Luis Roberto Guest
Code Help with interrupts |
Posted: Sun Jan 19, 2003 8:04 am |
Hi Folks!
I'm new in CCS compiler and I'm trying to do a program to count some quantities and my program does not work as I wish. I have an 74C922 (keypad 16 key encoder) with pin DA connected to my RB0/INT pin. It reconize that I pressed a button and gives me a correct value ( Tecla variable ) and set Tec_Press bit, that indicates me that a key was pressed. If I press "A" key in my keypad (value 10 decimal) my program switches to FuncaoA() and it can't leave that function until I press again a "A" key, because I have an infinite loop that tests every time if I had a key pressed (bit Tec_Press=1), but in fact it returns to my switch function at main() function (it is visible if I press "B" key it shows me the text "Function B" in my LCD). Any suggestion?
Another point is that i want to read 4 values from my keypad and store it in one variable (Qtde) - for example, I press 3 followed by 4 followed by 5 followed by 7 and my Qtde var must have 3457 stored (in order 1000's, 100's, 10's and 1's). How can I do that?
Thanks a lot,
Luis
#int_ext
UCHAR le_tec()
bit_set(Tec_Press);
set_tris_b(0xF1);
Tecla=PORT_B;
Tecla=swap(Tecla)&0x0F;
set_tris_b(0x01);
void main( void )
Qtde=0000;
QtdeBL=0001;
bit_clear(Tec_Press);
enable_interrupts(global);
enable_interrupts(int_ext);
set_tris_b ( 0x01 ); /* Bit 0 is input */
set_tris_a ( 0x00 );
LCD_Init(); // initializes display
CMD_LCD(CLEAR_DISP);
delay_ms(2);
printf(CHAR_LCD," Ready");
for (;;)
if (bit_test(Tec_Press))
switch (Tecla)
case 10: FuncaoA(); break;
case 11: FuncaoB(); break;
FuncaoA()
// Tec_Press==0;
CMD_LCD(0x01);
delay_ms(2);
printf(CHAR_LCD,"Quantity \%04ld",Qtde);
CMD_LCD(0xC0);
printf(CHAR_LCD,"Blocks \%04ld",QtdeBL);
CMD_LCD(0x8C); // Set column
CMD_LCD(0x0F); // Blinking Cursor
for(;;)
while (bit_test(Tec_Press)) {};
CHAR_LCD(Tecla+0x30);
if (Tecla==10) return;
FuncaoB()
// Tec_Press==0;
printf(CHAR_LCD,"Function B");
if (Tecla==11) return;
Original Post ID: 10800 |
kolio Guest
Re: Code Help with interrupts |
Posted: Mon Jan 20, 2003 2:10 am |
when you're pressing "A" key then an interrupt appears (74C922 to EXT Int), but what will happen when you're releasing the key ? I don't see where the key release is processed.
Original Post ID: 10810 |
