slahiri Guest
LCD/16F877 |
Posted: Mon Mar 03, 2003 7:24 pm |
I am k eep getting Error when compling this code, can some one tell me what I am doing wrong.
#include <16F877.H>
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=40000000)
#include<lcd_t.C>
int x;
main()
do
x = 2;
printf(lcd_putc, "\%u", x);
while( 1 );
// As defined in the following structure the pin connection is as follows:
// D0 enable
// D1 rs
// D2 rw
// D4 D4
// D5 D5
// D6 D6
// D7 D7
// LCD pins D0-D3 are not used and PIC D3 is not used.
// Un-comment the following define to use port B
// #define use_portb_lcd TRUE
struct lcd_pin_map { // This structure is overlayed
boolean enable; // on to an I/O port to gain
boolean rs; // access to the LCD pins.
boolean rw; // The bits are allocated from
boolean unused; // low order up. ENABLE will
int data : 4; // be pin B0.
} lcd;
#byte lcd = 8 // on to port D (at address 8)
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
byte CONST LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD
// to start it up.
// The following are used for setting
// the I/O port direction register.
STRUCT lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
STRUCT lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
byte lcd_read_byte() {
byte low,high;
set_tris_d(LCD_READ);
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
set_tris_d(LCD_WRITE);
return( (high<<4) | low);
void lcd_send_nibble( byte n ) {
lcd.data = n;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
void lcd_send_byte( byte address, byte n ) {
lcd.rs = 0;
while ( bit_test(lcd_read_byte(),7) ) ;
lcd.rs = address;
delay_cycles(1);
lcd.rw = 0;
delay_cycles(1);
lcd.enable = 0;
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init() {
byte i;
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( byte x, byte y) {
byte address;
if(y!=1)
address=lcd_line_two;
address=0;
address+=x-1;
lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
//delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
char lcd_getc( byte x, byte y) {
char value;
lcd_gotoxy(x,y);
lcd.rs=1;
value = lcd_read_byte();
lcd.rs=0;
return(value);
___________________________
Original Post ID: 12313 |
Re: LCD/16F877 |
Posted: Mon Mar 03, 2003 8:13 pm |
:=I am keep getting Error when compling this code, can some one tell me what I am doing wrong.
:=#include <16F877.H>
The following line should probably have the NOLVP parameter
added to the end.
:=#fuses HS,NOWDT,NOPROTECT
You have typed 40 MHz in the next line, and it
probably should be 4 MHz.
:=#use delay(clock=40000000)
I don't know what this "lcd_t.c" file is. It's not a CCS file.
Does it contain the function prototypes ?
:=#include <lcd_t.C>
:=int x;
If the "lcd_t.c" file does not contain function prototypes,
then you need to add them, or you need to move this entire
"main()" function to the end of the program.
:=main()
:=lcd_init();
:=do
:=delay_ms(100);
:=x = 2;
:=printf(lcd_putc, "\%u", x);
:=delay_ms(100);
:=while( 1 );
This next line is not a comment. It will cause a compiler
error. I wonder why you did not see this.
:=// As defined in the following structure the pin connection is as follows:
:=// D0 enable
:=// D1 rs
:=// D2 rw
:=// D4 D4
:=// D5 D5
:=// D6 D6
:=// D7 D7
:=// LCD pins D0-D3 are not used and PIC D3 is not used.
:=// Un-comment the following define to use port B
:=// #define use_portb_lcd TRUE
:=struct lcd_pin_map { // This structure is overlayed
:=boolean enable; // on to an I/O port to gain
:=boolean rs; // access to the LCD pins.
:=boolean rw; // The bits are allocated from
:=boolean unused; // low order up. ENABLE will
:=int data : 4; // be pin B0.
:=} lcd;
:=#byte lcd = 8 // on to port D (at address 8)
:=#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
:=#define lcd_line_two 0x40 // LCD RAM address for the second line
:=byte CONST LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
:=// These bytes need to be sent to the LCD
:=// to start it up.
:=// The following are used for setting
:=// the I/O port direction register.
:=STRUCT lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
:=STRUCT lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
:=byte lcd_read_byte() {
:=byte low,high;
:=set_tris_d(LCD_READ);
:=lcd.rw = 1;
:=delay_cycles(1);
:=lcd.enable = 1;
:=delay_cycles(1);
:=high = lcd.data;
:=lcd.enable = 0;
:=delay_cycles(1);
:=lcd.enable = 1;
:=delay_us(1);
:=low = lcd.data;
:=lcd.enable = 0;
:=set_tris_d(LCD_WRITE);
:=return( (high<<4) | low);
:=void lcd_send_nibble( byte n ) {
:=lcd.data = n;
:=delay_cycles(1);
:=lcd.enable = 1;
:=delay_us(2);
:=lcd.enable = 0;
:=void lcd_send_byte( byte address, byte n ) {
:=lcd.rs = 0;
:=while ( bit_test(lcd_read_byte(),7) ) ;
:=lcd.rs = address;
:=delay_cycles(1);
:=lcd.rw = 0;
:=delay_cycles(1);
:=lcd.enable = 0;
:=lcd_send_nibble(n >> 4);
:=lcd_send_nibble(n & 0xf);
:=void lcd_init() {
:=byte i;
:=lcd.rs = 0;
:=lcd.rw = 0;
:=lcd.enable = 0;
:=delay_ms(15);
:=for(i=1;i<=3;++i) {
:=lcd_send_nibble(3);
:=delay_ms(5);
:=lcd_send_nibble(2);
:=for(i=0;i<=3;++i)
:=lcd_send_byte(0,LCD_INIT_STRING[i]);
:=void lcd_gotoxy( byte x, byte y) {
:=byte address;
:=if(y!=1)
:=address=lcd_line_two;
:=else
:=address=0;
:=address+=x-1;
:=lcd_send_byte(0,0x80|address);
:=void lcd_putc( char c) {
:=switch (c) {
:=case '\f' : lcd_send_byte(0,1);
:=//delay_ms(2);
:=break;
:=case '\n' : lcd_gotoxy(1,2); break;
:=case '\b' : lcd_send_byte(0,0x10); break;
:=default : lcd_send_byte(1,c); break;
:=char lcd_getc( byte x, byte y) {
:=char value;
:=lcd_gotoxy(x,y);
:=lcd.rs=1;
:=value = lcd_read_byte();
:=lcd.rs=0;
:=return(value);
There is no closing brace at the end of this function.
Original Post ID: 12314 |
slahiri Guest
Re: LCD/16F877 |
Posted: Tue Mar 04, 2003 6:27 am |
:=:=I am keep getting Error when compling this code, can some one tell me what I am doing wrong.
:=:=#include <16F877.H>
:=The following line should probably have the NOLVP parameter
:=added to the end.
:=:=#fuses HS,NOWDT,NOPROTECT
:=You have typed 40 MHz in the next line, and it
:=probably should be 4 MHz.
:=:=#use delay(clock=40000000)
:=I don't know what this "lcd_t.c" file is. It's not a CCS file.
:=Does it contain the function prototypes ?
:=:=#include <lcd_t.C>
:=:=int x;
:=If the "lcd_t.c" file does not contain function prototypes,
:=then you need to add them, or you need to move this entire
:="main()" function to the end of the program.
:=:=main()
:=:=lcd_init();
:=:=do
:=:=delay_ms(100);
:=:=x = 2;
:=:=printf(lcd_putc, "\%u", x);
:=:=delay_ms(100);
:=:=while( 1 );
:=This next line is not a comment. It will cause a compiler
:=error. I wonder why you did not see this.
:=:=// As defined in the following structure the pin connection is as follows:
:=:=// D0 enable
:=:=// D1 rs
:=:=// D2 rw
:=:=// D4 D4
:=:=// D5 D5
:=:=// D6 D6
:=:=// D7 D7
:=:=// LCD pins D0-D3 are not used and PIC D3 is not used.
:=:=// Un-comment the following define to use port B
:=:=// #define use_portb_lcd TRUE
:=:=struct lcd_pin_map { // This structure is overlayed
:=:=boolean enable; // on to an I/O port to gain
:=:=boolean rs; // access to the LCD pins.
:=:=boolean rw; // The bits are allocated from
:=:=boolean unused; // low order up. ENABLE will
:=:=int data : 4; // be pin B0.
:=:=} lcd;
:=:=#byte lcd = 8 // on to port D (at address 8)
:=:=#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
:=:=#define lcd_line_two 0x40 // LCD RAM address for the second line
:=:=byte CONST LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
:=:=// These bytes need to be sent to the LCD
:=:=// to start it up.
:=:=// The following are used for setting
:=:=// the I/O port direction register.
:=:=STRUCT lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
:=:=STRUCT lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
:=:=byte lcd_read_byte() {
:=:=byte low,high;
:=:=set_tris_d(LCD_READ);
:=:=lcd.rw = 1;
:=:=delay_cycles(1);
:=:=lcd.enable = 1;
:=:=high = lcd.data;
:=:=lcd.enable = 0;
:=:=lcd.enable = 1;
:=:=delay_us(1);
:=:=low = lcd.data;
:=:=lcd.enable = 0;
:=:=set_tris_d(LCD_WRITE);
:=:=return( (high<<4) | low);
:=:=void lcd_send_nibble( byte n ) {
:=:=lcd.data = n;
:=:=lcd.enable = 1;
:=:=delay_us(2);
:=:=lcd.enable = 0;
:=:=void lcd_send_byte( byte address, byte n ) {
:=:=lcd.rs = 0;
:=:=while ( bit_test(lcd_read_byte(),7) ) ;
:=:=lcd.rs = address;
:=:=lcd.rw = 0;
:=:=lcd.enable = 0;
:=:=lcd_send_nibble(n >> 4);
:=:=lcd_send_nibble(n & 0xf);
:=:=void lcd_init() {
:=:=byte i;
:=:=lcd.rs = 0;
:=:=lcd.rw = 0;
:=:=lcd.enable = 0;
:=:=delay_ms(15);
:=:=for(i=1;i<=3;++i) {
:=:=lcd_send_nibble(3);
:=:=delay_ms(5);
:=:=lcd_send_nibble(2);
:=:=for(i=0;i<=3;++i)
:=:=lcd_send_byte(0,LCD_INIT_STRING[i]);
:=:=void lcd_gotoxy( byte x, byte y) {
:=:=byte address;
:=:=if(y!=1)
:=:=address=lcd_line_two;
:=:=else
:=:=address=0;
:=:=address+=x-1;
:=:=lcd_send_byte(0,0x80|address);
:=:=void lcd_putc( char c) {
:=:=switch (c) {
:=:=case '\f' : lcd_send_byte(0,1);
:=:=//delay_ms(2);
:=:=break;
:=:=case '\n' : lcd_gotoxy(1,2); break;
:=:=case '\b' : lcd_send_byte(0,0x10); break;
:=:=default : lcd_send_byte(1,c); break;
:=:=char lcd_getc( byte x, byte y) {
:=:=char value;
:=:=lcd_gotoxy(x,y);
:=:=lcd.rs=1;
:=:=value = lcd_read_byte();
:=:=lcd.rs=0;
:=:=return(value);
:=There is no closing brace at the end of this function.
I have change every thing you have asked me to change. I am using CCS LCD driver. My LCD is connected to PORTD. I was able to complie code but I don't see any thing on my LCD. I am posting my code again, Please take a look at it.
#include <16F877.H>
#include<lcd.C>
int x;
main()
do
x = 2;
while( 1 );
Original Post ID: 12321 |
Paladdin Guest
Re: LCD/16F877 |
Posted: Tue Mar 04, 2003 6:48 am |
:=I have change every thing you have asked me to change. I am using CCS LCD driver. My LCD is connected to PORTD. I was able to complie code but I don't see any thing on my LCD. I am posting my code again, Please take a look at it.
:=#fuses HS,NOWDT,NOPROTECT,NOLVP
:=#use delay(clock=4000000)
:=#include<lcd.C>
:=int x;
:=main()
:=lcd_init();
:=do
:=x = 2;
:=while( 1 );
LCD hardware cursor advances as you write and is easy to go out of the display. Maybe not the origin of the bug, but you should clear your LCD display before attempt any writes. You can accomplish this sending it a '\f' char:
printf(lcd_putc, "\f\%u", x) ;
This puts cursor at first line, first position. Jump to the next line with an '\n'.
It useful take a look at lcd.c source and, even more, reading any Hitachi display compatible docs. You will learn even how to send your very own custom chars to show on it :)
Good luck,
Original Post ID: 12322 |
slahiri Guest
Re: LCD/16F877 |
Posted: Tue Mar 04, 2003 9:40 am |
:=:=I have change every thing you have asked me to change. I am using CCS LCD driver. My LCD is connected to PORTD. I was able to complie code but I don't see any thing on my LCD. I am posting my code again, Please take a look at it.
:=:=#fuses HS,NOWDT,NOPROTECT,NOLVP
:=:=#use delay(clock=4000000)
:=:=#include<lcd.C>
:=:=int x;
:=:=main()
:=:=lcd_init();
:=:=do
:=:=x = 2;
:=:=while( 1 );
:=LCD hardware cursor advances as you write and is easy to go out of the display. Maybe not the origin of the bug, but you should clear your LCD display before attempt any writes. You can accomplish this sending it a '\f' char:
:=printf(lcd_putc, "\f\%u", x) ;
:=This puts cursor at first line, first position. Jump to the next line with an '\n'.
:=It useful take a look at lcd.c source and, even more, reading any Hitachi display compatible docs. You will learn even how to send your very own custom chars to show on it <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0">
:=Good luck,
I am using LCD which has controller HD44780A00. And this are PIN out. My other question is if I hold my logic prob on D0 which the enable pin for LCD what should I see.
LCD PIN OUT
1--GND
2--VCC
3--VEE--contrast
4--RS
5--R/W
6--E
7--14--DB0--DB7
// D0 enable
// D1 rs
// D2 rw
// D4 D4
// D5 D5
// D6 D6
// D7 D7
Original Post ID: 12332 |
Re: LCD/16F877 |
Posted: Tue Mar 04, 2003 1:07 pm |
:=I am using LCD which has controller HD44780A00. And this are PIN out. My other question is if I hold my logic prob on D0 which the enable pin for LCD what should I see.
:=LCD PIN OUT
:=1--GND
:=2--VCC
:=3--VEE--contrast
:=4--RS
:=5--R/W
:=6--E
:=7--14--DB0--DB7
What about the contrast pin ? That could be the problem.
See this recent post:
<a href="http://www.pic-c.com/forum/general/posts/12317.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/12317.html</a>
What voltage do you have connected to pin 3 (contrast pin) ?
Original Post ID: 12344 |
slahiri Guest
Re: LCD/16F877 |
Posted: Tue Mar 04, 2003 1:53 pm |
:=:=I am using LCD which has controller HD44780A00. And this are PIN out. My other question is if I hold my logic prob on D0 which the enable pin for LCD what should I see.
:=:=LCD PIN OUT
:=:=1--GND
:=:=2--VCC
:=:=3--VEE--contrast
:=:=4--RS
:=:=5--R/W
:=:=6--E
:=:=7--14--DB0--DB7
:=What about the contrast pin ? That could be the problem.
:=See this recent post:
:= <a href="http://www.pic-c.com/forum/general/posts/12317.html" TARGET="_blank"> <a href="http://www.pic-c.com/forum/general/posts/12317.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/12317.html</a></a>
:=What voltage do you have connected to pin 3 (contrast pin) ?
I do have two black line showing on the LCD when I power up.
Original Post ID: 12346 |
karth Guest
Re: LCD/16F877 |
Posted: Tue Mar 04, 2003 2:58 pm |
I had to write code for a LCD driver that had a KSO108 driver. the enable pin is an input to LCD driver, and each time it receive a command the enable pin has to be toggled.
example:
write to LCD
enable pin low
enable pin high
and you should keep all d0 d7 data pin on the same port.
good luck...
Original Post ID: 12347 |
slahiri Guest
Re: LCD/16F877 |
Posted: Tue Mar 04, 2003 6:15 pm |
:=:=:=I am using LCD which has controller HD44780A00. And this are PIN out. My other question is if I hold my logic prob on D0 which the enable pin for LCD what should I see.
:=:=:=LCD PIN OUT
:=:=:=1--GND
:=:=:=2--VCC
:=:=:=3--VEE--contrast
:=:=:=4--RS
:=:=:=5--R/W
:=:=:=6--E
:=:=:=7--14--DB0--DB7
:=:=What about the contrast pin ? That could be the problem.
:=:=See this recent post:
:=:= <a href="http://www.pic-c.com/forum/general/posts/12317.html" TARGET="_blank"> <a href="http://www.pic-c.com/forum/general/posts/12317.html" TARGET="_blank"> <a href="http://www.pic-c.com/forum/general/posts/12317.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/12317.html</a></a></a>
:=:=What voltage do you have connected to pin 3 (contrast pin) ?
:=I do have two black line showing on the LCD when I power up.
I would like thank every one those who help me thank you all. My LCD works
Original Post ID: 12354 |
