allenhuffman
Joined: 17 Jun 2019 Posts: 617 Location: Des Moines, Iowa, USA
CCSC.exe error code list? |
Posted: Fri Jan 17, 2025 9:02 am |
I have a DOS batch file I use to build a few dozen .hex files for various boards (app partitions, bootloaders, factory images that have it all combined, etc.). I use the CCSC.exe command line options.
I wanted the script to stop and report errors, and was pleased to see CCSC does return values:
Code: | CCSC #COMPILE_PARTITION='A' #BOARD=%BOARD_DEFINE% #BUILD_FOR_BOOTLOADER=1 #INCLUDE_BOOTLOADER=1 I="%INCLUDES%" BUILD=%PROJECT%.ccspjt
if %ERRORLEVEL% neq 1 (
echo The program returned an error with exit code %ERRORLEVEL%.
pause
I was checking the help looking for a list of these codes and didn't find it. Is there a listing somewhere?
I didn't see it in the PDF manual either, but I assume it is there and I am just not searching for what they call them. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002. |
Joined: 01 Jul 2010 Posts: 9429 Location: Greensville,Ontario
Posted: Fri Jan 17, 2025 9:20 am |
when I'm 'lost', I just ask the 'source'......
maybe there's a something.txt file with them ?? |
Posted: Fri Jan 17, 2025 9:23 am |
I don't know if this is exhaustive or not, but when I open up PCWHD and use the help dialog: In the "Search" tab, I searched for: errror
some of the results were of the format like e10003, etc. Those were specific error codes. There was also a section titled "Error Messages" which a lot of information (though I didn't catch any error codes there).
You might try sending them an email and seeing if they can provide a list. |
Posted: Sun Jan 19, 2025 3:00 am |
There are actually three different error code types that you can get.
CCS C itself is written in Delphi, and so some of the codes are the Delphi
codes for things line 'file not found' etc..
Then C itself has a few codes that are standardised, and CCS keeps to these
if applicable, However lots of these don't exist in the limited environment of
the PIC.
Then you have the CCS specific ones. These are the exxxx ones, and most
are listed in the manual. |
