Does anyone know of an I2C UART I can use to implmement a second UART. My throughput is too heavy to use a software UART.
___________________________
Original Post ID: 144516834
kender_a Guest
Re: Second UART needed on 877
Posted: Fri Aug 08, 2003 12:41 pm
I was looking for an I2C UART too. Such thing does not exist. But here are the two other options.
1. MAX3100 - SPI UART
2. PIC16F818 - it can be an I2C slave, and it has an internal UART. So it can act as an I2C UART (and may be do some other useful things).
Good luck,
Nick
Original Post ID: 144516836
Neutone
Posted: Fri Aug 08, 2003 12:42 pm
:=Does anyone know of an I2C UART I can use to implmement a second UART. My throughput is too heavy to use a software UART.
It has been a while since I have done I2C but I think that performing software bit shifting on a pin can be interupted to service a hardware interupt(uart) and still resume the I2C communications without a fault. The bit time while servicing an interupt would be long but that should still work. Also depending on the speed supported by the slave device a software solution could be faster.
Original Post ID: 144516838
