MONTECCHI lUCA Guest
| Problem with i2c eeprom.. help me... |
Posted: Sun Jan 12, 2003 6:15 am |
Hi..
I have a problem..
I would like read and write from 16f84 to 24cxx,but I have some problem..
I define the pin for SCL and SDA, and i have use the CCS's driver, but when I use the function read_ext or write_ext in any address, dont write and dont read from Serial eeprom..
Why?
Anyone can help me?
THX!
Original Post ID: 10624 |
Tomi Guest
| Re: Problem with i2c eeprom.. help me... |
Posted: Sun Jan 12, 2003 9:23 am |
1. Do you have pullup resistors on both SCL and SDA?
2. Did you call init_ext_eeprom() from your early main() ?
:=Hi..
:=I have a problem..
:=I would like read and write from 16f84 to 24cxx,but I have some problem..
:=I define the pin for SCL and SDA, and i have use the CCS's driver, but when I use the function read_ext or write_ext in any address, dont write and dont read from Serial eeprom..
:=Why?
:=Anyone can help me?
:=THX!
Original Post ID: 10629 |
Posted: Sun Jan 12, 2003 4:10 pm |
:=Hi..
What compiler are you using ? CCS or CC5x ?
Original Post ID: 10632 |
Posted: Mon Jan 13, 2003 3:08 am |
I use CCS but isn't a last version, is 3.048.
Yes,I call init_ext,but I have connect SDA and SCL to RB7 RB6 without pull-up resistor.. Is this the problem? I must use a 10k resistor?
Original Post ID: 10638 |
Posted: Mon Jan 13, 2003 3:10 am |
CCS,but isn't last version. is 3.048
Original Post ID: 10639 |
Tomi Guest
Posted: Mon Jan 13, 2003 3:39 am |
Yes, you have to use 2.2kOhm or same because those pins are floating.
:=I use CCS but isn't a last version, is 3.048.
:=Yes,I call init_ext,but I have connect SDA and SCL to RB7 RB6 without pull-up resistor.. Is this the problem? I must use a 10k resistor?
Original Post ID: 10640 |
R.J.Hamlett Guest
Posted: Mon Jan 13, 2003 3:47 am |
Yes. I2C, is defined as an 'open collector' drive bus. The chips, provide no 'pull up', and resistors are _required_. The actual value needed will depend on the capacitance of the lines, and the speed required. Normally a value between about 2.2K, and 4.7K, is typical. The bus 'idles' with the lines high, so power is only drawn through the resistors when data is being teansmitted. Without these, the bus will not work.
Original Post ID: 10642 |
| THANKS FOR ALL!! Now read and write OK!! |
Posted: Tue Jan 14, 2003 1:40 am |
THANKS FOR ALL!!
Original Post ID: 10674 |
