		| Author | Message |
		| Gabriel
				|  Posted: Wed Jan 30, 2013 7:59 am |   |
				| it means that you are not finding the "+CMTI" string.
 make sure your module is set to send the +CMTI string... i think it is called an "Unsolicited message"
  	  | Code: |  	  | output_low(PIN_D1);           // off receive ready light. counter_search=2;
 HitCounter=0;
 while((HitCounter!=5)&&(counter_search<8))
 if(Recieve_String[counter_search]==StrCMTI[counter_search-2])
 HitCounter++;
 counter_search++;
 the code above starts comparing character by character... if it gets 5 characters in a row to be the same, then the string is "found"
 notice that i start comparing Recieve string from position #2:
 This is because the module will respond:
 "\n \r + C M T I \n \r"    <  ----- Module response
 0  1  2 3 4  5 6 7  8      < ----- index position
 Make sure your module responds as described... the number of characters replied by the module is important  and the CASE of the response is important...
 you should try to run the the entire sequence of the program _manually_ in hyperterminal so that you know what responses you are and are not getting from the module...
 basically pretend you are the pic and send what ever the code is suposed to send and check what the module replys agains what the code expects...
 G.
 CCS PCM 5.078 & CCS PCH 5.093
		| ArthurWong
				|  Posted: Thu Jan 31, 2013 10:06 am |   |
				|  	  | Gabriel wrote: |  	  | it means that you are not finding the "+CMTI" string.
 HitCounter=0;
 HitCounter++;
 counter_search++;
 G.
 Hi Gabriel, i can get the "+CMTI" at the hyper terminal and my PIC also can trigger when receive the message but it is until the coding step below
 I just can work until output_low(PIN_D1)(int SMSALERT()), but the problem is when i send "!LED4 1", the command look like can't read it and the output part "output_high(PIN_B4)(Void DO_CMD())" can't trigger after receive my message...
 Just "output_low(PIN_D1)" then go back to starting again(int TEST_AT() )...
 then Gabriel i would like to ask what is the line of this coding use for
 "counter_read=0; "?
 is that to trigger others when interrupt was trigger? because it look like  just can work until "output_low(PIN_D1)(int SMSALERT())" and cant trigger
 need some advice from u Gabriel...TQ
  	  | Code: |  	  | int SMSALERT() {
 const char StrCMTI[]={"+CMTI"};
 counter_read=0;
 While(counter_read<=16)      // read all data
 output_high(PIN_D1);          // signal ready to receive sms
 counter_read=0;
 Delay_ms(500);              // ignore all remaining characters recieved..if any.
 counter_search=2;
 HitCounter=0;
 HitCounter++;
 counter_search++;
		| Gabriel
				|  Posted: Thu Jan 31, 2013 12:32 pm |   |
				| you need to understand how the code looks for the Strings.
 you also need to understand that if the code fails to find the +CMNI string, it will loop back to the begining... and wont even read the sms...
 look at the structure of calls:
  	  | Code: |  	  | while(1) {
 if(TEST_AT())
 if(SET_MEM())
 if(SET_PDU())
 if(SET_CNMI())
 if(SMSALERT())
 if(READ_SMS())
 if(GET_CMD())
 if(DEL_SMS())
 DO_CMD();
 DEL_SMS();
 if one IF fails the code wont execute any more code and loop back to the beggining.
 Pin D1 goes on when the serial buffer has one or more characters in it... and it goes low after its got 16 chars and a 500ms period expires.
 it THEN looks for the +CNMI string... which its not finding and thus getting back to The AT test...
 MORE INPORTANTLY... TEST THIS FIRST:
 "!LED4 1" is NOT the right command...
 These ARE the right commands:
  	  | Code: |  	  | const char CMD1[8][7]={"Led1 0","Led1 1","Led2 0","Led2 1","Led3 0","Led3 1","Led4 0","Led4 1"}; |
 this is CASE SENSITIVE....
 furthermore:
  	  | Quote: |  	  | then Gabriel i would like to ask what is the line of this coding use for "counter_read=0; "?
 "counter_read" is the index for the Main Serial Buffer...
 G.
		| ArthurWong
				|  Posted: Fri Feb 01, 2013 9:23 pm |   |
				| The command i should send is start with "!" first right Gabriel?  Since it need to detect "!" first then only continue with the command....so based on the coding i should put "!Led4 1" right? |  |
		| Gabriel
				|  Posted: Sat Feb 02, 2013 7:03 am |   |
				| yes! _________________
		| asmboy
				|  Posted: Sat Feb 02, 2013 4:55 pm |   |
				| In that main "while()"  there are enough  Delay_ms(500);  's and longer yet, to take a long nap per execution pass.
 I'm also a bit leery about the situation that obtains with as few as one mangled character in the nested I/O block.
 Fault tolerance is NOT a shining aspect of this implementation.
 I would consider a prioritized method of doing this that perhaps has an
 alternate set of conditionals.
 Just my 2 cents worth.
		| Gabriel
				|  Posted: Mon Feb 04, 2013 9:31 am |   |
				| asmboy, I totally agree with you...
 Like it say on the OP, this is not a perfect or efficient code...
 it was my first attempt at GSM/SMS.
 It was only my intention to offer a "working" starting point for others.
 it does work... but it could be WAY better.
 I am working on a cleaner, completely new "driver"...
 it should reflect some of the things ive learned along the way... should be ready soon..
 I haven't been coding much lately since i was training for IronMan 70.3 here in Panama... which was yesterday, and i successfully finished in 6:30 hours...
 G.
		| ArthurWong
				| I CAN DO IT |
				|  Posted: Wed Feb 06, 2013 10:56 am |   |
				| Hi Gabriel,after a few days try, finally i successful make the coding to be function...now i am on the way modify it....THANK YOU very much Gabriel...u really help me a lot with this project |  |
		| Gabriel
				|  Posted: Wed Feb 06, 2013 3:23 pm |   |
				| Awesome news! Congratulations.
 G.
		| rennelmallari
				|  Posted: Mon Feb 25, 2013 2:12 am |   |
				| Hey Gabriel.
 When will we able to see your update on this code?
		| Gabriel
				|  Posted: Mon Feb 25, 2013 8:19 am |   |
				| ... give me about a week...
 i just got a huge job and ive been busy as hell working on the hardware...
 G.
		| rennelmallari
				|  Posted: Mon Feb 25, 2013 8:52 am |   |
				| That would be great.. so excited to see that, it would be helpful because i have project defense.. ^_^ |  |
		| rennelmallari
				|  Posted: Sun Mar 10, 2013 6:35 pm |   |
				| Hi Gab, i tried your code but i'm stuck here.
  	  | Code: |  	  | int TEST_AT()
 counter_read=0;
 printf("AT");                //send command
 putchar(0x0D);                //send return ('enter' in hyperterminal)
 output_high(PIN_B1);  <--stucked :(
 While(counter_read<=8)             //"A T \R \R \N O K \R \N" characters returned by modem
 output_low(PIN_B1);
 counter_read=0;
 Delay_ms(500);               // ignore all remaining characters received
 if(GET_OK(0X0A))
 Return(1);
 else return(0);
 My hyperterminal reply just "OK" when i enter "AT".
 I use GSM SIM900D. Hope you can help me. Thanks.
		| Gabriel
				|  Posted: Mon Mar 11, 2013 7:19 am |   |
				| Hi,
 First off i appologize for not updating the code as i said i would...
 I'm working on a large proyect right now since 3 weeks and its taken all of my time....
 .... to your question:
 from what i understand you are stuck in the loop:
  	  | Code: |  	  | output_high(PIN_B1);  <--stucked :( While(counter_read<=8)             //"A T \R \R \N O K \R \N" characters returned by modem
 see the Comment next to the loop...
 it is expecting to receive ATLEAST 8 characters.
 from what you posted:
  	  | Quote: |  	  | My hyperterminal reply just "OK" when i enter "AT". |
 I assume you dont have local echo on....
 so your modem is only replying "OK\r\n" and thus not completing the 8+ characters required to exit the loop...
  	  | Code: |  	  | int TEST_AT() {
 counter_read=0;
 While(counter_read==0)    // CHANGED THIS
 output_low(PIN_B1);
 counter_read=0;
 Delay_ms(1000);               // CHANGED THIS
 if(GET_OK(0X0A))
 return(1);
 else return(0);
 Try the function above... i modified it a bit...
 try to understand what i did and you could modify the other functions the same way...
 G.
		| Gabriel
				|  Posted: Wed May 01, 2013 9:29 pm |   |
				| ++++++++++++++++++++++++++++++++++++++++++++++ EDIT:
 Please refer from now on to this code:
 http://www.ccsinfo.com/forum/viewtopic.php?t=50390
 I WILL NOT BE SUPPORTING THIS CODE ANY MORE
 FINALLY...
 G.
