZ ? Thats what i know PIC run 4MHZ, 8MHZ, and PLL
PostPosted: Wed Jun 01, 2022 12:27 am     Reply with quote
10M, is 'pushing it'. If you look at the timing diagrams, and add up the
minimum specified high time, low time, and the two rise and fall times,
you get 105nSec legal minimum. So 9.5MHz max. I like to use 8MHz
as the maximum that is generally reliable.
asmallri
PostPosted: Wed Jun 01, 2022 5:10 am     Reply with quote
Ttelmah wrote:
10M, is 'pushing it'.... I like to use 8MHz as the maximum that is generally reliable.
As do I :-)
Regards, Andrew
Page 2 of 2
