Leandro
| CCS 5 problem in all codes... |
Posted: Wed Feb 19, 2014 9:34 am |
I'm trying to create a web server using the CCS 5 and this happening these errors, anyone know what's wrong?
Posted: Wed Feb 19, 2014 10:12 am |
Yes, you don't have the registers defined.
If you have the IDE, then select 'tools', 'device editor', 'registers' (right hand entry on the top bar of the window), 'make include file'. This will then create a file with all the register defines for your processor. Include this near the top of your code (after fuses processor, clock etc.).
If you don't have the IDE do a search here, include files for this have been posted in the past. |
Leandro
Posted: Wed Feb 19, 2014 10:43 am |
Ttelmah thanks for help!
Is this?
Leandro
Posted: Thu Feb 20, 2014 12:53 pm |
I can not do anything with CCS5 had to remove and reinstall the version 4 release.
The problem now is that this version 4 with version 5 of the wizard, do not know what to do.
This version 5 really fumbled my life. |
Leandro
Posted: Mon Mar 10, 2014 2:17 pm |
Up
Please, help me... |
Joined: 01 Jul 2010 Posts: 9650 Location: Greensville,Ontario
Posted: Mon Mar 10, 2014 2:26 pm |
Unless there is a NECESSARY reason to use V5, just go back to V4. Hopefully you've got proper backups and can do this easily.
Sometimes an 'upgrade' really isn't a good idea.
I'm still in 4.2xx something as there is NO reason for me to 'upgrade'. The features, options, etc. of v5 aren't required for my project.
hth
jay |
gpsmikey
Posted: Mon Mar 10, 2014 4:45 pm |
I thought the latest version of 4 was 4.141 ?
mikey _________________ mikey
Posted: Mon Mar 10, 2014 5:11 pm |
another slip of the finger...sigh, having a half dead finger('skil'saw won ) has been a challenge pressing keys...4.1xx
jay |
Posted: Mon Mar 10, 2014 9:06 pm |
| Quote: | | The problem now is that this version 4 with version 5 of the wizard. |
You need to delete the whole CCS directory and start over with a clean
install of vs. 4.
Make sure you save your license files (*.crg) in a safe place before you
delete the CCS directory. Also make sure you save all your project files.
Save anything you don't want to lose. |
gpsmikey
Posted: Mon Mar 10, 2014 10:16 pm |
| temtronic wrote: | another slip of the finger...sigh, having a half dead finger('skil'saw won ) has been a challenge pressing keys...4.1xx
jay |
Yes, "skill" saws and table saws both can do some very serious damage very quickly (and I have known some very safety conscious folks that have lost an encounter with table saws).
