Gabriel
Uart + 1-wire same cable |
Posted: Mon Sep 09, 2019 6:52 pm |
Hi, has anyone had any success sharing 1-wire data with a UART?
I have some remote mounted ds18b20 sensors and the customer requested a screen AT the sensor location.
Wiring this setup again is something i REALLY want to avoid... ive spent over 16 hours laying cable just for the sensors...its only about 40 feet, but a terribly complicated path.
The data line has a strong pullup driven by a FET at the master... as per AN-148. Its a simple setup but it works great.
3.3V, GND and 1-wire data line is all i got.
AWG22
Any ideas? _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Mon Sep 09, 2019 6:59 pm |
See this CCS FAQ article:
"What is an easy way for two or more PIC MCUs to communicate?"
http://www.ccsinfo.com/faq.php?page=connect_pics
You have the two files it mentions. They are in your
CCS examples folder. |
Gabriel
Posted: Mon Sep 09, 2019 7:23 pm |
I meant 1 wire as in "Maxim/Dallas 1-wire" and using that same wire for regular serial. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
newguy
Posted: Mon Sep 09, 2019 7:55 pm |
You'd have to experiment. The only 1 wire device I've used is a DS1820 (or 18B20?) temperature sensor. From memory, you have to start the transaction by first asserting the 1-wire line low for a relatively long time. If you rig things so that your serial communication's baud rate is set so that the line is never low long enough to trigger the 1-wire device, you may be able to pull it off. However you'd need to make sure that whatever you choose operates under power supply extremes and anticipated temperature extremes.
Edit: I suppose you could also go to the other extreme. If you slow the baud rate down so much that the 1-wire's "answers" look like jitter, then you should be able to communicate by asserting the line low (as is appropriate given what you want to transmit), hold it low for your bit time, then release the line (high-Z), and let the temperature sensor think it's doing something useful while it holds the line low for a few microseconds before releasing it. You'd need to enable the pullup on that pin, if the PIC has pullups. If not, add an external pullup and ensure you enable the open drain on that pin (which would also be required).
Joined: 01 Jul 2010 Posts: 9196 Location: Greensville,Ontario
Posted: Mon Sep 09, 2019 8:02 pm |
Rethink the overall hardware !
Since you're going to have 'screen' as well as the temp sensor, add a PIC at the remote location..then single wire comm is easy.
What 'screen' will you use ? I'm wondering if the DS data will affect the screen?
Adding a $1 PIC still seems the right way to go though. Especially when the client says 'now I need 2 pushbuttons and a buzzer and ........'
Posted: Mon Sep 09, 2019 9:20 pm |
Gabriel wrote: | I meant 1 wire as in "Maxim/Dallas 1-wire" and using that same wire for regular serial. |
The upper schematic in the FAQ article shows one wire. |
PrinceNai
Posted: Wed Sep 11, 2019 4:50 am |
I'd also go Mr. Temtronic's way. Add another PIC at sensor location and use those three wires just for UART communication. |
smee
Posted: Wed Sep 11, 2019 4:56 am |
You could make use of a ds2404s and make a remote screen, and then use the Dallas one wire bus to display on the screen.
Thats if they still make it. Maxim killed off many parts.
Otherwise as long as you don't pull the bus low for more than 480uS you can use serial like you wanted to.
Or issue a reset, and a match rom and then 8 zeros, to deselect all devices on the bus, then it's yours to do as you wish, provided you don't issue a reset pulse ( >480us ). |
