MLE Guest
ccp1 interrupt still not working |
Posted: Thu Aug 07, 2003 9:39 am |
I cannot get the ccp1 interrupt to work. I am trying to get an interrupt every 0.5sec. I have an external clock input of 4096Hz, so I want timer1 to create a match at 2048. This is what I've tried to set up, but the interrupt routine is never triggered.
Here is my code (i've included the rtc.h file at the end)
#include "mylcd.h"
#include "rtc.h"
#include <string.h>
#fuses XT,NOWDT,NOPUT,NOBROWNOUT,NOLVP
#byte ADCON1 = 0X9F //The adcon1 register
#byte PORTA = 0x05
#byte PORTB = 0x06
#byte PORTC = 0x07
#byte PORTD = 0x08
#byte PORTE = 0x09
#bit CCP1_FLAG = 0x0C.2 //the capture/compare flag
/*----------FUNCTIONS-----------*/
/***********CCP1_int***********************/
/*This function handles the capture and */
/*compare inturrupt routine. */
#INT_CCP1
CCP1_int(){
//Variables
int RTCsec, //seconds of the real-time-clock
RTCmin, //minutes of the real-time-clock
RTChour; //hour of the real-time-clock
lcd_clear();
readTime(&RTCsec,&RTCmin,&RTChour);
displayTime(RTCsec,RTCmin,RTChour);
/***************Main Program Starts Here*************/
void main(){
char line1[25];
/*----------configure all the ports-------*/
Set_Tris_A(0x00); //set port A to outputs
Set_Tris_B(0x33); //make RB5, RB4(BUTTONS),
//RB1 (DQin) and RB0(pulse in) inputs
Set_Tris_C(0xD7); //RC7, RC6 (for Hserin/Hserout)
//RC4(RTC),RC2, RC1, RC0 inputs
Set_Tris_D(0x00); //set port D to outputs
Set_Tris_E(0x00); //set port E to outputs
PORTA = 0;
PORTB = 0;
PORTC = 0;
PORTD = 0;
PORTE = 0;
/*-----------set PIC registers------------*/
ADCON1=0b00001110;
//write to rtc
writeRTC(9, 56, 4, 24, 7,3); //starts the clock and sets
//sqw freq. to 4096Hz
SETUP_CCP1(CCP_COMPARE_RESET_TIMER);//set to reset TMR1
//set the compare reg. to generate
//a match at 2048 (every .5 sec)
//since the clock input is at 4096 Hz
SET_PWM1_DUTY(2048);
SETUP_TIMER_1(T1_EXTERNAL_SYNC|T1_DIV_BY_1); //external clock
SET_TIMER1(0); //start timer 1 counting at 0
CCP1_FLAG = 0; //clear the ccp flag
ENABLE_INTERRUPTS(INT_CCP1); //enable clock output interrupt
ENABLE_INTERRUPTS(GLOBAL);
delay_us(500);
lcd_clear();
strcpy(line1, "Interrupt Test"); // copy string
lcd_puts(line1);
}//end of main()
#define SCLpin PIN_C3
#define SDApin PIN_C4
#define SYNC PIN_C0
#define I2C1307W 0xD0 //the i2c control for writing to the rtc
#define I2C1307R 0xD1 //the i2c control for reading to the rtc
#define RTCCtrl 0x11 //this sets the clock output to 4096 per second
#use i2c(master,sda=SDApin, scl=SCLpin) //specific for the clock read and writes
/************convert2BCD*******************/
/*This function converts a two digit int */
/*to its BCD form. */
/*PARAMETERS: */
/* DEC - the integer to be */
/* converted */
/*RETURNS: */
/* BCD - the binary coded dec. */
/* format of DEC */
int convert2BCD(int DEC){
int BCD;
BCD = DEC/10; //get the first digit
BCD = BCD<<4;
BCD = BCD + (DEC\%10); //add the second digit
return BCD;
/************convert2BIN*******************/
/*This function converts a bcd number to */
/*its binary form. */
/*PARAMETERS: */
/* BCD - the number to be */
/* converted */
/*RETURNS: */
/* BIN - the binary form of the */
/* number */
int convert2BIN(int BCD){
int BIN;
BIN=((BCD>>4)&0x0f)*10+(BCD&0x0f);
return BIN;
/************writeRTC**********************/
/*This function writes the specified time */
/*and date to the rtc */
/*PARAMETERS: */
/* seconds - seconds of the rtc */
/* minutes - minutes of the rtc */
/* hours - hours of the rtc */
/* days - date of the rtc */
/* month - month of the rtc */
/* year - the year of the rtc */
/* (0=
/*RETURNS: */
void writeRTC(int seconds, int minutes, int hours, int days, int month,
int year) {
//convert everything to BCD before writing to the clock
seconds = convert2BCD(seconds);
minutes = convert2BCD(minutes);
hours = convert2BCD(hours);
days = convert2BCD(days);
month = convert2BCD(month);
year = convert2BCD(year);
disable_interrupts(GLOBAL);
I2C_start();
I2C_write(I2C1307W);
I2C_write(0x00); //starting address (the seconds register)
I2C_write(seconds); //write the seconds
I2C_write(minutes); //write the minutes
I2C_write(hours); //write the hours
I2C_write(0x00); //this is the weekday, but we don't use it
I2C_write(days); //write the date
I2C_write(month); //write the month
I2C_write(year); //write the year
I2C_write(RTCctrl); //write the control register
I2C_stop();
/************readTime**********************/
/*This function reads the seconds, minutes*/
/*and hours from the rtc */
/*PARAMETERS: */
/* sec - seconds of the rtc */
/* min - minutes of the rtc */
/* hour - hours of the rtc */
/*RETURNS: */
void readTime(int * sec, int * min, int * hour){
I2C_Start();
I2C_Start();
I2C_write(I2C1307R);
* sec=I2C_read(); //read the seconds
* min=I2C_read(); //read the minutes
* hour=I2C_read(0); //read the hours
I2C_stop();
/************displayTime*******************/
/*This function displays the time on the */
/*lcd screen */
/*PARAMETERS: */
/* sec - seconds to be displayed */
/* min - minutes to be displayed */
/* hour - hours to be displayed */
/*RETURNS: */
void displayTime(int sec, int min, int hour){
int RTCsec,RTCmin,RTChour;
char string[7], seconds[3], minutes[3], hours[3], colon[2];
//convert time to binary
RTCsec=convert2BIN(sec);
RTCmin=convert2BIN(min);
RTChour=convert2BIN(hour);
//convert numeric values to strings
sprintf(seconds,"\%d",RTCsec);
sprintf(minutes,"\%d",RTCmin);
sprintf(hours,"\%d",RTChour);
strcpy(string, "Time "); // copy string
strcpy(colon, ":");
//display on LCD
lcd_clear();
lcd_puts(string);
lcd_puts(hours);
lcd_puts(colon);
lcd_puts(minutes);
lcd_puts(colon);
lcd_puts(seconds);
Thank you,
Emily
___________________________
Original Post ID: 144516786 |
Re: ccp1 interrupt still not working |
Posted: Fri Aug 08, 2003 2:19 pm |
:=Hello,
:=I cannot get the ccp1 interrupt to work. I am trying to get an interrupt every 0.5sec. I have an external clock input of 4096Hz, so I want timer1 to create a match at 2048. This is what I've tried to set up, but the interrupt routine is never triggered.
:=SETUP_CCP1(CCP_COMPARE_RESET_TIMER);//set to reset TMR1
:=SET_PWM1_DUTY(2048);
I don't think you should use the SET_PWM1_DUTY(2048) function
to setup the period. It doesn't write to the CCPR1H register.
So do the following:
Put these two lines above main():
#byte CCPR1L = 0x15
#byte CCPR1H = 0x16
Then comment out the SET_PWM1_DUTY(2048) line, and substitute
these two lines instead:
CCPR1L = 0;
CCPR1H = 0x08;
//SET_PWM1_DUTY(2048);
This will set the 16-bit CCPR1 register to 0x0800, which is
2048. Now at least you will have the CCPR1 register set to
the correct value. I don't know if this will make your whole
program work, but you'll be closer to making it work.
Original Post ID: 144516844 |
