Sleep on 18F452
bgpartri
Sleep on 18F452
PostPosted: Mon Aug 25, 2003 4:43 pm     Reply with quote
I am trying to set my 18F452 to sleep until it gets an interrupt on INT_EXT. While it is sleeping, I would like to update the time so I know the time when wake up. I tried the following code, but it doesn't go back to sleep:
void int_timer1_isr(void){
set_timer1(MS_250);
if (state == SLEEPING){
sleep();
} else {
I want to wake up with something like this:
void int_ext_isr(void)
state = MAINTAIN;
just_woke_up = TRUE;
} else {
disable_interrupts(INT_EXT);
button1_debounce_count = 1;
I am going to sleep with the following code:
state = SLEEPING;
//disable_interrupts(INT_TIMER1);
sleep();
If I disable the TIMER1 interrupt, it stays asleep, and even the INT_EXT won't wake it up.
It feels like I'm really missing something here.
___________________________
Original Post ID: 144517242
bgpartri
Re: Sleep on 18F452
PostPosted: Mon Aug 25, 2003 5:50 pm     Reply with quote
:=I am trying to set my 18F452 to sleep until it gets an interrupt on INT_EXT. While it is sleeping, I would like to update the time so I know the time when wake up. I tried the following code, but it doesn't go back to sleep:
:=void int_timer1_isr(void){
:= set_timer1(MS_250);
:= if (state == SLEEPING){
:= sleep();
:= } else {
I managed to fix it myself. First, it doesn't like going to sleep in a ISR apparently. It really shouldn't matter, since sleep just stops the clock. But I moved the sleep to my mainline, and now it works.
INT_EXT not waking up was a logic error. I disable the interrupts to do a debounce, but didn't enable them after I used the same button to set the sleep state.
:=I want to wake up with something like this:
:=void int_ext_isr(void)
:=if (state == SLEEPING){
:= state = MAINTAIN;
:= just_woke_up = TRUE;
:= } else {
:= disable_interrupts(INT_EXT);
:= button1_debounce_count = 1;
:=I am going to sleep with the following code:
:=state = SLEEPING;
:=//disable_interrupts(INT_TIMER1);
:=sleep();
:=If I disable the TIMER1 interrupt, it stays asleep, and even the INT_EXT won't wake it up.
:=It feels like I'm really missing something here.
Original Post ID: 144517244
