SSD1306OLED lcd
paulie2907
SSD1306OLED lcd
PostPosted: Tue Feb 07, 2023 5:09 pm     Reply with quote
Hello, I have a problem with the LCD, the LCD has shifted by 4 pixels. I can't find a way to fix it :( And the display shows random lines on the right side.
It can be seen on the left side on the 4th pixel. 0,1,2,3 is not visible on the x-axis.
This is beyond me.
SSD1306OLED.c
 SSD1306 OLED driver for CCS PIC C compiler (SSD1306OLED.c)                   *
 Reference: Adafruit Industries SSD1306 OLED driver and graphics library.     *
 The driver is for I2C mode only.                                             *
 https://simple-circuit.com/                                                   *
 This is a library for our Monochrome OLEDs based on SSD1306 drivers          *
  Pick one up today in the adafruit shop!                                     *
  ------> http://www.adafruit.com/category/63_98                              *
 Adafruit invests time and resources providing this open source code,         *
 please support Adafruit and open-source hardware by purchasing               *
 products from Adafruit!                                                      *
 Written by Limor Fried/Ladyada  for Adafruit Industries.                     *
 BSD license, check license.txt for more information                          *
 All text above, and the splash screen must be included in any redistribution *
#include <stdint.h>
//------------------------------ Definitions ---------------------------------//
#ifndef SSD1306_I2C_ADDRESS
  #define SSD1306_I2C_ADDRESS   0x7A
#if !defined SSD1306_128_32 && !defined SSD1306_96_16
#define SSD1306_128_64
#if defined SSD1306_128_32 && defined SSD1306_96_16
  #error "Only one SSD1306 display can be specified at once"
#if defined SSD1306_128_64
  #define SSD1306_LCDWIDTH            128
  #define SSD1306_LCDHEIGHT            64
  #define SSD1306_LCDHEIGHT           32
#if defined SSD1306_96_16
  #define SSD1306_LCDWIDTH             96
  #define SSD1306_LCDHEIGHT            16
#define SSD1306_SETCONTRAST          0x81
#define SSD1306_DISPLAYALLON_RESUME  0xA4
#define SSD1306_DISPLAYALLON         0xA5
#define SSD1306_NORMALDISPLAY        0xA6
#define SSD1306_INVERTDISPLAY_       0xA7
#define SSD1306_DISPLAYOFF           0xAE
#define SSD1306_DISPLAYON            0xAF
#define SSD1306_SETDISPLAYOFFSET     0xD3
#define SSD1306_SETCOMPINS           0xDA
#define SSD1306_SETVCOMDETECT        0xDB
#define SSD1306_SETDISPLAYCLOCKDIV   0xD5
#define SSD1306_SETPRECHARGE         0xD9
#define SSD1306_SETMULTIPLEX         0xA8
#define SSD1306_SETLOWCOLUMN         0x00
#define SSD1306_SETHIGHCOLUMN        0x10
#define SSD1306_SETSTARTLINE         0x40
#define SSD1306_MEMORYMODE           0x20
#define SSD1306_COLUMNADDR           0x21
#define SSD1306_PAGEADDR             0x22
#define SSD1306_COMSCANINC           0xC0
#define SSD1306_COMSCANDEC           0xC8
#define SSD1306_SEGREMAP             0xA1
#define SSD1306_CHARGEPUMP           0x8D
#define SSD1306_EXTERNALVCC          0x01
#define SSD1306_SWITCHCAPVCC         0x02
// Scrolling #defines
#define SSD1306_ACTIVATE_SCROLL                      0x2F
#define SSD1306_DEACTIVATE_SCROLL                    0x2E
#define SSD1306_SET_VERTICAL_SCROLL_AREA             0xA3
#define SSD1306_RIGHT_HORIZONTAL_SCROLL              0x26
#define SSD1306_LEFT_HORIZONTAL_SCROLL               0x27
#define SSD1306_VERTICAL_AND_RIGHT_HORIZONTAL_SCROLL 0x29
#define SSD1306_VERTICAL_AND_LEFT_HORIZONTAL_SCROLL  0x2A
#define ssd1306_swap(a, b) { int16_t t = a; a = b; b = t; }
uint8_t _i2caddr, _vccstate, x_pos, y_pos, text_size;
int1 wrap = true;
void ssd1306_command(uint8_t c);
void SSD1306_Begin(uint8_t vccstate = SSD1306_SWITCHCAPVCC, uint8_t i2caddr = SSD1306_I2C_ADDRESS);
void SSD1306_DrawPixel(uint8_t x, uint8_t y, int1 color = TRUE);
void SSD1306_StartScrollRight(uint8_t start, uint8_t stop);
void SSD1306_StartScrollLeft(uint8_t start, uint8_t stop);
void SSD1306_StartScrollDiagRight(uint8_t start, uint8_t stop);
void SSD1306_StartScrollDiagLeft(uint8_t start, uint8_t stop);
void SSD1306_StopScroll(void);
void SSD1306_Dim(int1 dim);
void SSD1306_Display(void);
void SSD1306_ClearDisplay(void);
void SSD1306_DrawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int1 color = TRUE);
void SSD1306_DrawFastHLine(uint8_t x, uint8_t y, uint8_t w, int1 color = TRUE);
void SSD1306_DrawFastVLine(uint8_t x, uint8_t y, uint8_t h, int1 color = TRUE);
void SSD1306_FillRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h, int1 color = TRUE);
void SSD1306_FillScreen(int1 color = TRUE);
void SSD1306_DrawCircle(int16_t x0, int16_t y0, int16_t r);
void SSD1306_DrawCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername);
void SSD1306_FillCircle(int16_t x0, int16_t y0, int16_t r, int1 color = TRUE);
void SSD1306_FillCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername, int16_t delta, int1 color = TRUE);
void SSD1306_DrawRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h);
void SSD1306_DrawRoundRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h, uint8_t r);
void SSD1306_FillRoundRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h, uint8_t r, int1 color = TRUE);
void SSD1306_DrawTriangle(uint8_t x0, uint8_t y0, uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2);
void SSD1306_FillTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, int1 color = TRUE);
void SSD1306_DrawChar(uint8_t x, uint8_t y, uint8_t c, uint8_t size = 1);
void SSD1306_DrawText(uint8_t x, uint8_t y, char *_text, uint8_t size = 1);
void SSD1306_TextSize(uint8_t t_size);
void SSD1306_GotoXY(uint8_t x, uint8_t y);
void SSD1306_Print(uint8_t c);
void SSD1306_PutCustomC(rom uint8_t *c);
void SSD1306_SetTextWrap(int1 w);
void SSD1306_InvertDisplay(int1 i);
void SSD1306_DrawBMP(uint8_t x, uint8_t y, rom uint8_t *bitmap, uint8_t w, uint8_t h);
const char Font[] = {
0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x5F, 0x00, 0x00,
0x00, 0x07, 0x00, 0x07, 0x00,
0x14, 0x7F, 0x14, 0x7F, 0x14,
0x24, 0x2A, 0x7F, 0x2A, 0x12,
0x23, 0x13, 0x08, 0x64, 0x62,
0x36, 0x49, 0x56, 0x20, 0x50,
0x00, 0x08, 0x07, 0x03, 0x00,
0x00, 0x1C, 0x22, 0x41, 0x00,
0x00, 0x41, 0x22, 0x1C, 0x00,
0x2A, 0x1C, 0x7F, 0x1C, 0x2A,
0x08, 0x08, 0x3E, 0x08, 0x08,
0x00, 0x80, 0x70, 0x30, 0x00,
0x08, 0x08, 0x08, 0x08, 0x08,
0x00, 0x00, 0x60, 0x60, 0x00,
0x20, 0x10, 0x08, 0x04, 0x02,
0x3E, 0x51, 0x49, 0x45, 0x3E,
0x00, 0x42, 0x7F, 0x40, 0x00,
0x72, 0x49, 0x49, 0x49, 0x46,
0x21, 0x41, 0x49, 0x4D, 0x33,
0x18, 0x14, 0x12, 0x7F, 0x10,
0x27, 0x45, 0x45, 0x45, 0x39,
0x3C, 0x4A, 0x49, 0x49, 0x31,
0x41, 0x21, 0x11, 0x09, 0x07,
0x36, 0x49, 0x49, 0x49, 0x36,
0x46, 0x49, 0x49, 0x29, 0x1E,
0x00, 0x00, 0x14, 0x00, 0x00,
0x00, 0x40, 0x34, 0x00, 0x00,
0x00, 0x08, 0x14, 0x22, 0x41,
0x14, 0x14, 0x14, 0x14, 0x14,
0x00, 0x41, 0x22, 0x14, 0x08,
0x02, 0x01, 0x59, 0x09, 0x06,
0x3E, 0x41, 0x5D, 0x59, 0x4E,
0x7C, 0x12, 0x11, 0x12, 0x7C,
0x7F, 0x49, 0x49, 0x49, 0x36,
0x3E, 0x41, 0x41, 0x41, 0x22,
0x7F, 0x41, 0x41, 0x41, 0x3E,
0x7F, 0x49, 0x49, 0x49, 0x41,
0x7F, 0x09, 0x09, 0x09, 0x01,
0x3E, 0x41, 0x41, 0x51, 0x73,
0x7F, 0x08, 0x08, 0x08, 0x7F,
0x00, 0x41, 0x7F, 0x41, 0x00,
0x20, 0x40, 0x41, 0x3F, 0x01,
0x7F, 0x08, 0x14, 0x22, 0x41,
0x7F, 0x40, 0x40, 0x40, 0x40,
0x7F, 0x02, 0x1C, 0x02, 0x7F,
0x7F, 0x04, 0x08, 0x10, 0x7F,
0x3E, 0x41, 0x41, 0x41, 0x3E,
0x7F, 0x09, 0x09, 0x09, 0x06,
0x3E, 0x41, 0x51, 0x21, 0x5E,
0x7F, 0x09, 0x19, 0x29, 0x46
const char Font2[] = {
0x26, 0x49, 0x49, 0x49, 0x32,
0x03, 0x01, 0x7F, 0x01, 0x03,
0x3F, 0x40, 0x40, 0x40, 0x3F,
0x1F, 0x20, 0x40, 0x20, 0x1F,
0x3F, 0x40, 0x38, 0x40, 0x3F,
0x63, 0x14, 0x08, 0x14, 0x63,
0x03, 0x04, 0x78, 0x04, 0x03,
0x61, 0x59, 0x49, 0x4D, 0x43,
0x00, 0x7F, 0x41, 0x41, 0x41,
0x02, 0x04, 0x08, 0x10, 0x20,
0x00, 0x41, 0x41, 0x41, 0x7F,
0x04, 0x02, 0x01, 0x02, 0x04,
0x40, 0x40, 0x40, 0x40, 0x40,
0x00, 0x03, 0x07, 0x08, 0x00,
0x20, 0x54, 0x54, 0x78, 0x40,
0x7F, 0x28, 0x44, 0x44, 0x38,
0x38, 0x44, 0x44, 0x44, 0x28,
0x38, 0x44, 0x44, 0x28, 0x7F,
0x38, 0x54, 0x54, 0x54, 0x18,
0x00, 0x08, 0x7E, 0x09, 0x02,
0x18, 0xA4, 0xA4, 0x9C, 0x78,
0x7F, 0x08, 0x04, 0x04, 0x78,
0x00, 0x44, 0x7D, 0x40, 0x00,
0x20, 0x40, 0x40, 0x3D, 0x00,
0x7F, 0x10, 0x28, 0x44, 0x00,
0x00, 0x41, 0x7F, 0x40, 0x00,
0x7C, 0x04, 0x78, 0x04, 0x78,
0x7C, 0x08, 0x04, 0x04, 0x78,
0x38, 0x44, 0x44, 0x44, 0x38,
0xFC, 0x18, 0x24, 0x24, 0x18,
0x18, 0x24, 0x24, 0x18, 0xFC,
0x7C, 0x08, 0x04, 0x04, 0x08,
0x48, 0x54, 0x54, 0x54, 0x24,
0x04, 0x04, 0x3F, 0x44, 0x24,
0x3C, 0x40, 0x40, 0x20, 0x7C,
0x1C, 0x20, 0x40, 0x20, 0x1C,
0x3C, 0x40, 0x30, 0x40, 0x3C,
0x44, 0x28, 0x10, 0x28, 0x44,
0x4C, 0x90, 0x90, 0x90, 0x7C,
0x44, 0x64, 0x54, 0x4C, 0x44,
0x00, 0x08, 0x36, 0x41, 0x00,
0x00, 0x00, 0x77, 0x00, 0x00,
0x00, 0x41, 0x36, 0x08, 0x00,
0x02, 0x01, 0x02, 0x04, 0x02
static uint8_t ssd1306_buffer[SSD1306_LCDHEIGHT * SSD1306_LCDWIDTH / 8] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xE0, 0x20, 0x20, 0x20, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x20,
0x20, 0x20, 0x20, 0x20, 0x60, 0x00, 0x10, 0xF0, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x60, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x78, 0x1F,
0x05, 0x0C, 0x74, 0x42, 0x01, 0x00, 0x38, 0x46, 0x42, 0x41, 0x21, 0x31, 0x0E, 0x00, 0x61, 0x3D,
0x07, 0x02, 0x61, 0x3F, 0x07, 0x02, 0x79, 0x4F, 0x00, 0x78, 0x44, 0x42, 0x21, 0x71, 0x5E, 0x21,
0x00, 0x61, 0x3D, 0x07, 0x02, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00, 0x40, 0x78, 0x4F, 0x43, 0x42
#if (SSD1306_LCDHEIGHT * SSD1306_LCDWIDTH > 96*16)
0x42, 0x46, 0x61, 0x10, 0x00, 0x70, 0x5E, 0x21, 0x3C, 0x4C, 0x4A, 0x49, 0x45, 0x25, 0x03, 0x38,
0x44, 0x42, 0x41, 0x41, 0x21, 0x03, 0x00, 0x71, 0x5F, 0x21, 0x61, 0x3D, 0x07, 0x02, 0x01, 0x03,
0x38, 0x46, 0x42, 0x41, 0x21, 0x31, 0x0E, 0x00, 0x60, 0x3D, 0x0F, 0x04, 0x02, 0x79, 0x4F, 0x00,
0x00, 0x71, 0x5F, 0x21, 0x38, 0x44, 0x42, 0x41, 0x41, 0x21, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
0xFC, 0x00, 0x00, 0xC0, 0x20, 0xE0, 0x00, 0x00, 0xC0, 0x20, 0xE0, 0x00, 0x00, 0xE0, 0x00, 0xE0,
0x00, 0x00, 0xC0, 0x20, 0xE0, 0x00, 0x00, 0xE0, 0x40, 0x20, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x04,
0x04, 0x00, 0x00, 0xFC, 0x00, 0x00, 0xC0, 0x20, 0xC0, 0x00, 0x00, 0xC0, 0x20, 0x20, 0x00, 0xFC,
0x80, 0x40, 0x20, 0x00, 0x00, 0x00, 0x00, 0x04, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8,
0x04, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x04,
0x03, 0x00, 0x00, 0x03, 0x04, 0x07, 0x00, 0x00, 0x13, 0x14, 0x0F, 0x00, 0x00, 0x03, 0x04, 0x03,
0x00, 0x00, 0x03, 0x04, 0x07, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x04,
0x04, 0x00, 0x00, 0x07, 0x00, 0x00, 0x03, 0x04, 0x03, 0x00, 0x00, 0x03, 0x04, 0x04, 0x00, 0x07,
0x01, 0x02, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x03,
0x04, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
#if (SSD1306_LCDHEIGHT == 64)
0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0xF0, 0xF9, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x1F, 0x0F,
0x87, 0xC7, 0xF7, 0xFF, 0xFF, 0x1F, 0x1F, 0x3D, 0xFC, 0xF8, 0xF8, 0xF8, 0xF8, 0x7C, 0x7D, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x3F, 0x0F, 0x07, 0x00, 0x30, 0x30, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xFE, 0xFE, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xC0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
0x00, 0xC0, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x7F, 0x3F, 0x1F,
0x0F, 0x07, 0x1F, 0x7F, 0xFF, 0xFF, 0xF8, 0xF8, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xF8, 0xE0,
0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0xFE, 0x00, 0x00,
0x00, 0xFC, 0xFE, 0xFC, 0x0C, 0x06, 0x06, 0x0E, 0xFC, 0xF8, 0x00, 0x00, 0xF0, 0xF8, 0x1C, 0x0E,
0x06, 0x06, 0x06, 0x0C, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0xFE, 0xFE, 0x00, 0x00, 0x00, 0x00, 0xFC,
0xFE, 0xFC, 0x00, 0x18, 0x3C, 0x7E, 0x66, 0xE6, 0xCE, 0x84, 0x00, 0x00, 0x06, 0xFF, 0xFF, 0x06,
0x06, 0xFC, 0xFE, 0xFC, 0x0C, 0x06, 0x06, 0x06, 0x00, 0x00, 0xFE, 0xFE, 0x00, 0x00, 0xC0, 0xF8,
0xFC, 0x4E, 0x46, 0x46, 0x46, 0x4E, 0x7C, 0x78, 0x40, 0x18, 0x3C, 0x76, 0xE6, 0xCE, 0xCC, 0x80,
0x00, 0x00, 0x00, 0x00, 0x01, 0x07, 0x0F, 0x1F, 0x1F, 0x3F, 0x3F, 0x3F, 0x3F, 0x1F, 0x0F, 0x03,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x00, 0x00,
0x00, 0x0F, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x00, 0x00, 0x03, 0x07, 0x0E, 0x0C,
0x18, 0x18, 0x0C, 0x06, 0x0F, 0x0F, 0x0F, 0x00, 0x00, 0x01, 0x0F, 0x0E, 0x0C, 0x18, 0x0C, 0x0F,
0x07, 0x01, 0x00, 0x04, 0x0E, 0x0C, 0x18, 0x0C, 0x0F, 0x07, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x00,
0x00, 0x0F, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x07,
0x07, 0x0C, 0x0C, 0x18, 0x1C, 0x0C, 0x06, 0x06, 0x00, 0x04, 0x0E, 0x0C, 0x18, 0x0C, 0x0F, 0x07,
    uint8_t control = 0x00;   // Co = 0, D/C = 0
    I2C_Start(SSD1306_STREAM);
    I2C_Write(SSD1306_STREAM, _i2caddr);
    I2C_Write(SSD1306_STREAM, control);
    I2C_Write(SSD1306_STREAM, c);
    I2C_Stop(SSD1306_STREAM);
  _vccstate = vccstate;
  _i2caddr  = i2caddr;
  delay_ms(10);
  #ifdef SSD1306_RST
    output_low(SSD1306_RST);
    output_drive(SSD1306_RST);
    delay_ms(10);
    output_high(SSD1306_RST);
  // Init sequence
  ssd1306_command(SSD1306_DISPLAYOFF);                      // 0xAE
  ssd1306_command(SSD1306_SETDISPLAYCLOCKDIV);              // 0xD5
  ssd1306_command(0x80);                                    // the suggested ratio 0x80
  ssd1306_command(SSD1306_SETMULTIPLEX);                    // 0xA8
  ssd1306_command(SSD1306_LCDHEIGHT - 1);
  ssd1306_command(SSD1306_SETDISPLAYOFFSET);                // 0xD3
  ssd1306_command(0x00);                                     // no offset
  ssd1306_command(SSD1306_SETSTARTLINE);                    // line #0
  ssd1306_command(SSD1306_CHARGEPUMP);                      // 0x8D
  ssd1306_command(0xAD);                                    // Master configuration
  ssd1306_command(0x8E);
  if (vccstate == SSD1306_EXTERNALVCC)
    { ssd1306_command(0x10); }
    { ssd1306_command(0x14); }
  ssd1306_command(SSD1306_MEMORYMODE);                    // 0x20
  ssd1306_command(0x00);                                  // 0x0 act like ks0108
  ssd1306_command(SSD1306_SEGREMAP | 0xA1);
  ssd1306_command(SSD1306_COMSCANDEC);
  ssd1306_command(SSD1306_SETCOMPINS);                    // 0xDA
  ssd1306_command(0x12);
  ssd1306_command(SSD1306_SETCONTRAST);                   // 0x81
  ssd1306_command(0x8F);
#elif defined SSD1306_128_64
    { ssd1306_command(0x9F); }
    { ssd1306_command(0xCF); }
#elif defined SSD1306_96_16
  ssd1306_command(0x2);   //ada x12
    { ssd1306_command(0xAF); }
  ssd1306_command(SSD1306_SETPRECHARGE);                  // 0xd9
  ssd1306_command(0xD2);
    { ssd1306_command(0x22); }
    { ssd1306_command(0xF1); }
  ssd1306_command(SSD1306_SETVCOMDETECT);                 // 0xDB
  ssd1306_command(0x34);
  ssd1306_command(SSD1306_DISPLAYALLON_RESUME);           // 0xA4
  ssd1306_command(SSD1306_NORMALDISPLAY);                 // 0xA6
  ssd1306_command(SSD1306_DEACTIVATE_SCROLL);
  ssd1306_command(SSD1306_DISPLAYON);//--turn on oled panel
  // set cursor to (0, 0)
  x_pos = 0;
  y_pos = 0;
  // set text size to 1
  text_size = 1;
     if ((x >= SSD1306_LCDWIDTH) || (y >= SSD1306_LCDHEIGHT))
       return;
     if (color)
       ssd1306_buffer[x + (uint16_t)(y / 8) * SSD1306_LCDWIDTH] |=  (1 << (y & 7));
       ssd1306_buffer[x + (uint16_t)(y / 8) * SSD1306_LCDWIDTH] &=  ~(1 << (y & 7));
  ssd1306_command(SSD1306_RIGHT_HORIZONTAL_SCROLL);
  ssd1306_command(0X00);
  ssd1306_command(start);
  ssd1306_command(stop);
  ssd1306_command(0XFF);
  ssd1306_command(SSD1306_ACTIVATE_SCROLL);
  ssd1306_command(SSD1306_LEFT_HORIZONTAL_SCROLL);
  ssd1306_command(SSD1306_SET_VERTICAL_SCROLL_AREA);
  ssd1306_command(SSD1306_LCDHEIGHT);
  ssd1306_command(SSD1306_VERTICAL_AND_RIGHT_HORIZONTAL_SCROLL);
  ssd1306_command(0X01);
  ssd1306_command(SSD1306_VERTICAL_AND_LEFT_HORIZONTAL_SCROLL);
  uint8_t contrast;
  if (dim)
    contrast = 0; // Dimmed display
  else {
    if (_vccstate == SSD1306_EXTERNALVCC)
      contrast = 0x9F;
      contrast = 0xCF;
  // the range of contrast to too small to be really useful
  // it is useful to dim the display
  ssd1306_command(contrast);
     ssd1306_command(SSD1306_COLUMNADDR);
     ssd1306_command(0);   // Column start address (0 = reset)
     ssd1306_command(SSD1306_LCDWIDTH-1); // Column end address (127 = reset)
     ssd1306_command(SSD1306_PAGEADDR);
     ssd1306_command(0); // Page start address (0 = reset)
     #if SSD1306_LCDHEIGHT == 64
       ssd1306_command(7); // Page end address
     #if SSD1306_LCDHEIGHT == 32
      ssd1306_command(3); // Page end address
     #if SSD1306_LCDHEIGHT == 16
       ssd1306_command(1); // Page end address
      uint16_t i =0;
      for (i = 0; i < (SSD1306_LCDWIDTH*SSD1306_LCDHEIGHT / 8); i++) {
         // send a bunch of data in one xmission
         I2C_Write(SSD1306_STREAM, 0x40);
         uint8_t x = 0;
         for (x = 0; x < 16; x++) {
           I2C_Write(SSD1306_STREAM, ssd1306_buffer[i]);
           i++;
         i--;
      uint16_t i = 0;
      ssd1306_buffer[i] = 0;
     int1 steep;
     int8_t ystep;
     uint8_t dx, dy;
     int16_t err;
     steep = abs(y1 - y0) > abs(x1 - x0);
     if (steep) {
       ssd1306_swap(x0, y0);
       ssd1306_swap(x1, y1);
     if (x0 > x1) {
       ssd1306_swap(x0, x1);
       ssd1306_swap(y0, y1);
     dx = x1 - x0;
     dy = abs(y1 - y0);
     err = dx / 2;
     if (y0 < y1)
       ystep = 1;
       ystep = -1;
     for (; x0 <= x1; x0++) {
       if (steep) {
         if(color) SSD1306_DrawPixel(y0, x0);
         else      SSD1306_DrawPixel(y0, x0, FALSE);
       else {
         if(color) SSD1306_DrawPixel(x0, y0);
         else      SSD1306_DrawPixel(x0, y0, FALSE);
       err -= dy;
       if (err < 0) {
         y0  += ystep;
         err += dx;
   SSD1306_DrawLine(x, y, x + w - 1, y, color);
  SSD1306_DrawLine(x, y, x, y + h - 1, color);
   int16_t i = 0;
   for (i = x; i < x + w; i++)
   SSD1306_DrawFastVLine(i, y, h, color);
void SSD1306_FillScreen(int1 color = TRUE) {
  SSD1306_FillRect(0, 0, SSD1306_LCDWIDTH, SSD1306_LCDHEIGHT, color);
  int16_t f = 1 - r;
  int16_t ddF_x = 1;
  int16_t ddF_y = -2 * r;
  int16_t x = 0;
  int16_t y = r;
  SSD1306_DrawPixel(x0  , y0 + r);
  SSD1306_DrawPixel(x0  , y0 - r);
  SSD1306_DrawPixel(x0 + r, y0);
  SSD1306_DrawPixel(x0 - r, y0);
  while (x < y) {
    if (f >= 0) {
      y--;
      ddF_y += 2;
      f += ddF_y;
    x++;
    ddF_x += 2;
    f += ddF_x;
    SSD1306_DrawPixel(x0 + x, y0 + y);
    SSD1306_DrawPixel(x0 - x, y0 + y);
    SSD1306_DrawPixel(x0 + x, y0 - y);
    SSD1306_DrawPixel(x0 - x, y0 - y);
    SSD1306_DrawPixel(x0 + y, y0 + x);
    SSD1306_DrawPixel(x0 - y, y0 + x);
    SSD1306_DrawPixel(x0 + y, y0 - x);
    SSD1306_DrawPixel(x0 - y, y0 - x);
  int16_t f     = 1 - r;
  int16_t ddF_x = 1;
  int16_t x     = 0;
  int16_t y     = r;
  while (x < y) {
    if (f >= 0) {
      y--;
      ddF_y += 2;
      f     += ddF_y;
    x++;
    ddF_x += 2;
    f     += ddF_x;
    if (cornername & 0x4) {
    if (cornername & 0x2) {
    if (cornername & 0x8) {
    if (cornername & 0x1) {
  SSD1306_DrawFastVLine(x0, y0 - r, 2 * r + 1, color);
  SSD1306_FillCircleHelper(x0, y0, r, 3, 0, color);
// Used to do circles and roundrects
void SSD1306_FillCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername, int16_t delta, int1 color = TRUE) {
  int16_t f     = 1 - r;
  int16_t ddF_x = 1;
  int16_t x     = 0;
  int16_t y     = r;
  while (x < y) {
    if (f >= 0) {
      y--;
      ddF_y += 2;
      f     += ddF_y;
    x++;
    ddF_x += 2;
    f     += ddF_x;
    if (cornername & 0x01) {
      SSD1306_DrawFastVLine(x0 + x, y0 - y, 2 * y + 1 + delta, color);
      SSD1306_DrawFastVLine(x0 + y, y0 - x, 2 * x + 1 + delta, color);
    if (cornername & 0x02) {
      SSD1306_DrawFastVLine(x0 - x, y0 - y, 2 * y + 1 + delta, color);
      SSD1306_DrawFastVLine(x0 - y, y0 - x, 2 * x + 1 + delta, color);
// Draw a rectangle
  SSD1306_DrawFastHLine(x, y, w);
  SSD1306_DrawFastHLine(x, y + h - 1, w);
  SSD1306_DrawFastVLine(x, y, h);
  SSD1306_DrawFastVLine(x + w - 1, y, h);
// Draw a rounded rectangle
  // smarter version
  SSD1306_DrawFastHLine(x + r, y, w - 2 * r); // Top
  SSD1306_DrawFastHLine(x + r, y + h - 1, w - 2 * r); // Bottom
  SSD1306_DrawFastVLine(x, y + r, h - 2 * r); // Left
  SSD1306_DrawFastVLine(x + w - 1, y + r, h - 2 * r); // Right
  // draw four corners
  SSD1306_DrawCircleHelper(x + r, y + r, r, 1);
  SSD1306_DrawCircleHelper(x + w - r - 1, y + r, r, 2);
  SSD1306_DrawCircleHelper(x + w - r - 1, y + h - r - 1, r, 4);
  SSD1306_DrawCircleHelper(x + r, y + h - r - 1, r, 8);
// Fill a rounded rectangle
  // smarter version
  SSD1306_FillRect(x + r, y, w - 2 * r, h, color);
  SSD1306_FillCircleHelper(x + w - r - 1, y + r, r, 1, h - 2 * r - 1, color);
  SSD1306_FillCircleHelper(x + r        , y + r, r, 2, h - 2 * r - 1, color);
// Draw a triangle
  SSD1306_DrawLine(x0, y0, x1, y1);
  SSD1306_DrawLine(x1, y1, x2, y2);
  SSD1306_DrawLine(x2, y2, x0, y0);
// Fill a triangle
  int16_t a, b, y, last;
  // Sort coordinates by Y order (y2 >= y1 >= y0)
  if (y0 > y1) {
    ssd1306_swap(y0, y1); ssd1306_swap(x0, x1);
  if (y1 > y2) {
    ssd1306_swap(y2, y1); ssd1306_swap(x2, x1);
  if (y0 > y1) {
  if(y0 == y2) { // Handle awkward all-on-same-case as its own thing
    a = b = x0;
    if(x1 < a)      a = x1;
    else if(x1 > b) b = x1;
    if(x2 < a)      a = x2;
    else if(x2 > b) b = x2;
    SSD1306_DrawFastHLine(a, y0, b - a + 1, color);
    return;
  int16_t
  dx01 = x1 - x0,
  dy01 = y1 - y0,
  dx02 = x2 - x0,
  dy02 = y2 - y0,
  dx12 = x2 - x1,
  dy12 = y2 - y1;
  int32_t  sa   = 0, sb   = 0;
  // For upper part of triangle, find scanline crossings for segments
  // 0-1 and 0-2.  If y1=y2 (flat-bottomed triangle), the scanline y1
  // is included here (and second loop will be skipped, avoiding a /0
  // error there), otherwise scanline y1 is skipped here and handled
  // in the second loop...which also avoids a /0 error here if y0=y1
  // (flat-topped triangle).
  if(y1 == y2) last = y1;   // Include y1 scanline
  else         last = y1 - 1; // Skip it
  for(y = y0; y <= last; y++) {
    a   = x0 + sa / dy01;
    b   = x0 + sb / dy02;
    sa += dx01;
    sb += dx02;
    /* longhand:
    a = x0 + (x1 - x0) * (y - y0) / (y1 - y0);
    b = x0 + (x2 - x0) * (y - y0) / (y2 - y0);
    if(a > b) ssd1306_swap(a, b);
    SSD1306_DrawFastHLine(a, y, b - a + 1, color);
  // For lower part of triangle, find scanline crossings for segments
  // 0-2 and 1-2.  This loop is skipped if y1=y2.
  sa = dx12 * (y - y1);
  sb = dx02 * (y - y0);
  for(; y <= y2; y++) {
    a   = x1 + sa / dy12;
    b   = x0 + sb / dy02;
    sa += dx12;
    sb += dx02;
    /* longhand:
    a = x1 + (x2 - x1) * (y - y1) / (y2 - y1);
// invert the display
  if (i)
    ssd1306_command(SSD1306_INVERTDISPLAY_);
  wrap = w;
  SSD1306_GotoXY(x, y);
  SSD1306_TextSize(size);
  SSD1306_Print(c);
  while(*_text != '\0')
    SSD1306_Print(*_text++);
// move cursor to position (x, y)
  if((x >= SSD1306_LCDWIDTH) || (y >= SSD1306_LCDHEIGHT))
    return;
  x_pos = x;
  y_pos = y;
// set text size
  if(t_size < 1)
    t_size = 1;
  text_size = t_size;
/* print single char
    \a  Set cursor position to upper left (0, 0)
    \b  Move back one position
    \n  Go to start of current line
    \r  Go to line below
  int1 _color;
  uint8_t i, j, line;
  if (c == ' ' && x_pos == 0 && wrap)
    return;
  if(c == '\a') {
    x_pos = y_pos = 0;
    return;
  if( (c == '\b') && (x_pos >= text_size * 6) ) {
    x_pos -= text_size * 6;
    return;
  if(c == '\r') {
    x_pos = 0;
    return;
  if(c == '\n') {
    y_pos += text_size * 8;
    if((y_pos + text_size * 7) > SSD1306_LCDHEIGHT)
      y_pos = 0;
    return;
  if((c < ' ') || (c > '~'))
    c = '?';
  for(i = 0; i < 5; i++ ) {
    if(c < 'S')
      line = font[(c - ' ') * 5 + i];
      line = font2[(c - 'S') * 5 + i];
    for(j = 0; j < 7; j++, line >>= 1) {
      if(line & 0x01)
        _color = TRUE;
        _color = FALSE;
      if(text_size == 1) SSD1306_DrawPixel(x_pos + i, y_pos + j, _color);
      else               SSD1306_FillRect(x_pos + (i * text_size), y_pos + (j * text_size), text_size, text_size, _color);
  SSD1306_FillRect(x_pos + (5 * text_size), y_pos, text_size, 7 * text_size, FALSE);
  x_pos += text_size * 6;
  if( x_pos > (SSD1306_LCDWIDTH + text_size * 6) )
    x_pos = SSD1306_LCDWIDTH;
  if (wrap && (x_pos + (text_size * 5)) > SSD1306_LCDWIDTH)
    x_pos = 0;
      y_pos = 0;
// print custom char (dimension: 7x5 pixel)
  int1 _color;
  uint8_t i, j, line;
    line = c[i];
      if(line & 0x01)
        _color = TRUE;
        _color = FALSE;
  x_pos += (text_size * 6);
    x_pos = 0;
      y_pos = 0;
// draw BMP stored in ROM
void SSD1306_ROMBMP(uint8_t x, uint8_t y, rom uint8_t *bitmap, uint8_t w, uint8_t h)
   uint16_t i = 0;
   for(i = 0; i < h/8; i++ )
      uint16_t j = 0;
      for(j = 0; j < (uint16_t)w * 8; j++ )
         if( bit_test(bitmap[j/8 + i*w], j % 8) == 1 )
         SSD1306_DrawPixel(x + j/8, y + i*8 + (j % 8));
         SSD1306_DrawPixel(x + j/8, y + i*8 + (j % 8), 0);
on main is this
   // iniciliazitaion lcd
   SSD1306_Begin(SSD1306_SWITCHCAPVCC, SSD1306_I2C_ADDRESS );
   SSD1306_StartScrollRight(1, 0); // fix it for bad pixels
   delay_ms(20);
   SSD1306_StopScroll();
   delay_ms(20);
SSD1306_Display();
         delay_ms(5000);
         delay_ms(3000);
         SSD1306_ClearDisplay();
         SSD1306_InvertDisplay(0);
         SSD1306_DrawLine(0, 0, 128, 0);// this i see
         SSD1306_DrawLine(0, 31, 128, 31);//this i see too
         SSD1306_DrawLine(0, 1, 0, 31);// /this is not visible
         SSD1306_DrawLine(128, 0, 128, 31);// /this is not visible too
         SSD1306_Display();
while(true);
foto is here :https://romar-electronic.cz/1.jpg and https://romar-electronic.cz/2.jpg
display when i use is : https://www.ebay.com/itm/301220791533
PostPosted: Wed Feb 08, 2023 2:26 am     Reply with quote
Why not use the one I have supplied in the Code Library?. It has some
restrictions, since it is designed to use less RAM (to suit most PIC's), but
is working.
However the pixel left shift, almost certainly implies you do not actually
have an SSD1306 display. You probably have an SH1106. Unfortunately
a lot of the displays sold as SSD1306, actually use this chip. The difference
is that the SSD1306 can actually address 132*64, while the SH1106 can
only address 128*64. The ADAFRUIT library is written assuming that the
physical display starts at column 4 in the address range to allow for this.
My code has a define for SH1106 to fix this.
Just checked, and on the actual ADAFRUIT library, there is a version
for the SH1106. Changes some settings to make it work.
asmallri
PostPosted: Wed Feb 08, 2023 9:50 pm     Reply with quote
If you bought this from AliExpress or similar you may have an SH1106 driver display instead of a SDD1306. Most drivers support configuring the SDD1306 driver for the SH1106. Once initialized correctly software written for the SDD1306 works on the SH1106 based displays.
Regards, Andrew
PostPosted: Thu Feb 09, 2023 2:36 am     Reply with quote
It's actually totally certain that he doesn't have an SSD1306. This chip only
supports displays up to about 1.5". The maximum drive current to the
LED's is not enough for larger displays. 100uA max. The SSD1325, is the
Solomon chip for larger displays (300uA max). The SH1106, supports
200uA max. The other advantage of the SH, is that it supports running
the logic outputs at 5v, which is much more convenient for older PIC's.
This is why a lot of the boards use it. It is 95% compatible with the
SSD1306, just requiring the changes to the location offsets inside the
driver.
