markpaxton Guest
Re: Unable to read all receive bytes |
Posted: Wed Aug 20, 2003 8:07 am |
I'm no expert at all, so I could be wrong... I know there's a buffer on the receiver of 3 characters. You might just be reading the 1st two chars when the int_rda fires indicating more than that in the buffer and leaving the other 3 behind (does int_rda stay set after the isr until the buffer is emptied?). You'd see no hangup/error as #use rs232 has the errors option set. As a quick hack, stick a few ms delay in the PC code between sending chars to the PIC. Also look at the RS232_ERRORS variable.
___________________________
Original Post ID: 144517108 |
Humberto
Posted: Wed Aug 20, 2003 10:25 am |
:=I'm trying to do a simple test to illustrate the timer and rda interrupts.
:=Each time the timer interrupt is called it serially sends a 5-byte message. If the PC sends a 5-byte message i.e. 0xB2, 0x07, 0x02, 0x01, 0x01, the test program below is meant to echo it back. However, it seems that the serial interrupt is only called twice because it only echoes back the first 2 bytes.
:=There is hardly any code in the rda interrupt.
:=Why is this so? I must be missing something here. I'm using the #use rs232(baud =19200, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
:=int array[10];
:=short int flag_fifo = 0;
short int flag_timer2 = 0;
:=int a = 0;
:=test_tx( int x1, int x2, int x3, int x4, int x5)
:= putc(x1);
:= putc(x2);
:= putc(x3);
:= putc(x4);
:= putc(x5);
:=#int_rda
:=serial_isr()
:= array[a] = getc();
:= a++;
if(a >= 4)
{flag_fifo = 1;}
:= disable_interrupts(INT_TIMER2);
:=#int_timer2
:=timer2_isr()
flag_timer2 = 1;
Note: keep your isr routine as short as possible
//:= test_tx(0xB1, 0x53, 0x08, 0x07, 0x01);
:=main()
int b;
:= while(1)
:= enable_interrupts(INT_TIMER2);
:= enable_interrupts(INT_RDA);
:= enable_interrupts(GLOBAL);
:= //do something here
:= if(flag_fifo)
disable_interrupts(GLOBAL);
for(b = 0; b <= a; b++)
putc( array[b] );
:= flag_fifo = 0;
:= a = 0;
if(flag_timer2)
flag_timer2 = 0;
Hope this help.
rgds
Humberto
Original Post ID: 144517109 _________________ Humber |
R.J.Hamlett Guest
Posted: Wed Aug 20, 2003 10:53 am |
:=int array[10];
:=int a = 0;
:= putc(x1);
:= putc(x2);
:= putc(x3);
:= putc(x4);
:= putc(x5);
:=#int_rda
:=serial_isr()
:= a++;
:= flag_fifo = 1;
:=#int_timer2
:=timer2_isr()
Start here.
Avoid using any routine, inside, and outside an ISR. You are now doing this with 'putc', which will mean that the main code will automatically attempt to disable interrupts around the putc call. Though it _should_ test the status of the interrupt, and only disable it if it is enabled, and re-enable it, only if it was enabled, you are making the compiler have to do a lot of work. Also 'putc', will wait till the character has sent. Hence it is possible that timer2, could re-interrupt, before two characters have been sent (there are potentially three characters of RS232 output buffering), and things could get very messy here. Use an interrupt driven transmit as well, and your own 'putc', that just transfers characters to the buffer, or do the transfer from 'main', once the flag is set.
:=main()
:= while(1)
You have not setup the divisor, or timeout values for the timer. The defaults may be OK, but don't rely on them...
:= if(flag_fifo)
:= int b;
:= for(b = 0; b < a; b++)
:= putc( array[b] );
So, if one character only has been received at this point, only one character will be echoed back. You then go into the timer based handler, and behaviour then depends on the timer settings, and how the interrupts will interact...
:= flag_fifo = 0;
:= a = 0;
Original Post ID: 144517111 |
