PIC24F Series 64-bit data handling Problem
Mrinmoy
View user's profile Send private message Send e-mail AIM Address
PostPosted: Wed Nov 13, 2024 3:29 am     Reply with quote
I am using PIC24FJ512GU406 in one of my project and my CCS compiler version is V-5.101.
    unsigned int64   g_ui64TestTemp = 1270000;
    unsigned int64   g_ui64WtSum = 0;
    for(g_stADCDataQ.m_i16Rear = 0; g_stADCDataQ.m_i16Rear < 4196; g_stADCDataQ.m_i16Rear++)
        g_ui64WtSum = g_ui64WtSum + g_ui64TestTemp;
This is a sample code that I have tried and in my actual application the same thing I have to implement. But in both cases I have seen that the Sum variable can not contain data that cross 32-bit; i.e. the answer should come 5328920000 but actually it comes 1033952704. If I down the range from 4196 to 2048 or something nearby then the sum value comes accurate which is within 32-bit range.
Can anyone please help me about this. Its urgent.
Thanks in Advance.
PostPosted: Wed Nov 13, 2024 6:09 am     Reply with quote
How are you seeing this?. If using an IDE, you need to be very careful of
how it thinks the data is declared. MPLAB has problems with this.
This was described here:
[url]
http://www.ccsinfo.com/forum/viewtopic.php?t=60057&highlight=int64
[/url]
PostPosted: Wed Nov 13, 2024 6:35 am     Reply with quote
I just cut your code down to a mini test version, and ran it on your compiler
version:
#include <main64.h> //processor clock etc..
    int16 g_stADCDataQ;
    char result[32];
    for(g_stADCDataQ = 0; g_stADCDataQ < 4196; g_stADCDataQ++)
    sprintf(result, "%lu", g_ui64WtSum);
       delay_cycles(1);
and 'result' contains 5228920000
It works fine.
Whatever you are doing with this afterwards, or how you are displaying it,
is where the 32bit limitation is appearing.
Mrinmoy
PostPosted: Thu Nov 14, 2024 12:04 am     Reply with quote
Yes. You are right.
This limitation has MPLAB IDE itself, but internally it is working perfectly.
You just show a good way to handle such problems that I learned.
Thanks for support.
