MCW Guest
#INT Global |
Posted: Thu Aug 21, 2003 5:15 am |
I´ve got still a problem with the following interrupt service. The program steps into the isr, as planned, but then a reset follows. I´ve looked to the .lst file and found a retlw 00 instruction at the end of my isr.
At the memory address 0x00 is the goto 0x0200 instruction ( my main function is located at this address)
I need some more help in this situation !!!
#INT_GLOBAL
#asm
goto VECTOR_MY_ISR_HIGH
#endasm
#org VECTOR_MY_ISR_HIGH, VECTOR_MY_ISR_HIGH + VECTOR_LEN3
void myISR_Vector_High( void )
if ( bit_test(INTCON,2) )
if (bit_test(INTCON, 5))
Var.ISR |= 0x01; }
Bit_Clear(INTCON, 2);
if (bit_test(PIR3, 0))
if (bit_test(PIE3, 0)) {
Var.ISR |= 0x02; }
BIT_CLEAR(PIR3,0); }
#asm
retfie
#endasm
Original Post ID: 144517124 |
R.J.Hamlett Guest
Re: #INT Global |
Posted: Thu Aug 21, 2003 7:15 am |
:=Hello,
:=I´ve got still a problem with the following interrupt service. The program steps into the isr, as planned, but then a reset follows. I´ve looked to the .lst file and found a retlw 00 instruction at the end of my isr.
:=At the memory address 0x00 is the goto 0x0200 instruction ( my main function is located at this address)
:=I need some more help in this situation !!!
:=Best Wishes
You are still not saving the registers...
This has to be done by you (it is not automatic).
Also, since you have not actually defined a 'function' now, the compiler does not treat this as an interrupt handler...
//You will need the addresses of the status register, and BSR defined
//to suit your processor.
#INT_GLOBAL
void isr_handler(void) {
static int save_w;
static int save_status;
static int save_BSR;
#asm
MOVWF save_w
SWAPF status,W
BCF status,5
BCF status,6
MOVWF save_status
//If you want to start jumping around, you will have to
//save PCLATH/L as well
MOVF BSR
MOVWF save_BSR
#endasm
if ( bit_test(INTCON,2) ) {
if (bit_test(INTCON, 5)) {
Var.ISR |= 0x01;
if (bit_test(PIR3, 0)) {
Var.ISR |= 0x02;
BIT_CLEAR(PIR3,0);
#asm
MOVF save_BSR
MOVWF BSR
SWAPF save_status,W
MOVWF status
SWAPF save_w,F
SWAPF save_w,W
#endasm
:= #INT_GLOBAL
:= #asm
:= goto VECTOR_MY_ISR_HIGH
:= #endasm
:= #org VECTOR_MY_ISR_HIGH, VECTOR_MY_ISR_HIGH + VECTOR_LEN3
:= void myISR_Vector_High( void )
:= if ( bit_test(INTCON,2) )
:= if (bit_test(INTCON, 5))
:= Var.ISR |= 0x01; }
:= Bit_Clear(INTCON, 2);
:= if (bit_test(PIR3, 0))
:= if (bit_test(PIE3, 0)) {
:= Var.ISR |= 0x02; }
:= BIT_CLEAR(PIR3,0); }
:= #asm
:= retfie
:= #endasm
Original Post ID: 144517126 |
