		| Author | Message |
		| isaac aiyanyo Guest
				| 1D to 2D array |
				|  Posted: Sun Dec 15, 2002 2:14 pm |   |
				| Hello pic c gurus i would be pleased if someone can help me out this
 problem.
 i am trying to convert the 1D array pat[32] to a
 2D array then send this to port b.
 this works perfectly as a 1D array so i need to change
 CHAR const pat[32] to a 2D array and also
 where port_b = pat[index] to port_b=pat[down][across];
 but the display don't work at all i have being trying
 to see where i am going wrong for a few nights with no joy
 so guys i do really need your help here.
 Thanks in advance
 Isaac
 (oo)
 /(____)\
 #include <16F876.H>
 #fuses HS,NOWDT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP
 #use delay(clock=20000000)
 #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,RESTART_WDT,ERRORS)
 #IFNDEF EXP_OUT_ENABLE
 #define Row 4
 #define Col 8
 #define EXP_OUT_ENABLE PIN_C2
 #define EXP_OUT_CLOCK PIN_C1
 #define EXP_OUT_DO PIN_C0
 #define NUMBER_OF_74595 4
 #ENDIF
 #include <74595.C>
 #byte port_a=5
 #byte port_b=6
 #byte port_c=7
 char const pat[Row][Col]={
 //CHAR const pat[32]    =  {
 0,0xfc,0xfe,0x33,0x33,0xfe,0xfe,0, /* Fort A*/
 0,0xff,0xff,0xdb,0xdb,0xff,0x66,0, /* Font B*/
 0,0x7e,0xff,0xc3,0xc3,0xc3,0xc3,0, /* Font C*/
 0,0xff,0xff,0xc3,0xc3,0xff,0x7e,0, /* Font D*/
 main()              // array holds the character maps for ABCD which scrolls//
 int mask[4];
 int data[4];				 // array to store our data since i am
 int delaycount;
 int startposition;
 int index;
 int i,nelly;
 int down,across;
 set_tris_c(0);
 set_tris_b(0);
 port_c = 0;
 port_b = 0;
 startposition = 0;
 delaycount = 3; 				// adjust this value to control scrolls speed
 while (delaycount)
 index = startposition;
 mask[0]=0x01;				// Initialize our mask
 mask[1]=0x00;
 mask[2]=0x00;
 mask[3]=0x00;
 for (i=0; i<32; i++) 	        	// we have 32 columns to drive
 // store our mask in an array. we need to do this because
 // the call to write_expanded_outputs will destroy the value
 // passed in.
 data[0] = mask[0]; 		// store which column we are driving
 data[1] = mask[1];	 	// in an array
 data[2] = mask[2];
 data[3] = mask[3];
 index = i + startposition; 	// point to the next pattern to display
 if (index >= sizeof(pat)) 	// make sure that we don't exceed the array
 index -= sizeof(pat);
 port_b = 0; 			// disable driving the LEDs
 write_expanded_outputs(data); 	// enable our column driver
 //	port_b = pat[index]; 		// drive our LEDs
 nelly=i\%8;
 for(down=0;down<Row;down++)
 for (across =0;across
 printf("\%x",pat[down][across]);
 //printf("\%x",pat[index],"\r\n");
 if (shift_left(mask,4,0))
 mask[0] = 0x01;
 // shift to the next column for next time
 delay_us(700); 			// adjust this value to control the drive time
 //for the leds
 --delaycount; 				// decrement our delay loop counter
 ++startposition; 					// Point to the next data pattern
 if (startposition >= sizeof(pat)) 			// make sure that we don't exceed the array
 startposition = 0;
 Original Post ID: 10055
		| isaac aiyanyo Guest
				| Re: 1D to 2D array (sorted) |
				|  Posted: Sun Dec 15, 2002 3:59 pm |   |
				| I have managed to get the display to work now but i still now help in making it scroll
 the scroll don't work anymore so if you have any
 suggestions it would be highly welcomed
 :=   Thanks in advance
 :=   Isaac
 :=   (oo)
 := /(____)\
 :=#include <16F876.H>
 :=#fuses HS,NOWDT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP
 :=#use delay(clock=20000000)
 :=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,RESTART_WDT,ERRORS)
 :=#IFNDEF EXP_OUT_ENABLE
 :=#define Row 4
 :=#define Col 8
 :=#define EXP_OUT_ENABLE PIN_C2
 :=#define EXP_OUT_CLOCK PIN_C1
 :=#define EXP_OUT_DO PIN_C0
 :=#define NUMBER_OF_74595 4
 :=#ENDIF
 :=#include <74595.C>
 :=#byte port_a=5
 :=#byte port_b=6
 :=#byte port_c=7
 :=char const pat[Row][Col]={
 :=//CHAR const pat[32]    =  {
 :=		    0,0xfc,0xfe,0x33,0x33,0xfe,0xfe,0, /* Fort A*/
 :=		    0,0xff,0xff,0xdb,0xdb,0xff,0x66,0, /* Font B*/
 :=		    0,0x7e,0xff,0xc3,0xc3,0xc3,0xc3,0, /* Font C*/
 :=		    0,0xff,0xff,0xc3,0xc3,0xff,0x7e,0, /* Font D*/
 :=main()              // array holds the character maps for ABCD which scrolls//
 :=int mask[4];
 :=int data[4];				 // array to store our data since i am
 :=int delaycount;
 :=int startposition;
 :=int index;
 :=int i,nelly;
 :=int down,across;
 :=set_tris_c(0);
 :=set_tris_b(0);
 :=port_c = 0;
 :=port_b = 0;
 :=startposition = 0;
 :=while(1)
 :=		delaycount = 3; 				// adjust this value to control scrolls speed
 :=		while (delaycount)
 :=			index = startposition;
 :=			mask[0]=0x01;				// Initialize our mask
 :=			mask[1]=0x00;
 :=			mask[2]=0x00;
 :=			mask[3]=0x00;
 :=			for (i=0; i<32; i++) 	        	// we have 32 columns to drive
 :=			// store our mask in an array. we need to do this because
 :=			// the call to write_expanded_outputs will destroy the value
 :=			// passed in.
 :=				data[0] = mask[0]; 		// store which column we are driving
 :=				data[1] = mask[1];	 	// in an array
 :=				data[2] = mask[2];
 :=				data[3] = mask[3];
 :=				index = i + startposition; 	// point to the next pattern to display
 :=				if (index >= sizeof(pat)) 	// make sure that we don't exceed the array
 :=				index -= sizeof(pat);
 :=				port_b = 0; 			// disable driving the LEDs
 :=				write_expanded_outputs(data); 	// enable our column driver
 :=			//	port_b = pat[index]; 		// drive our LEDs
 :=				nelly=i\%8;
 :=                                for(down=0;down<Row;down++)
 :=                                  for (across =0;across
:=                                    port_b=pat[down][across];
 :=                                    printf("\%x",pat[down][across]);
 :=                                //printf("\%x",pat[index],"\r\n");
 :=                                if (shift_left(mask,4,0))
 :=  				mask[0] = 0x01;
 :=								// shift to the next column for next time
 :=				delay_us(700); 			// adjust this value to control the drive time
 :=								//for the leds
 :=		   	--delaycount; 				// decrement our delay loop counter
 :=	    ++startposition; 					// Point to the next data pattern
 :=	    if (startposition >= sizeof(pat)) 			// make sure that we don't exceed the array
 :=             		 startposition = 0;
 Original Post ID: 10056
		| isaac aiyanyo Guest
				| Re: 1D to 2D array |
				|  Posted: Sun Dec 15, 2002 4:03 pm |   |
				| i forgot to include the code here it is.
 Thanks in advance
 Isaac
 (oo)
 /(____)\
 #include <16F876.H>
 #ENDIF
 #include <74595.C>
 #byte port_a=5
 #byte port_b=6
 #byte port_c=7
 char const pat[4][8]={
 //CHAR const pat[40]    =  {
 int mask[4];
 int delaycount;
 int startposition;
 int index;
 int i,x,nelly;
 signed int down;
 signed int across=8;
 set_tris_c(0);
 set_tris_b(0);
 port_c = 0;
 port_b = 0;
 startposition = 0;
 delaycount = 2; 				// adjust this value to control scrolls speed
 while (delaycount)
 mask[1]=0x00;
 mask[2]=0x00;
 mask[3]=0x00;
 down=-1;
 // passed in.
 data[2] = mask[2];
 data[3] = mask[3];
 across=i\%8;
 if (!across) down++;		  //this should be ok
 //BEWARE nothing stops 'down'
 port_b = pat[down][across];       //incrementing beyond the array size
 //so down is given a value of
 // -1 outside the loop
 // there might be another way!
 mask[0] = 0x01;
 //for the leds
 startposition = 0;
 :=#define Row 4
 :=#define Col 8
 :=#ENDIF
 :=#byte port_a=5
 :=#byte port_b=6
 :=#byte port_c=7
 :=int mask[4];
 :=int delaycount;
 :=int index;
 :=int i,nelly;
 :=int down,across;
 :=set_tris_c(0);
 :=set_tris_b(0);
 :=port_c = 0;
 :=port_b = 0;
 :=while(1)
 :=			mask[1]=0x00;
 :=			mask[2]=0x00;
 :=			mask[3]=0x00;
 :=			// passed in.
 :=				nelly=i\%8;
 :=  				mask[0] = 0x01;
 :=								//for the leds
 Original Post ID: 10057
 | You cannot post new topics in this forum You cannot reply to topics in this forum
