I have a LoRa device that needs a unique 32 byte Appkey programmed in every unit. I managed to make this work with #serialize, the ICD-U80 and a file containing the keys. Kudos to CCS for having thought of this functionality albeit probably meant for serial numbers
Thinking about how I would do an upgrade in the field I tried to get this working with the Load N Go but that failed. Programming the .hex file in "Memory 1" with the keyfile available gets me a 'failed to write serial number"
error.
Is this at all possible?
Posted: Mon Mar 11, 2024 7:59 am
I suggest you ask CCS.
The #serialize option normally needs ccs_load. However they really should
offer a way to do this on the load'n'go, so if they don't, you need to
persuade them to add this!....
