pat
Joined: 07 Sep 2003 Posts: 40 Location: Adelaide, Australia
A/D reading with 16F877 |
Posted: Thu Aug 14, 2003 11:53 am |
Hi! I built a simple thermometer that reads temperature from 0-50 degree. But problem I got is that the readings I get jump some values. As an example, A/D reads from 0 to 009F, than jumps to 0100. It doesn't read from 00A0 to 00FF. Same from 0100 to 0180, than jumps to 0200; and again from 0200 to 02A0, than jumps to 0300 and finally reads ok to 03FF. Sorry but I just don't understand with it does that. Any ideas?
Thanks a lot.
Here's the code.
int iTemp;
long lTemp;
float fTemp;
setup_adc_ports(A_ANALOG);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(FALSE);
setup_psp(PSP_DISABLED);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
lcd_gotoxy(1,1);
printf(LCD_PUTC, "Bonjour, il fait: ");
lcd_gotoxy(1,2);
printf(LCD_PUTC, "Valeur HEX: ");
lcd_gotoxy(21,1);
printf(LCD_PUTC, "Valeur C: ");
set_adc_channel(0);
lTemp = Read_ADC();
lcd_gotoxy(12,2);
printf(LCD_PUTC, "\%4LX", lTemp);
fTemp = (lTemp / 20.48);
iTemp = ceil(fTemp);
lcd_gotoxy(30,1);
printf(LCD_PUTC, "\%2u", iTemp);
___________________________
Original Post ID: 144516965 |
Re: A/D reading with 16F877 |
Posted: Thu Aug 14, 2003 12:16 pm |
:=void main()
:= int iTemp;
:= long lTemp;
:= float fTemp;
:= setup_adc_ports(A_ANALOG);
This next line immediately draws my attention. The data sheet
says to use the Fosc/2 clock only if your crystal frequency
is at 1.25 MHz or below. What freq are you using ?
:= setup_adc(ADC_CLOCK_DIV_2);
:= setup_spi(FALSE);
:= setup_psp(PSP_DISABLED);
:= setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
:= setup_timer_1(T1_DISABLED);
:= setup_timer_2(T2_DISABLED,0,1);
:= setup_ccp1(CCP_OFF);
:= setup_ccp2(CCP_OFF);
:= lcd_init();
:= lcd_gotoxy(1,1);
:= printf(LCD_PUTC, "Bonjour, il fait: ");
:= lcd_gotoxy(1,2);
:= printf(LCD_PUTC, "Valeur HEX: ");
:= lcd_gotoxy(21,1);
:= printf(LCD_PUTC, "Valeur C: ");
:= while(1)
:= delay_ms(100);
:= set_adc_channel(0);
:= delay_ms(100);
:= lTemp = Read_ADC();
:= lcd_gotoxy(12,2);
:= printf(LCD_PUTC, "\%4LX", lTemp);
:= fTemp = (lTemp / 20.48);
:= iTemp = ceil(fTemp);
:= lcd_gotoxy(30,1);
:= printf(LCD_PUTC, "\%2u", iTemp);
Original Post ID: 144516966 |
pat
Posted: Thu Aug 14, 2003 12:31 pm |
Oups, actually I'm using a 20MHz crystal.
Pat
:=:=void main()
:=:= int iTemp;
:=:= long lTemp;
:=:= float fTemp;
:=:= setup_adc_ports(A_ANALOG);
:=This next line immediately draws my attention. The data sheet
:=says to use the Fosc/2 clock only if your crystal frequency
:=is at 1.25 MHz or below. What freq are you using ?
:=:= setup_adc(ADC_CLOCK_DIV_2);
:=:= setup_spi(FALSE);
:=:= setup_psp(PSP_DISABLED);
:=:= setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
:=:= setup_timer_1(T1_DISABLED);
:=:= setup_timer_2(T2_DISABLED,0,1);
:=:= setup_ccp1(CCP_OFF);
:=:= setup_ccp2(CCP_OFF);
:=:= lcd_init();
:=:= lcd_gotoxy(1,1);
:=:= printf(LCD_PUTC, "Bonjour, il fait: ");
:=:= lcd_gotoxy(1,2);
:=:= printf(LCD_PUTC, "Valeur HEX: ");
:=:= lcd_gotoxy(21,1);
:=:= printf(LCD_PUTC, "Valeur C: ");
:=:= while(1)
:=:= delay_ms(100);
:=:= set_adc_channel(0);
:=:= delay_ms(100);
:=:= lTemp = Read_ADC();
:=:= lcd_gotoxy(12,2);
:=:= printf(LCD_PUTC, "\%4LX", lTemp);
:=:= fTemp = (lTemp / 20.48);
:=:= iTemp = ceil(fTemp);
:=:= lcd_gotoxy(30,1);
:=:= printf(LCD_PUTC, "\%2u", iTemp);
Original Post ID: 144516967 |
Posted: Thu Aug 14, 2003 12:43 pm |
:=Oups, actually I'm using a 20MHz crystal.
Change it to this:
setup_adc(ADC_CLOCK_DIV_32);
Original Post ID: 144516968 |
pat
Posted: Thu Aug 14, 2003 9:17 pm |
Yesss! You're the man!
Thanks again for that!
Pat
:=:=Oups, actually I'm using a 20MHz crystal.
:=Change it to this:
:=setup_adc(ADC_CLOCK_DIV_32);
Original Post ID: 144516987 |
