I'm using a pic 16f76, and I get the error "out of Rom , a segment is too large" My program use a main function that call
4 funtions, but the last funtion calls several functions. I have
put #SEPARATE in several functions declaration of the program but the error "out of rom" does not desapeare.
the main code is:
BYTE i;
init();
// MANDAMOS UN AT AL MODEM
while( 1 )
while ( serbuffout != serbuffin )
serbuffout ++;
if ( serbuffout > SERBUFFLEN)
serbuffout = 0;
while ( estado_llamada != CONECTADO)
selectDevice( MODEM_);
dial();
eject(); // here are several calls to small funtcions
Thank's in advanced
bye
___________________________
Original Post ID: 144516804
Re: out of rom error
Posted: Fri Aug 08, 2003 11:42 am
<font face="Courier New" size=-1>:=I'm using a pic 16f76, and I get the error "out of Rom , a segment is too large" My program use a main function that call
:=4 funtions, but the last funtion calls several functions. I have
:=put #SEPARATE in several functions declaration of the program but the error "out of rom" does not disappear.
It's possible that your program actually is too large for
the PIC. You should comment out the internal code in one
or more functions, until the program compiles without errors.
Then check the top of the .LST file (or the pop-up compiler
window) and see what percentage of ROM is used ? Is it 95\% ?
</font>
Original Post ID: 144516828
