benoitstjean
Joined: 30 Oct 2007 Posts: 553 Location: Ottawa, Ontario, Canada
PIC24EP - Generate 16kHz from a short-sync 8kHz interrupt |
Posted: Mon Apr 29, 2024 8:00 am |
Device: PIC24EP512GP806
Compiler: 5.116
Good day all,
Scenario: I want to interface a PDM microphone to a modem. The modem accepts only 16-bit PCM audio and it's the modem that must generate the clocking because that's how it works as per the manufacturer, there's no other way around that. Currently, the modem generates a 2.048MHz 50% PWM and an 8kHz short-sync clock to a CODEC. On the CODEC's front-end, I have an analog microphone. With the modem's clocks to the CODEC, the CODEC outputs a 16-bit audio stream to the modem. This is currently working over the cell network. Now, what I want to do is eliminate the CODEC and the analog mic and connect a PDM mic to the modem. This requires interfacing with an ADAU7002 PDM to PCM converter (as I have indicated in a previous post) and for sure, will require my PIC24.
The ADAU7002 is on a dev board, the modem frequencies are giving me some grief and many constraints need to be followed:
- My setup must use the modem's 2.048MHz and do something with the 8kHz short sync.
- The ADAU7002 requires a minimum BCLK of 256kHz with a minimum 64:1 ratio with the LRCLK. The ratio is automatically calculated by the IC and the LRCLK must be minimum 4Khz (64x 4kHz = 256kHz). The ADAU7002 takes ratios of 64, 128, 192, 256, 384 and 512.
- The combination of BCLK and LRCLK is what will generate the PDM clock on the PDM side of the ADAU7002 which will then send it to the microphone and in return, the microphone will send its PDM audio to the ADAU7002's PDM input after which it will convert it to a 20-bit PCM audio stream. I'll deal with the 20-bit to 16-bit down-sampling later.
- The microphone's PDM clock can only run between 600kHz and 3.3MHz therefore the modem's 2.048MHz is perfect for that.
- The PDM clock out of the ADAU7002 is fixed at 64x the LRCLK input's clock (not to confuse with the BCLK:LRCLK ratio described above with multiple ratios.... this is the LRCLK:PDMCLK ratio and is fixed to 64).
- The ADAU7002's BCLK will be the modem's 2.048MHz and in order to have a valid ratio that will also work with the PDM microphone's constraints, I have only two options considering that the BCLK will be the modem's 2.048MHz:
1) An LRCLK of 16kHz for a 128:1 ratio --> 16,000 x 128 = 2,048,000 BCLK --> will generate a 1.024MHz PDM clock
2) LRCLK of 32kHz for a 64:1 ratio ---> 32,000 x 64 = 2,048,000 BCLK --> will generate a 2.048MHz PDM clock
- Lastly, the only other clock I have available that is synched with the 2.048MHz is the 8kHz.
Somehow, I guess I need to send that 8kHz short synch pulse to the PIC probably as an interrupt-on-change and from that, I need to generate a 50% 16kHz or 32kHz clock in order to be within the constraints.... now my question is: any idea on how to do that?!
Sorry for the long explanation for something that seems simple but the constraints I have are problematic and I wanted to give the whole picture to avoid the back and forth questions and assumptions.
Does all this make sense? Any idea?
Many thanks!
Ben |
Joined: 01 Jul 2010 Posts: 9160 Location: Greensville,Ontario
Posted: Mon Apr 29, 2024 9:11 am |
Ouch, my head hertz ! too many numbers, not enough coffee.....
OK, thinking outside the box....
Could you use a 'gluPIC' to do what you need ?
Some silly 8 pin,50 cent PIC that does the 'conversion/control/signalling' ?
benoitstjean
Posted: Mon Apr 29, 2024 9:19 am |
The PCB with the analog mic is already built and programming all done and all works. I soldered little wire-wrap wires on certain pins and just trying to figure-out how to convert short-sync 8kHz pulse to 16kHz 50% duty. |
gaugeguy
Posted: Mon Apr 29, 2024 12:51 pm |
It seems like you would need to use the 8kHz pulse to trigger a one-shot pulse and would go low for 31.25us and then go back high. |
benoitstjean
Posted: Mon Apr 29, 2024 1:09 pm |
Yep, that's also what I was thinking but I wasn't sure if a timer would be able to count such as low amount of ticks to make-up for 31.25uS.
I'll have to investigate this further.
Thanks for your input!
Ben |
