As I have not yet tried this but will in the next day or so I'd thought to try the forum...
I presume that the KBD.C routine is useable within a INT_TIMER1 service routine. To be implemented on a F877 device running at 20MHz with a timer interrupt every 20mS.
If anyone has any good ideas or thoughts, I'd be happy to hear them else i'll let you know how it went.
___________________________
Original Post ID: 144516458
Mark
Re: Using kbd.c within a INT_TIMER1 routine
Posted: Tue Jul 29, 2003 10:14 am
ISR's should be as short as possible. It is best to set a flag in the ISR and then check the flag in the main loop.
Regards,
Mark
:=As I have not yet tried this but will in the next day or so I'd thought to try the forum...
:=I presume that the KBD.C routine is useable within a INT_TIMER1 service routine. To be implemented on a F877 device running at 20MHz with a timer interrupt every 20mS.
:=If anyone has any good ideas or thoughts, I'd be happy to hear them else i'll let you know how it went.
Original Post ID: 144516471
