icd-u64 PIC18LF26K22 firmware
Roberto da Rivoli
PostPosted: Fri Jan 31, 2025 2:07 am     Reply with quote
Help, on my ICD-U64 REV3 I burned the micro PIC18LF26K22. Now I replaced it and I need the firmware to load on it, who can send it to me, thanks
PostPosted: Fri Jan 31, 2025 2:57 am     Reply with quote
Er. Not clear what you are asking for?????
The firmware for the PIC18FH26K22, is _your_ program. Will differ for
every job. There is no universal firmware for the chip.
There are probably 20000 different sets of firmware in use and owned by the
posters here. You need to ask whoever wrote the original code you were
using.
Your question is a bit like "I have a book, send me the words to put in it".....
Roberto da Rivoli
PostPosted: Fri Jan 31, 2025 5:14 am     Reply with quote
I probably explained myself badly!
I burned the internal microcontroller in the ICD-U64, I'm asking for the emulator firmware
dyeatman
PostPosted: Fri Jan 31, 2025 6:39 am     Reply with quote
The ICD firmware comes with the compiler. Normally you will find the it
in the PICC directory with a name similar to "icd-images-firmware-03-61.fw".
This file is for all versions for the ICD.
If you don't have it you will have to ask CCS for it.
Google and Forum Search are some of your best tools!!!!
PostPosted: Fri Jan 31, 2025 8:09 am     Reply with quote
I think you would have to have CCS replace the chip.
He is after the internal firmware for the ICD-U64. The runtime parts of
this come with software updates with CCSLoad, but if he has destroyed
the chip he won't have the bootloader part that is in the chip to load these.
Since these are proprietary to CCS I doubt if they will supply them. Also
(of course), he will need another programmer to actually put this in.
Roberto da Rivoli
PostPosted: Fri Jan 31, 2025 9:06 am     Reply with quote
If CCS sends me the file to upload, there will be no problem finding another programmer to upload it.
Roberto da Rivoli
PostPosted: Fri Jan 31, 2025 9:59 am     Reply with quote
SOLVED
THANKS to CCS support
PostPosted: Fri Jan 31, 2025 10:00 am     Reply with quote
Well done CCS. Glad they were prepared to supply this.
