Sampling at 8kHz
Morgan
Sampling at 8kHz
PostPosted: Sat Jul 26, 2003 9:47 am     Reply with quote
Hi
I'm using a 20MHz clock on a Pic16F876 and need to sample analog input (sound) at exactly 8kHz. I know I have to use the timer interrupt as I want to do other stuff while I'm waiting, but don't know how to do this. Would appreciate it if anybody could help me.
Thanx
___________________________
Original Post ID: 144516386
R.J.Hamlett
Re: Sampling at 8kHz
PostPosted: Sat Jul 26, 2003 2:53 pm     Reply with quote
:=Hi
:=I'm using a 20MHz clock on a Pic16F876 and need to sample analog input (sound) at exactly 8kHz. I know I have to use the timer interrupt as I want to do other stuff while I'm waiting, but don't know how to do this. Would appreciate it if anybody could help me.
:=Thanx
I'd suggest:
int16 ADvalue;
#INT_TIMER2
void T2INT(void) {
ADvalue=read_adc(ADC_READ_ONLY);
read_adc(ADC_START_ONLY);
In main:
setup_timer_2(T2_DIV_BY_1,125,5);
and obviously set the ADC to the required channel, and setup as required.
The timer will be called 20000000/(4*125*5) times per second, and immediately reads the ADC value, from the _last_ conversion, and triggers the next conversion. This way, the interrupt code, doesn't have to wait for the ADC hardware.
You will also have to set a flag in the interrupt, to tell the main code to store the number.
Original Post ID: 144516389
