INT_RDA not working...
krugerrc
PostPosted: Thu Dec 20, 2001 12:57 am     Reply with quote
I'm writing a program (for the PIC16F877) where I enable the interrupts not at the beginning of, but later in main(). My problem is this: The program works up to the point where I enable the interrupts (I'm only using global and INT_RDA). If I comment out the two lines that enables the interrupts, the rest of the program executes correctly.
What Am I doing wrong??
Here's an example of my program
#int_RDA
RDA_isr() {
RS232=true; //there is some characters waiting...
int main(){
LCD_INIT();
soft_on();
init_modem();
enter_pin();
if (dbg)
printf(LCD_PUTC,"\f secs count-down");
i=30;
while (i>0){
i--;
if (dbg){
LCD_gotoxy(1,1);
printf(LCD_PUTC,"\%u", i);
if (dbg){
printf(LCD_PUTC,"\f Enabling\n Interrupts");
} //----> program works up to here
enable_interrupts(global);
enable_interrupts(INT_RDA);
if (dbg){
printf(LCD_PUTC,"\f Interrupts\n Enabled");
___________________________
Original Post ID: 1702
Richard Golding
Re: INT_RDA not working...
PostPosted: Thu Dec 20, 2001 3:15 am     Reply with quote
I think the 'enable_interrupts(global)' statement
should be the last the interrupt list viz:-
see example program EX_STWT.C in back of CCS manual
Original Post ID: 1703
PostPosted: Thu Dec 20, 2001 12:05 pm     Reply with quote
:=Hi,
:=I'm writing a program (for the PIC16F877) where I enable the interrupts not at the beginning of, but later in main(). My problem is this: The program works up to the point where I enable the interrupts (I'm only using global and INT_RDA). If I comment out the two lines that enables the interrupts, the rest of the program executes correctly.
:=What Am I doing wrong??
:=Here's an example of my program
:=#int_RDA
:=RDA_isr() {
:= RS232=true; //there is some characters waiting...
Do this:
#int_RDA
RDA_isr()
char c;
c = getc();
RS232=true;
Read the 16F877 data sheet, in the section on the USART
Asynchronous Receiver. It says: "Flag bit RCIF is a
read only bit, which is cleared by hardware. It is cleared
when the RCREG register has been read and is empty."
Ie., you have to clear the receive interrupt condition.
You can do this by reading the byte from the USART.
Original Post ID: 1707
Mike D
PostPosted: Thu Dec 20, 2001 2:39 pm     Reply with quote
Hey, that sorted out one of my problems too.
:=I think the 'enable_interrupts(global)' statement
:=should be the last the interrupt list viz<img src="http://www.ccsinfo.com/pix/forum/disagree.gif" border="0">
:= enable_interrupts(INT_RDA);
:= enable_interrupts(GLOBAL);
:=see example program EX_STWT.C in back of CCS manual
Original Post ID: 1708
