i2c failure above 32k address
Lance Zaklan
PostPosted: Thu Jan 09, 2003 2:32 am     Reply with quote
I'm using an 18F452 with a 64k of flash memory accessed by the i2c bus. I can access addresses below 32k, but not above. When I attempt to access an address above 32k, i an access of the address - 32k.
compiler version is: 3.127
Here's the "open" routine to setup for the read.
#define WORD unsigned long // Data type definitions
#define EEROM_ADDR 0xa0 // i2c addr for external EEROM
void
open_file(WORD start, WORD offset, BYTE writeAccess)
offset += start;
i2c_start();
i2c_write(EEROM_ADDR); // Write start pointer to eerom
//set ms byte of address
i2c_write(offset >> 8);
//set ls bits of address
// by trunction during argument pass
i2c_write(offset);
// if not write, must be read, so restart as read
if (!writeAccess)
i2c_stop();
i2c_start();
i2c_write(EEROM_ADDR | 1); // set for reads
The code invokes the
open_file(32768, 0, READ_ACCESS);
data = i2c_read();
The address read will be at 0.
thanks
lance
(slz)
___________________________
Original Post ID: 10553
Tomi
Re: i2c failure above 32k address
PostPosted: Thu Jan 09, 2003 4:05 am     Reply with quote
<font face="Courier New" size=-1>What is the type of your 64k memory?
If it is a 24LC515 then keep in mind that it is divided onto two 32k parts. The first part is accessed at address 0xA0 and the 2nd part's I2C address is 0xA8.
:=I'm using an 18F452 with a 64k of flash memory accessed by the i2c bus. I can access addresses below 32k, but not above. When I attempt to access an address above 32k, i an access of the address - 32k.
:=compiler version is: 3.127
:=Here's the "open" routine to setup for the read.
:=#define WORD unsigned long // Data type definitions
:=#define EEROM_ADDR 0xa0 // i2c addr for external EEROM
:=void
:=open_file(WORD start, WORD offset, BYTE writeAccess)
:= offset += start;
:= i2c_start();
:= i2c_write(EEROM_ADDR); // Write start pointer to eerom
:= //set ms byte of address
:= i2c_write(offset >> 8);
:= //set ls bits of address
:= // by trunction during argument pass
:= i2c_write(offset);
:= // if not write, must be read, so restart as read
:= if (!writeAccess)
:= i2c_stop();
:= i2c_start();
:= i2c_write(EEROM_ADDR | 1); // set for reads
:=The code invokes the
:=open_file(32768, 0, READ_ACCESS);
:=data = i2c_read();
:=The address read will be at 0.
:=thanks
:=lance
:=(slz)</font>
Original Post ID: 10554
Lance Zaklan
PostPosted: Thu Jan 09, 2003 2:04 pm     Reply with quote
yes. that's it. thank you
lance
:=<font face="Courier New" size=-1>What is the type of your 64k memory?
:=If it is a 24LC515 then keep in mind that it is divided onto two 32k parts. The first part is accessed at address 0xA0 and the 2nd part's I2C address is 0xA8.
:=:=I'm using an 18F452 with a 64k of flash memory accessed by the i2c bus. I can access addresses below 32k, but not above. When I attempt to access an address above 32k, i an access of the address - 32k.
:=:=compiler version is: 3.127
:=:=Here's the "open" routine to setup for the read.
:=:=#define WORD unsigned long // Data type definitions
:=:=#define EEROM_ADDR 0xa0 // i2c addr for external EEROM
:=:=void
:=:=open_file(WORD start, WORD offset, BYTE writeAccess)
:=:= offset += start;
:=:= i2c_start();
:=:= i2c_write(EEROM_ADDR); // Write start pointer to eerom
:=:= //set ms byte of address
:=:= i2c_write(offset >> 8);
:=:= //set ls bits of address
:=:= // by trunction during argument pass
:=:= i2c_write(offset);
:=:= // if not write, must be read, so restart as read
:=:= if (!writeAccess)
:=:= i2c_stop();
:=:= i2c_start();
:=:= i2c_write(EEROM_ADDR | 1); // set for reads
:=:=The code invokes the
:=:=open_file(32768, 0, READ_ACCESS);
:=:=data = i2c_read();
:=:=The address read will be at 0.
:=:=thanks
:=:=lance
:=:=(slz)</font>
Original Post ID: 10572
