[Solved] DS3231 and PIC16f628A
robo_z
PostPosted: Wed Jun 14, 2023 1:28 pm     Reply with quote
Hello i want show the time and date from a RTC DS3231, but i have problems for show correctly.
this is my code:
#include <16F628A.h>
#FUSES NOWDT
#FUSES PUT      //Power Up Timer
#FUSES NOMCLR   //Master Clear pin enabled
#FUSES BROWNOUT   //Reset when brownout detected
#FUSES NOLVP   //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES CPD      //Data EEPROM Code Protected
#FUSES PROTECT   //Code protected from reads
#use delay(internal=4MHz)
#use fast_io(A)
#use fast_io(B)
#define DS3231_INT   PIN_B0
#define DS3231_SDA   PIN_B1
#define DS3231_SCL   PIN_B2
#define PIN_TXD      PIN_B7
#use rs232(baud=9600, parity=N, xmit=PIN_TXD, rcv=0, bits=8, DISABLE_INTS, FORCE_SW, stream=SERIE)
#use i2c(MASTER, SDA=DS3231_SDA, SCL=DS3231_SCL, FAST=100000, STREAM=BUS_I2C)
const unsigned int DirDS3231 = 0xD0;
unsigned int Segundo, Minuto, Hora, Dia, Mes, Anio, Alarma1_Min, Alarma1_Hora, Alarma2_Min, Alarma2_Hora, Temperatura;
unsigned int Bcd2Dec(unsigned int MiBCD)
   return ( (MiBCD >> 4) * 10 + (MiBCD & 0x0F) );
unsigned int Dec2Bcd(unsigned int MiDEC)
   return ( ((MiDEC / 10) << 4) + (MiDEC % 10) );
void LeerDS3231(unsigned int DirReloj)
   i2c_start(BUS_I2C);                        // Inicia la Comunicaion I2C
     i2c_write(BUS_I2C, DirReloj);               // Escribimos la Direccion del DS3231
     i2c_write(BUS_I2C, 0x00);                  // Send register address (Registro Segundos)
     i2c_stop(BUS_I2C);                        // Detiene la Comunicaion I2C
     i2c_start(BUS_I2C);                        // Reiniciamos la Comunicacion I2C
     i2c_write(BUS_I2C, DirReloj | 0x01);         // Iniciamos la Lectura
     Segundo = Bcd2Dec(i2c_read(BUS_I2C, 1));      // Leemos Segundos Del Registro 0
     Minuto = Bcd2Dec(i2c_read(BUS_I2C, 1));         // Leemos Minutos Del Registro 1
     Hora = Bcd2Dec(i2c_read(BUS_I2C, 1));         // Leemos Hora Del Registro 2
     i2c_read(BUS_I2C, 1);                     // Saltamos el Registro 3 (Dia de la Semana)
     Dia = Bcd2Dec(i2c_read(BUS_I2C, 1));          // Leemos Fecha Del Registro 4
     Mes = Bcd2Dec(i2c_read(BUS_I2C, 1));         // Leemos Mes Del Registro 5
     Anio = Bcd2Dec(i2c_read(BUS_I2C, 1));         // Leemos Anio Del Registro 6
     i2c_read(BUS_I2C, 1);                     // Saltamos el Registro 7 (Alarma 1 Segundos)
     Alarma1_Min = Bcd2Dec(i2c_read(BUS_I2C, 1));   // Leemos Alarma 1 Minutos Del Registro 8
     Alarma1_Hora = Bcd2Dec(i2c_read(BUS_I2C, 1));   // Leemos Alarma 1 Horas Del Registro 9
     i2c_read(BUS_I2C, 1);                     // Saltamos el Registro 10 (Alarma 1 Fecha)
     Alarma2_Min = Bcd2Dec(i2c_read(BUS_I2C, 1));   // Leemos Alarma 2 Minutos Del Registro 11
     Alarma2_Hora = Bcd2Dec(i2c_read(BUS_I2C, 1));   // Leemos Alarma 2 Horas Del Registro 12
     i2c_read(BUS_I2C, 1);                     // Saltamos el Registro 13 (Alarma 2 Fecha)
     i2c_read(BUS_I2C, 1);                     // Saltamos el Registro 14 (Control)
     i2c_read(BUS_I2C, 1);                     // Saltamos el Registro 15 (Status)
     i2c_read(BUS_I2C, 1);                     // Saltamos el Registro 16 (Anging Offset)
     Temperatura = i2c_read(BUS_I2C, 1);            // Leemos Temperatura MSB Del Registro 17
   port_b_pullups(0x0F);
   set_tris_a(0x30);
   set_tris_b(0x09);
         LeerDS3231(DirDS3231);
      fprintf(SERIE, "Fecha:%02u/%02u/%02u Hora:%02u:%02u:%02u Temperatura:%02u\r", Dia, Mes, Anio, Hora, Minuto, Segundo, Temperatura);
but i get irregular data:
Fecha:14/06/23 Hora:14:22:33 Temperatura:00
Fecha:165/165/165 Hora:165:165:03 Temperatura:255
Fecha:14/06/23 Hora:14:22:33 Temperatura:32
how to solve this problem.
thanks for you help.
PostPosted: Wed Jun 14, 2023 4:34 pm     Reply with quote
hmm...what is the value of the I2C bus pullup resistors ?
do you have battery attached to the DS3231 ?
also add a 1 second delay in your loop..helps us humans to see better...
PostPosted: Wed Jun 14, 2023 5:00 pm     Reply with quote
You need to do a NACK on the last i2c_read operation.
You are doing an ACK.
ACK = 1
NACK = 0
robo_z
PostPosted: Wed Jun 14, 2023 5:01 pm     Reply with quote
thanks for you help
i solve add a not acknoledge at final of read.
     i2c_read(BUS_I2C, 1);                     // Saltamos el Registro 16 (Aging Offset)
     i2c_read(BUS_I2C, 0);                     // Saltamos el Registro 18 (Temperatura LSB) y Cerramos con NOT ACK
