Can't #DEVICE *=16 on latest compiler
Joe Porthouse
PostPosted: Mon Aug 11, 2003 2:10 pm     Reply with quote
This is very frustrating. Every time I upgrade my compiler I spend a day chasing down incompatabilities between my previously working code and the new compiler.
#include <16F877.h>
#DEVICE PIC16F877 *=16
#fuses hs,wdt,noprotect,put,brownout,nolvp
Generates an “Error 23 - Can not change device type this far into the code” on the #device line.
Removing the line I get “Not enough RAM for all variables”.
How do I get the *=16 onto this device?
___________________________
Original Post ID: 144516899
Steve H.
Re: Can't #DEVICE *=16 on latest compiler
PostPosted: Mon Aug 11, 2003 2:52 pm     Reply with quote
:=This is very frustrating. Every time I upgrade my compiler I spend a day chasing down incompatabilities between my previously working code and the new compiler.
:=#include <16F877.h>
:=#DEVICE PIC16F877 *=16
:=#fuses hs,wdt,noprotect,put,brownout,nolvp
:=Generates an “Error 23 - Can not change device type this far into the code” on the #device line.
:=Removing the line I get “Not enough RAM for all variables”.
:=How do I get the *=16 onto this device?
I think this is bacause the device name is also in the header file. Change your line to remove the part type like,
#DEVICE *=16
and make sure that the header also does not have a *=16 in it.
Steve H.
Original Post ID: 144516900
Joe Porthouse
PostPosted: Tue Aug 12, 2003 7:09 am     Reply with quote
:=:=This is very frustrating. Every time I upgrade my compiler I spend a day chasing down incompatabilities between my previously working code and the new compiler.
:=:=#include <16F877.h>
:=:=#DEVICE PIC16F877 *=16
:=:=#fuses hs,wdt,noprotect,put,brownout,nolvp
:=:=Generates an “Error 23 - Can not change device type this far into the code” on the #device line.
:=:=Removing the line I get “Not enough RAM for all variables”.
:=:=How do I get the *=16 onto this device?
:=I think this is bacause the device name is also in the header file. Change your line to remove the part type like,
:=#DEVICE *=16
:=and make sure that the header also does not have a *=16 in it.
:=Steve H.
That did it, thanks.
Original Post ID: 144516921
