Pass Variable's Data to OUTPUT_X() Function
tcwong3
PostPosted: Mon Jul 21, 2003 9:06 pm     Reply with quote
How to pass data of an 8 bits register to the
output_x() function?
___________________________
Original Post ID: 144516240
R J Hamlett
Re: Pass Variable's Data to OUTPUT_X() Function
PostPosted: Tue Jul 22, 2003 7:07 am     Reply with quote
:=How to pass data of an 8 bits register to the
:=output_x() function?
I presume you mean that you want to read a value from one of the 'internal' registers, rather than just a normal variable?.
In the latter case:
output_x(variable_name);
In the former case:
#byte name=address
Where 'name' is the name you want ro use to 'talk' to this register, and 'address' is the address of the register in memory.
Then:
output_x(name);
Will read the value at 'address', and output this to the port.
Original Post ID: 144516243
