allenhuffman
Joined: 17 Jun 2019 Posts: 612 Location: Des Moines, Iowa, USA
CCSC.exe/CCSCOMPILE.exe passing in #defines as quoted string |
Posted: Thu Jan 30, 2025 4:57 pm |
When command line compiling, the manual says you can use
...to set a global define. We use this and it works, for lables, numbers and even single quoted characters:
Code: | #BOARD=CONTROL #DEBUG=1 PARTITION='A' |
But I had wanted to pass in something like this...
Code: | #if !defined(VERSION_METADATA)
#define VERSION_METADATA "-Bootloader"
#endif |
But trying to do
Code: | #VERSION_METADATA="-OtherThing" |
...does not work. It is passed in without quotes around it and just creates a compile error.
The manual also lists an alternative:
...but that does the same thing. Actually, it's a bit different. It I try to pass in "-Bootloader" using #, it effectively ends up like:
Code: | #define VERSION_METADATA -Bootloader |
...with no quotes around it. Using the +GVERSION_METADATA="-Bootloader" will end up in UPPERCASE like:
Code: | #define VERSION_METADATA -BOOTLOADER |
I have no idea why.
The usual escapes like \"String\" do not work.
Support said double quotes should work, but they do not.
Anyone figured out how to do this? _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002. |
allenhuffman
Posted: Thu Jan 30, 2025 4:58 pm |
Also, order on the compile line seems to matter. You can have them before the BUILD=, but when I put one after it I got weird compiler errors. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
