Delfinss
| 16F1509 HEF read program memory |
Posted: Wed Apr 20, 2022 5:16 am |
Hi everyone
I want to save a 10 bit ADC value to memory.
when i say read memory i get 16383 value.
Where am I going wrong, can you help me please?
| Code: | :
#include <16f1509.h>
#device ADC = 10 // 0 ile 1023
#include <math.h>
#use delay(internal=1000000)
#fuses INTRC_IO
#fuses NOWDT
#fuses NOPUT
#fuses NOLVP
#fuses NOPROTECT
#fuses NODEBUG
#fuses NOBROWNOUT
#fuses NOWRT
#use fast_io(c)
#use fast_io(a)
#use fast_io(b)
#use rs232 (baud=9600, xmit=pin_B7,rcv=pin_B5, parity=N, stop=1)
//=================TEST_ARENA==================
#define HEF 0x1F80
#ROM int16 HEF={1,2,3,4} //ensures the compiler will not accidentally
//put something else here.
int8 count_NTC;
unsigned int8* avg_CO;
unsigned int8* oku;
unsigned long int sum_CO,onuf_co;
delay_ms(300);
// setup_psp(PSP_DISABLED);
setup_timer_1(T1_DISABLED);
//setup_CCP1(CCP_OFF);
// setup_CCP2(CCP_OFF);
set_tris_c(0b00001111);// C0,C1,C2,C3 pini input yapıldı.// C4 output
set_tris_a(0x00); // a2,a4,a5 pini output //red,green,yellow leds
set_tris_b(0b01000000); // Alarm_Set_Button
output_a(0x00); //red led
output_b(0x00);
output_c(0x00);
setup_adc(adc_clock_div_2);
// setup_adc_ports(4);
// setup_adc_ports(5);
//setup_adc_ports(6);
setup_adc_ports(7);
while (True){
//==========================test_alan==============
if (input(pin_b6)==1){
delay_ms(20);
output_high(pin_a2);
delay_ms(20);
//write the values
write_program_memory(HEF,&avg_CO,4);
if (input(pin_b6)==0) {
output_low(pin_a2);
delay_ms(20);
//and read them back - CCS read works fine
read_program_memory(HEF,&oku,4);
set_adc_channel(7);
delay_us(20);
sum_CO=0;
for (count_NTC=0; count_NTC<8; count_NTC++)
onuf_co=read_adc();
delay_us(100);
sum_CO=onuf_co + sum_CO;
&avg_CO= sum_CO/=8;
//==================red===
if (avg_CO >= oku){
output_high(pin_a5);
delay_ms(20);
else if (avg_CO < oku){
output_low(pin_a5);
delay_ms(20);
//==================green LED ==========================
output_high(pin_a4);
// delay_ms(1000);
//==================yellow LED ==========================
printf("AVG_CO-ADC=%lu\n\r",avg_CO);
printf("%lu\n\r",oku);
delay_ms(2000);
Posted: Wed Apr 20, 2022 5:27 am |
What compiler version?.
Also you need to lay the data out to write to HEF. The HEF is the low
byte of each instruction word. So it is like this:
0000 HEF byte, do not use this byte
0002 HEF byte, do not use this byte
0004 HEF byte, do not use this byte
etc....
You need to lay your data out as a 16bit array, with the data you want
to store in the low bytes of each 16bit word.
When reading back you have to do the opposite. |
Delfinss
Posted: Wed Apr 20, 2022 7:15 am |
| Compiler version v5.007 |
Posted: Wed Apr 20, 2022 7:23 am |
Ouch.
That compiler is before V5 was really a working compiler. It may well not
be reading/writing the memory correctly. It was a 'beta' at best at that
point. |
Posted: Wed Apr 20, 2022 9:22 am |
As a comment, use the proper defines for set_adc_ports. '7' is not a
legitimate ADC pin selection. sAN7 is the correct selection to select C3. |
Posted: Wed Apr 20, 2022 10:45 am |
Now, given the age of your compiler I know the program memory functions
will not work.
So here is a basic program showing reading and writing a 32bit value
to the HEF, with handwritten routines:
#include <16F1509.h>
#device ADC=10
#fuses NOWDT
#fuses NOLVP
#fuses NOPROTECT
#fuses NODEBUG
#fuses NOBROWNOUT
#fuses NOWRT
#use delay(internal=4000000)
#include <math.h>
#byte PMCON1=getenv("SFR:PMCON1")
#byte PMCON2=getenv("SFR:PMCON2")
#byte PMDATL=getenv("SFR:PMDATL")
#byte PMDATH=getenv("SFR:PMDATH")
#byte PMADRL=getenv("SFR:PMADRL")
#byte PMADRH=getenv("SFR:PMADRH")
#bit CFGS=PMCON1.6
#bit RD=PMCON1.0
#bit WREN=PMCON1.2
#bit FREE=PMCON1.4
#bit WR=PMCON1.1
#bit LWLO=PMCON1.5
#define MAX_BYTES_TO_USE 4 //change this to adjust how many bytes can be transferred
int16 PmBuff[MAX_BYTES_TO_USE]; //one word allocated for every byte
#define HEF_ADDRESS 0x1F80
#ROM int16 HEF_ADDRESS={1,2,3,4} //ensures the compiler will not accidentally
//Now basic routines to write the program memory given compiler is too old to have these working
#inline //Make this inline
void unlock(void)
//unlock the memory
PMCON2=0x55; //unlock sequence
PMCON2=0xAA;
WR=TRUE; //trigger unlock
delay_cycles(1);
delay_cycles(1); //Two NOPs
void erase(void)
//erase the HEF page
PMADRL=HEF_ADDRESS;
PMADRH=make8(HEF_ADDRESS,1);
CFGS=FALSE;
FREE=TRUE;
WREN=TRUE; //specify erase
unlock(); //This unlocks and performs the erase
WREN=FALSE;
//Physical read and write routines
void write_HEF(char * buffer)
int ctr;
disable_interrupts(GLOBAL); //interrupts must be off during write
erase(); //erase the page
PMADRL=HEF_ADDRESS;
CFGS=FALSE;
WREN=TRUE;
LWLO=TRUE; //write to latches
//now load the bytes into the latches
for (ctr=0;ctr<MAX_BYTES_TO_USE;ctr++)
PMDATL=*(buffer++);
PMDATH=*(buffer++);
unlock();
PMADRL++;
LWLO=FALSE; //turn off latch access
unlock(); //perform the physical write
WREN=FALSE;
void read_HEF(void)
int ctr;
PMADRL=HEF_ADDRESS;
//now need to read the four 16bit values
CFGS=FALSE;
RD=TRUE;
delay_cycles(1);
delay_cycles(1); //two NOPs
PmBuff[ctr]=make16(PMDATH,PMDATL);
PMADRL++;
//Routines to transfer an int32 in/out of the HEF layout
void build_table(int32 val)
//format an int32 value into the HEF layout
PmBuff[0]=make8(val,0);
PmBuff[1]=make8(val,1);
PmBuff[2]=make8(val,2);
PmBuff[3]=make8(val,3);
int32 retrieve_table(void)
//read the bytes back out of the table into an int32
int32 val;
//Just the low byte from each value
val=make32((int8)PmBuff[3],(int8)PmBuff[2],(int8)PmBuff[1],(int8)PmBuff[0]);
return val;
//write an int32 to HEF
void HEF_write(int32 val)
build_table(val);
write_HEF((char *)PmBuff); //write the 8 bytes to HEF
//read an int32 from HEF
int32 HEF_read(void)
read_HEF(); //read the 8 bytes back
return retrieve_table(); //and convert back to int32
int1 dowrite=TRUE;
int32 value = 0x112255AA; //test value
//Now just do a single write to HEF to prove how this works.
if (dowrite==TRUE)
HEF_write(value);
dowrite=FALSE; //stop writing - remember writes use lives.
value=HEF_read();
printf("Value is %LX\n",value);
Delfinss
Posted: Thu Apr 21, 2022 3:39 am |
| Thank you very much for your effort But I get the value is FFFFFFFF |
Posted: Thu Apr 21, 2022 3:57 am |
Hmm. Two possibilities.
One your compiler is not setting up one of the registers correctly. I don't
have 5.007, the earliest V5 compiler I bothered to keep was 5.012. Before
this there were so many problems that it was pointless to keep them.
Two, you have killed the HEF by repeatedly writing.
Are you testing with a known test value as I show?.
The code works correctly on a later compiler. |
Delfinss
Posted: Thu Apr 21, 2022 4:25 am |
Yes I am testing it with the test value you sent.
I will test with the updated version. |
Delfinss
Posted: Tue Apr 26, 2022 12:39 am |
Hello again
Even though I tried again with CCS C Version 5.049V, the result did not change.
I am doing the simulation in proteus. Is this why I am getting wrong results (proteus version 8.10)? |
Posted: Tue Apr 26, 2022 1:16 am |
AAARGH!.......
Seriously see the previous comments here about Proteus. IT DOES NOT WORK.
You can take perfectly working code, and Proteus will tell you it doesn't
work. You can design code that works in Proteus, put it into a real chip,
and it won't work.
You are wasting your time using Proteus.
I use it as a PCB package. For that it is good. However the simulator
is a complete waste of time on the PIC (actually quite good for analog
designs). On the PIC so many parts don't work, or work incorrectly, it
is pointless. |
Joined: 01 Jul 2010 Posts: 9649 Location: Greensville,Ontario
Posted: Tue Apr 26, 2022 5:25 am |
re: You are wasting your time using Proteus.
AND OURS !!!!
Arrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrgh...
It should be a 'rule' that the first line posted is 'this is real code' or 'this is a 'simulation'....
NO 'simulator' actually runs like a PIC, None, nada, zilch, zero. while some emulate some portion/features of some PICs in 2+decades of 'playing with PICS', NONE run like a real PIC in the Real World using Real code.
If I had a penny for every hour wasted on programmers trying to use Proteus, I could retire. Better yet, buy a plant to manufacture PICs !! |
Posted: Tue Apr 26, 2022 5:47 am |
Also look at the sticky at the head of the Forum.
Questions here should be real hardware _only_. |
Delfinss
Posted: Wed Apr 27, 2022 5:36 am |
| Sorry, I'm very new to this work. I will be more careful. I have a few shortcomings in the hardware, I will try it immediately when I complete it. |
Rhinomx
Posted: Wed Aug 24, 2022 1:32 pm |
| temtronic wrote: | re: You are wasting your time using Proteus.
AND OURS !!!!
HI!
hope this helps!
BIG BIG thank you for your code you didn't waste your time, it just help me a lot to understand how to store in the HEF I just tested and works great. BIG thank you! |
