PIC16F877A int_ext
Khansokhua
PIC16F877A int_ext
PostPosted: Sat Nov 27, 2021 4:07 am     Reply with quote
#include <Timerlar.h>
#fuses XT
#use delay(clock=4M)
#use fast_io(b)
int i;
const int segment[10]= {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7C,0x07,0x7F,0x6F};
#int_ext
void ext_kesme()
   output_high(pin_d0);
   output_low(pin_d0);
   delay_ms(3000);
   for(i=0;i<=9;i++)
        output_c(segment[i]);
        output_low(pin_d0);
  set_tris_b(0x01);
   output_c(0x00);
   output_d(0x00);
   output_a(0x02);
   ext_int_edge(L_TO_H);
   enable_interrupts(int_ext);
Hi greetings! I don't know why, how on PORTB RB2-RB3-RB5-RB6 were being logic "1". I just wonder why this happened ?
If someone could explain, thanks respects!
Re: PIC16F877A int_ext
PostPosted: Sat Nov 27, 2021 9:29 am     Reply with quote
Khansokhua wrote:
output_c(0x00);
output_d(0x00);
output_a(0x02);
You never initialize PortB. You only initialize ports C, D, and A.
If you want PortB to be 0x00, then add this line:
output_b(0x00);
PostPosted: Sat Nov 27, 2021 12:20 pm     Reply with quote
The point is you set the TRIS:
set_tris_b(0x01);
Now the register for a port defaults to '1' (data sheet), so when you set
the tris to set these bits as outputs all the bits (except B1), go high.
To set the bits to low, and leave B1 as an input - get rid of the above
TRIS instruction, then:
   output_b(0); //B0 to B7 now all 0
   output_float(PIN_B1); //B1 is now an input
Khansokhua
PostPosted: Mon Nov 29, 2021 4:10 am     Reply with quote
Thank you
