How can I reserve a specific memory location?
chingB
PostPosted: Thu Mar 18, 2004 5:13 pm     Reply with quote
Anybody has an idea of how can I reserver a specific location of the on-chip program memory?
Does CCS has a built-in function for reading/writing the on-chip program memory?
Any comments and suggestions?
Thank you.
Haplo
PostPosted: Thu Mar 18, 2004 5:49 pm     Reply with quote
To reserve location you can use #org. Quoting from the manual: Follow the ORG with a {} to only reserve the area with nothing inserted by the compiler. You may want to take a look at #ROM too.
To read/write the on-chip program memory you can use the read_program_eeprom()/write_program_eeprom () functions.
PostPosted: Thu Mar 18, 2004 10:31 pm     Reply with quote
How many clock cycles does it takes for a read_program_eeprom() and write_program_eeprom()?
Haplo
PostPosted: Fri Mar 19, 2004 12:10 am     Reply with quote
Judging by the code generated in the .LST file, on a PIC16F87x read_program_eeprom() takes around 20 instruction cycles and write_program_eeprom() takes around 40 instruction cycles to finish.
