andresteff
pic readout despite code protect because of x-ray radiation |
Posted: Thu Jun 08, 2023 9:18 am |
is there a possibility to read the flash from the PIC (PIC16F1619), despite code pritect?
I have irradiated a prototype with x-ray radiation. approx. 1-3 Gray/h.
After 2 minutes the PIC went off.
The 2 prototype worked. No failure.
Now I want to read out the memory to see if the program was disturbed by the radiation, or if there is a regular hardware bug. |
Joined: 01 Jul 2010 Posts: 9168 Location: Greensville,Ontario
Posted: Thu Jun 08, 2023 9:23 am |
Probably not... and now you know WHY you should not use 'code protect' until the HOUR you ship out the FINAL product.
I have to assume that Microchip has altered the 'code protection' methods since the 16C84 days. Those could be read even when 'protected'....
ah the good old days..... |
Posted: Thu Jun 08, 2023 9:28 am |
Basically no.
That is the whole point of protection.
However you can verify the memory, using a trick. If you program another
chip with the same code, and protection, then read it, the values you get
back should be the same as those from the irradiated chip if the memory
hasn't changed.
Some of the PIC's do say they use NOR flash. This is much less likely to
be affected by XRays than NAND flash. |
andresteff
Posted: Thu Jun 08, 2023 10:41 am |
Ttelmah wrote: | Basically no.
hasn't changed.
Apparently the debug bit was set!
I have compared the code, but I don't know what the two red differences mean. Debug bit, and....
Left side: Pic no failure. Right side, pic with failure
https://ibb.co/ZTX70LR |
andresteff
the pic can not be programmed. |
Posted: Thu Jun 08, 2023 11:04 am |
big.... |
Posted: Thu Jun 08, 2023 1:14 pm |
Remember if a chip has a protection bit set, it can only be programmed
after a full erase using full programming voltages, not LVP. |
andresteff
Posted: Fri Jun 09, 2023 1:16 am |
Ttelmah wrote: | Remember if a chip has a protection bit set, it can only be programmed
I can delete the pic.
but not program. Despite full progrmming voltage. NO LVP!
The PIC is broken.
Possibly it could also be EMC which is also emmitted by the x-ray radiation.
But I think it is the X-ray radiation. |
Posted: Fri Jun 09, 2023 1:45 am |
EMC is much more likely.
However that is why equipment in locations where it is likely to be exposed
to such problems has to be properly designed and protected.
I have some kit that is right adjacent to a couple of high power radiation
sources. They are inside lead Faraday cages. The connections for power
have multiple isolation and protection layers. Spark gap. EMC chokes.
Transorbs, then normal supply filtering and protection. |
