LCD.C and KBD.C for microEngineering Labs LAB-X1
Hans Zimmer
PostPosted: Tue Jan 21, 2003 9:39 pm     Reply with quote
I'm looking for the LCD and KBD drivers, modified for LAB X-1
LCD uses D0-D7 for data and E0-E2 for RS, E, R/W and KBD uses B0-B3 for rows and B4-B7 for columns (4x4).
Thanks in advance,
Hans
___________________________
Original Post ID: 10875
Re: LCD.C and KBD.C for microEngineering Labs LAB-X1
PostPosted: Wed Jan 22, 2003 1:28 am     Reply with quote
:=I'm looking for the LCD and KBD drivers, modified for LAB X-1
:=LCD uses D0-D7 for data and E0-E2 for RS, E, R/W and KBD uses B0-B3 for rows and B4-B7 for columns (4x4).
I looked at the schematic and the LCD driver data sheet.
<a href="http://www.melabs.com/products/labx1.htm" TARGET="_blank">http://www.melabs.com/products/labx1.htm</a>
You don't have to use all 8 bits on the data bus.
The standard way (at least that I've seen), is to
use the the upper 4 bits, D4-D7.
I think you should be able to use Jon Fick's sample driver.
Go here, and look at the C code for "LCD DISPLAYS":
<a href="http://www.VermontFicks.org/pic.htm" TARGET="_blank">http://www.VermontFicks.org/pic.htm</a>
His driver only uses D4-D7, E, and RS. But the MeLabs board
is completely configurable. You install jumpers on the
headers to use the pins that are needed. So, just install
jumpers for Port D, bits 4-7. Also install jumpers for
port E, bits 0 and 1. Don't install the jumper for bit 2,
because Mr. Fick's driver expects the R/W line to be held low.
The MeLabs board has a pull-down resistor on the R/W line.
The resistor takes care of holding it in a low state.
So just modify his driver to use Port D and E, instead of
ports A and B. It should work OK.
Original Post ID: 10882
Hans Zimmer
PostPosted: Wed Jan 22, 2003 7:50 pm     Reply with quote
Thank you PCM. In the schematic diagram seems there are jumpers between the data lines and the LCD, but they do not exist.
Since I prefer to not cut the traces to modify the board, at least by now, I'm trying to modify LCD.C to do the job.
Jon Fick's driver is a good work, but modifying LCD.C will increase my compatibility with other programs written in CCS C.
Connecting D0-D7 to the LCD, I suppose I can work not only in nibble mode but also in byte mode.
:=I looked at the schematic and the LCD driver data sheet.
:= <a href="http://www.melabs.com/products/labx1.htm" TARGET="_blank"> <a href="http://www.melabs.com/products/labx1.htm" TARGET="_blank">http://www.melabs.com/products/labx1.htm</a></a>
:=You don't have to use all 8 bits on the data bus.
:=The standard way (at least that I've seen), is to
:=use the the upper 4 bits, D4-D7.
:=I think you should be able to use Jon Fick's sample driver.
:=Go here, and look at the C code for "LCD DISPLAYS":
:= <a href="http://www.VermontFicks.org/pic.htm" TARGET="_blank"> <a href="http://www.VermontFicks.org/pic.htm" TARGET="_blank">http://www.VermontFicks.org/pic.htm</a></a>
:=His driver only uses D4-D7, E, and RS. But the MeLabs board
:=is completely configurable. You install jumpers on the
:=headers to use the pins that are needed. So, just install
:=jumpers for Port D, bits 4-7. Also install jumpers for
:=port E, bits 0 and 1. Don't install the jumper for bit 2,
:=because Mr. Fick's driver expects the R/W line to be held low.
:=The MeLabs board has a pull-down resistor on the R/W line.
:=The resistor takes care of holding it in a low state.
:=So just modify his driver to use Port D and E, instead of
:=ports A and B. It should work OK.
Original Post ID: 10914
PostPosted: Wed Jan 22, 2003 9:01 pm     Reply with quote
:=Thank you PCM. In the schematic diagram seems there are jumpers between the data lines and the LCD, but they do not exist.
:=Since I prefer to not cut the traces to modify the board, at least by now, I'm trying to modify LCD.C to do the job.
:=Jon Fick's driver is a good work, but modifying LCD.C will increase my compatibility with other programs written in CCS C.
:=Connecting D0-D7 to the LCD, I suppose I can work not only in nibble mode but also in byte mode.
In the photograph here, it looks like they don't actually
have the headers installed. They just have the pads.
Based on what you said, they apparently have traces going
between the pads.
The CCS file, LCD.C, has all of the LCD signals on one port.
They use a structure to define the variables. I'll think
you'll find that it's difficult to modify that code to work
with two different ports. That's why I recommend Mr. Fick's
code.
His code could still work with the MeLabs board, because
like you said, you can use 4 bits or 8 bits for the data.
With regard to the R/W pin, you can just set it low
by doing "output_low(PIN_E2);", or you can set it to be
and input, by doing "output_float(PIN_E2);". With it
set as an input, the pull-down resistor on the board
will keep R/W low.
In other words, you don't have to cut the traces to
make his driver work. The only reason I suggested that,
is because I thought you might want to use the lower bits
of Port D for something else.
Original Post ID: 10918
Hans Zimmer
PostPosted: Wed Jan 22, 2003 9:28 pm     Reply with quote
If I not mistaken, LCD.C uses all three lines, enable, rs and r/w. But I don't know what they did in their board, since it is not documented in their manual.
Thanks again for your help.
:=In the photograph here, it looks like they don't actually
:=have the headers installed. They just have the pads.
:=Based on what you said, they apparently have traces going
:=between the pads.
:=The CCS file, LCD.C, has all of the LCD signals on one port.
:=They use a structure to define the variables. I'll think
:=you'll find that it's difficult to modify that code to work
:=with two different ports. That's why I recommend Mr. Fick's
:=code.
:=His code could still work with the MeLabs board, because
:=like you said, you can use 4 bits or 8 bits for the data.
:=With regard to the R/W pin, you can just set it low
:=by doing "output_low(PIN_E2);", or you can set it to be
:=and input, by doing "output_float(PIN_E2);". With it
:=set as an input, the pull-down resistor on the board
:=will keep R/W low.
:=In other words, you don't have to cut the traces to
:=make his driver work. The only reason I suggested that,
:=is because I thought you might want to use the lower bits
:=of Port D for something else.
Original Post ID: 10919
