Printf and float ?
Xavier
Printf and float ?
PostPosted: Wed Jan 22, 2003 3:17 pm     Reply with quote
Hello everybody,
Does anyone can help me with printf function with float value ?
My pb :
1) I would like to print float value with leading zeros
printf("\%05.1f",val);
the result is 23.7 with val = 23.7 and should be 023.7 ?
whats wrong ?
2) How can I force the sign with printf ?
printf("\%+05.1f",val); does'nt works ! why ?
Many thanks in advance for your help.
Regards,
Xavier
___________________________
Original Post ID: 10898
Re: Printf and float ?
PostPosted: Wed Jan 22, 2003 6:30 pm     Reply with quote
:=Hello everybody,
:=Does anyone can help me with printf function with float value ?
:=My pb :
:=1) I would like to print float value with leading zeros
:=printf("\%05.1f",val);
:=the result is 23.7 with val = 23.7 and should be 023.7 ?
:=whats wrong ?
:=2) How can I force the sign with printf ?
:=printf("\%+05.1f",val); does'nt works ! why ?
I used PCM vs. 3.136 to run the test program below,
and got the following results in the terminal window:
023.7
+023.7
#include "c:\program files\picc\devices\16F877.h"
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
#use Delay(clock=8000000)
float val;
val = 23.7;
printf("\%05.1f\n\r",val);
printf("\n\r");
printf("+\%05.1f",val);
In the last printf statement, I moved the "+" sign to
the beginning of the format string.
Original Post ID: 10911
Xavier
PostPosted: Thu Jan 23, 2003 3:39 am     Reply with quote
Thanks for you help Smile
I used PCM vs. 3.118
val = 23.7;
The result is 23.7 with no leading zeros ?!
val = -23.7
The result is +-23.7 with no leading zeros and sign pb ?!
The aim is to format the result like
+002.1 if val=2.1
+279,5 if val=279.5
-123.4 if val=-123.4
-025.9 if vzl=-25.9
Any ideas ?
PS : how to purchase free upgrade of PCM ?
Thanks in advance
Regards,
Xavier
Original Post ID: 10923
R.J.Hamlett
PostPosted: Thu Jan 23, 2003 3:42 am     Reply with quote
:=Hi,
:=Thanks for you help <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0">
:=I used PCM vs. 3.118
:=val = 23.7;
:=printf("\%05.1f\n\r",val);
:=The result is 23.7 with no leading zeros ?!
:=val = -23.7
:=printf("+\%05.1f",val);
:=The result is +-23.7 with no leading zeros and sign pb ?!
:=The aim is to format the result like
:=+002.1 if val=2.1
:=+279,5 if val=279.5
:=-123.4 if val=-123.4
:=-025.9 if vzl=-25.9
:=Any ideas ?
:=PS : how to purchase free upgrade of PCM ?
:=Thanks in advance
:=Regards,
:=Xavier
Yes. This has been a running problem with CCS's printf. I am glad to see that it has now been fixed.
The solution on older compilers, is to 'bodge' it, by using sprintf to send the characters to a text buffer, and then add the zeros yourself. :-(
Original Post ID: 10925
PostPosted: Thu Jan 23, 2003 12:46 pm     Reply with quote
:=:=Hi,
:=:=Thanks for you help <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0">
:=:=I used PCM vs. 3.118
:=:=val = 23.7;
:=:=printf("\%05.1f\n\r",val);
:=:=The result is 23.7 with no leading zeros ?!
:=:=val = -23.7
:=:=printf("+\%05.1f",val);
:=:=The result is +-23.7 with no leading zeros and sign pb ?!
:=:=The aim is to format the result like
:=:=+002.1 if val=2.1
:=:=+279,5 if val=279.5
:=:=-123.4 if val=-123.4
:=:=-025.9 if vzl=-25.9
:=:=Any ideas ?
:=:=PS : how to purchase free upgrade of PCM ?
:=:=Thanks in advance
:=:=Regards,
:=:=Xavier
:=Yes. This has been a running problem with CCS's printf. I am glad to see that it has now been fixed.
:=The solution on older compilers, is to 'bodge' it, by using sprintf to send the characters to a text buffer, and then add the zeros yourself. :-(
Here's a post that will help him use the sprintf method.
<a href="http://www.pic-c.com/forum/general/posts/8305.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/8305.html</a>
Original Post ID: 10943
