bgpartri Guest
| Compiler Bug? |
Posted: Sun Jul 27, 2003 3:26 pm |
Is there some reason this code should hang? Am I missing something?
#include <18f452.h>
#include <math.h>
void main(void){
float number_log;
number_log = log(2.0);
number_log += 1;
I just put the second executable statement in there so I could single step somewhere. It turns out it isn't needed, because it never returns from the log function.
___________________________
Original Post ID: 144516407 |
bgpartri Guest
| Re: Compiler Bug? |
Posted: Sun Jul 27, 2003 5:24 pm |
The second include was supposed to be <math.h>.
Since my first post, I have found that exp doesn't work either.
:=Is there some reason this code should hang? Am I missing something?
:=#include <18f452.h>
:=#include <math.h>
:=void main(void){
:= float number_log;
:= number_log = log(2.0);
:= number_log += 1;
:=I just put the second executable statement in there so I could single step somewhere. It turns out it isn't needed, because it never returns from the log function.
Original Post ID: 144516408 |
bgpartri Guest
| Re: Compiler Bug? |
Posted: Sun Jul 27, 2003 5:27 pm |
Very interesting. I guess <-m-a-t-h-.-h-> gets processed by something along the way to the list.
:=The second include was supposed to be <math.h>.
:=Since my first post, I have found that exp doesn't work either.
:=:=Is there some reason this code should hang? Am I missing something?
:=:=#include <18f452.h>
:=:=#include <math.h>
:=:=void main(void){
:=:= float number_log;
:=:= number_log = log(2.0);
:=:= number_log += 1;
:=:=I just put the second executable statement in there so I could single step somewhere. It turns out it isn't needed, because it never returns from the log function.
Original Post ID: 144516409 |
Mark
| Re: Compiler Bug? |
Posted: Sun Jul 27, 2003 8:24 pm |
You should add a while(1) to keep the processor from going to sleep.
:=Very interesting. I guess <-m-a-t-h-.-h-> gets processed by something along the way to the list.
:=:=The second include was supposed to be <math.h>.
:=:=Since my first post, I have found that exp doesn't work either.
:=:=:=Is there some reason this code should hang? Am I missing something?
:=:=:=#include <18f452.h>
:=:=:=#include <math.h>
:=:=:=void main(void){
:=:=:= float number_log;
:=:=:= number_log = log(2.0);
:=:=:= number_log += 1;
:=:=:=I just put the second executable statement in there so I could single step somewhere. It turns out it isn't needed, because it never returns from the log function.
Original Post ID: 144516413 |
bgpartri Guest
| Re: Compiler Bug? |
Posted: Sun Jul 27, 2003 8:51 pm |
Thanks. I don't think I would ever have figured that out.
I was still stumped for a while about why my real program still didn't work. I was not programming enough memory. For whatever reason, MPLAB didn't give me an error. It was falling off the end of the program in some way. That program did have a while(TRUE); at the end.
Anyway, its fixed now.
:=You should add a while(1) to keep the processor from going to sleep.
:=:=Very interesting. I guess <-m-a-t-h-.-h-> gets processed by something along the way to the list.
:=:=:=The second include was supposed to be <math.h>.
:=:=:=Since my first post, I have found that exp doesn't work either.
:=:=:=:=Is there some reason this code should hang? Am I missing something?
:=:=:=:=#include <18f452.h>
:=:=:=:=#include <math.h>
:=:=:=:=void main(void){
:=:=:=:= float number_log;
:=:=:=:= number_log = log(2.0);
:=:=:=:= number_log += 1;
:=while(1);
:=:=:=:=I just put the second executable statement in there so I could single step somewhere. It turns out it isn't needed, because it never returns from the log function.
Original Post ID: 144516415 |
