Help me 16 bit decimal convert to BCD code
thanhhavdt
View user's profile Send private message AIM Address Yahoo Messenger ICQ Number
PostPosted: Sat Apr 13, 2024 10:46 am     Reply with quote
Why not return BCD value in my program?
#include <16f887.h>
#device *=16
#device adc=10
#fuses nowdt,xt,noput,protect,nodebug,nobrownout,nolvp
//#include <internal_eeprom.c>
//#bit  ResetRom = 0x05.5 //RA5 (PIN 7)
#byte PORTA = 0x05
#byte PORTB = 0x06
#byte PORTC = 0x07
#byte PORTD = 0x08
#byte PORTE = 0x09
#byte TRISA = 0x85
#byte TRISB = 0x86
#byte TRISC = 0x87
#byte TRISD = 0x88
#byte TRISE = 0x89
#bit re0    =    0x09.0 // DS_PIN
#bit re1    =    0x09.1 //SHCP_PIN
#bit re2    =    0x09.2 //STCP_PIN
/* IC74HC595 */
#define SHCP_PIN  PIN_E1
#define DS_PIN   PIN_E0
#define STCP_PIN     PIN_E2
byte Lo_Data_DKX ;
byte Hi_Data_DKX ;
int16 a=10;
int16 b=0;
int16 c=0;
int16 d=0;
int16 Data_DKX = 0;
int16 Data_CHIA = 0;
int16 Data = 0;
void convert_data_DKX()
   Data_DKX = (((800*a)+(80*(b+25))+(8*c)+d));
   Data_CHIA = (Data_DKX)/2;
   Hi_Data_DKX = (unsigned char) ((((Data_CHIA / 1000) % 10) << 12) |(((Data_CHIA / 100) % 10) << 8) ) ;
   Lo_Data_DKX = (unsigned char) ((((Data_CHIA / 10) % 10) << 4) | (Data_CHIA % 10));
void IC_74hc595(int data)
int i;
output_low(SHCP_PIN);
for(i=0;i<=7;i++)
if((data & 0x80)==0)
{output_low(DS_PIN);
delay_us(50);}
output_high(DS_PIN);
data=data<<1;
output_high(SHCP_PIN);
void IC_74HC595_Output()
output_low(STCP_PIN);
delay_ms(50);
output_high(STCP_PIN);
void write_to_595 (byte Lo_Data_DKX, Hi_Data_DKX)
      IC_74hc595(Hi_Data_DKX);
      IC_74hc595(Lo_Data_DKX);
      IC_74HC595_Output();
void send_data_DKX()
   convert_data_DKX();
   write_to_595(Lo_Data_DKX, Hi_Data_DKX);
   TRISA=0x00;    //PortA as OUTPUT, RA5 as INPUT
   TRISB=0xFF;    //PortB as INPUT
   TRISC=0x00;    //PortC as OUTPUT
   TRISD=0xFF;    //PortD as INPUT
   TRISE=0x00;    //PortE as OUTPUT
   PORTC=0;  //
   PORTE=0;
 while(true)
      send_data_DKX();
PostPosted: Sun Apr 14, 2024 1:52 am     Reply with quote
First thing. Document, document, document.
We have no idea of what you are actually trying to do, and you yourself,
if you come back to this code in a few years time, will also have no idea
what it is meant to do. Documentation is your friend, and gives a place
to start. It also will often make obvious what is going wrong.....
Now, I'll make some comments in your routine, and this may help you
get a key to the problem:
   //Much better really to pass variables to the function rather than
   //using globals.
   //Now what on earth is this meant to do?. You are passing it four
   //int16 values 10, 0, 0, 0
   //so 10*800 = 8000
   //80*25 = 2000
   //result will be 10000.
   //Why the strange multiplication, and the addition of 25?????
   //Why over 2?. Now 5000. At least this can fit into four BCD
   //'digits'.
   //Now this looks as if you are trying to code this is binary
   //nibbles, not 'BCD' digits. So you possibly want:
   // 0b0101 0000 (0x 50)
   // 0b0000 0000 (0x 00)
   //Big problem here is your cast. You are generating the nibble into the
   //high byte of a 16bit value, then casting this to an unsigned char. At
   //this point the high byte is _thrown away_. You get just the low byte
   //result 00.........
   //Given you want only the high byte here:
   Hi_Data_DKX=(((Data_CHIA/1000) %10) <<4) + (Data_CHIA/100)%10;
   //Now this gives the 'thousands' moved to the high nibble of the
   //resulting byte, and the hundreds in the low nibble. Exactly what
   //is needed.
   //This is exactly what you code below, but doing the high two digits.
   //The problem was you were generating '0x 5000', then taking the
   //low byte of this result. Answer = 0, not 0x50.... :(
thanhhavdt
PostPosted: Sun Apr 14, 2024 8:57 am     Reply with quote
Thanks Ttelmah!!!
