PeterD Guest
inttoascii or hextoascii function? |
Posted: Mon Dec 16, 2002 9:17 am |
Does anyone know where I can find an inttoascii or hextoascii function?
Original Post ID: 10065 |
R.J.Hamlett Guest
Re: inttoascii or hextoascii function? |
Posted: Mon Dec 16, 2002 9:43 am |
:=Does anyone know where I can find an inttoascii or hextoascii function?
sprintf
For your requirements:
char output[5];
sprintf(output,"\%D",value_to_convert);
Will put into the string 'output', the ASCII equivalent of the number in 'value_to_convert'. Using '\%ld', instead of '\%D', will allow a long integer to be sent. With this the output could be seven digits 'wide' ('-' sign, 5 digits, and the terminating '\0'), so the array would need to be larger.
Original Post ID: 10066 |
Dave Yeatman Guest
Posted: Mon Dec 16, 2002 4:07 pm |
Depending on what you are doing, converting individual numbers is easy. This would be the building block for whatever you want to do.
If a decimal digit simply add 48 to make it the ascii equivalent.
For hex:
If <=9 then add 0x30, else add 0x37.
I created a function that I call with the digit to convert and it returns a char. I also pass a boolean flag "hex" to tell whether to convert hex or decimal. Once created, the routine works everywhere and you can paste it into any code.
Example protoype:
char convert(byte digit, boolean hex)
Good Luck!
Dave
Original Post ID: 10078 |
