write_program_memory on 18F25K80 not working
2xhp
PostPosted: Wed Apr 14, 2021 6:43 pm     Reply with quote
I can't seem to get write_program_memory to work on a 18F25K80. Compiler version is PCH V5.087.
I'm checking to see if it's written or not by reading back the program memory. The programmer I'm using is a PICkit 2. I see that the EEPROM value I'm writing is written to just to verify the program is running.
Any ideas anyone? I thought maybe it's a fuse value, but I've tried everything that seems like it might be related to write protection. Thanks in advance.
Test program:
#include <18F25K80.h>
#fuses HSM,PLLEN,NOFCMEN,NOIESO,WDT,WDT_SW,NOMCLR,NOBROWNOUT,NOPUT,SOSC_DIG
#fuses NOPROTECT,NOCPD,NOCPB,NOWRTD,NOWRTB,NOWRTC,NOEBTRB
#use delay(clock=40000000, restart_wdt)
int8 buffer[64] = {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,
   17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,
   33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,
   49,50,51,52,53,54,55,56,57,58,59,60,60,62,63,64 };
   write_program_memory(0x2000,buffer,64);
   write_eeprom(0x00, 0x77);
List file:
    CCS PCH C Compiler, Version 5.087, xxxxx 14-Apr-21 18:37
    Filename: C:\temp\test.lst
    ROM used: 326 bytes (1%)
    Largest free fragment is 32442
    RAM used: 68 (2%) at main() level
    75 (2%) worst case
    Stack used: 0 locations
    Stack size: 31
    0000: GOTO 0066
    .................... #include <18F25K80.h>
    .................... //////////// Standard Header file for the PIC18F25K80 device ////////////////
    .................... //// (C) Copyright 1996, 2014 Custom Computer Services ////
    .................... //// This source code may only be used by licensed users of the CCS C ////
    .................... //// compiler. This source code may only be distributed to other ////
    .................... //// licensed users of the CCS C compiler. No other use, reproduction ////
    .................... //// or distribution is permitted without written permission. ////
    .................... //// Derivative programs created using this software in object code ////
    .................... //// form are not restricted in any way. ////
    .................... #device PIC18F25K80
    0004: MOVF FF2,W
    0006: MOVWF 03
    0008: BCF FF2.7
    000A: BSF F7F.7
    000C: BSF F7F.2
    000E: MOVLB F
    0010: MOVLW 55
    0012: MOVWF F7E
    0014: MOVLW AA
    0016: MOVWF F7E
    0018: BSF F7F.1
    001A: NOP
    001C: MOVF 03,W
    001E: IORWF FF2,F
    0020: MOVLB 0
    0022: RETURN 0
    0024: BCF F7F.6
    0026: MOVF FF6,W
    0028: ANDLW 3F
    002A: MOVWF 00
    002C: MOVLW C0
    002E: ANDWF FF6,F
    0030: TBLRD*-
    0032: MOVFF 44,01
    0036: TSTFSZ 00
    0038: BRA 0048
    003A: MOVFF FEE,FF5
    003E: MOVF 01,F
    0040: BZ 004A
    0042: TBLWT+*
    0044: DECF 01,F
    0046: BRA 004E
    0048: DECF 00,F
    004A: TBLRD+*
    004C: TBLWT*
    004E: MOVLW 3F
    0050: ANDWF FF6,W
    0052: XORLW 3F
    0054: BNZ 0036
    0056: BSF F7F.4
    0058: RCALL 0004
    005A: RCALL 0004
    005C: TSTFSZ 01
    005E: BRA 0036
    0060: CLRF FF8
    0062: GOTO 011A (RETURN)
    .................... #list
    .................... #fuses HSM,PLLEN,NOFCMEN,NOIESO,WDT,WDT_SW,NOMCLR,NOBROWNOUT,NOPUT,SOSC_DIG
    .................... #fuses NOPROTECT,NOCPD,NOCPB,NOWRTD,NOWRTB,NOWRTC,NOEBTRB
    .................... #use delay(clock=40000000, restart_wdt)
    .................... int8 buffer[64] = {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,
    .................... 17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,
    .................... 33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,
    .................... 49,50,51,52,53,54,55,56,57,58,59,60,60,62,63,64 };
    .................... void main() {
    0066: CLRF FF8
    0068: BCF FD0.7
    006A: MOVLB F
    006C: MOVF x5C,W
    006E: ANDLW 80
    0070: MOVWF x5C
    0072: MOVLW 00
    0074: MOVWF x5D
    0076: BCF FC1.3
    0078: BCF FC1.4
    007A: BCF FC1.5
    007C: CLRF x5E
    007E: CLRF x5F
    0080: BRA 00C6
    0082: DATA 40,00
    0084: DATA 04,01
    0086: DATA 02,03
    0088: DATA 04,05
    008A: DATA 06,07
    008C: DATA 08,09
    008E: DATA 0A,0B
    0090: DATA 0C,0D
    0092: DATA 0E,0F
    0094: DATA 10,11
    0096: DATA 12,13
    0098: DATA 14,15
    009A: DATA 16,17
    009C: DATA 18,19
    009E: DATA 1A,1B
    00A0: DATA 1C,1D
    00A2: DATA 1E,1F
    00A4: DATA 20,21
    00A6: DATA 22,23
    00A8: DATA 24,25
    00AA: DATA 26,27
    00AC: DATA 28,29
    00AE: DATA 2A,2B
    00B0: DATA 2C,2D
    00B2: DATA 2E,2F
    00B4: DATA 30,31
    00B6: DATA 32,33
    00B8: DATA 34,35
    00BA: DATA 36,37
    00BC: DATA 38,39
    00BE: DATA 3A,3B
    00C0: DATA 3C,3C
    00C2: DATA 3E,3F
    00C4: DATA 40,00
    00C6: MOVLW 00
    00C8: MOVWF FF8
    00CA: MOVLW 00
    00CC: MOVWF FF7
    00CE: MOVLW 82
    00D0: MOVWF FF6
    00D2: TBLRD*+
    00D4: MOVF FF5,W
    00D6: MOVWF 00
    00D8: XORLW 00
    00DA: BZ 0102
    00DC: TBLRD*+
    00DE: MOVF FF5,W
    00E0: MOVWF 01
    00E2: BTFSC FE8.7
    00E4: BRA 00F0
    00E6: ANDLW 3F
    00E8: MOVWF FEA
    00EA: TBLRD*+
    00EC: MOVFF FF5,FE9
    00F0: BTFSC 01.6
    00F2: TBLRD*+
    00F4: BTFSS 01.6
    00F6: TBLRD*+
    00F8: MOVFF FF5,FEE
    00FC: DCFSNZ 00,F
    00FE: BRA 00D2
    0100: BRA 00F4
    0102: CLRF FF8
    .................... write_program_memory(0x2000,buffer,64);
    0104: CLRF FF8
    0106: MOVLW 20
    0108: MOVWF FF7
    010A: CLRF FF6
    010C: CLRF FEA
    010E: MOVLW 04
    0110: MOVWF FE9
    0112: MOVLW 40
    0114: MOVWF 44
    0116: MOVLB 0
    0118: BRA 0024
    .................... write_eeprom(0x00, 0x77);
    011A: MOVF FF2,W
    011C: MOVWF 00
    011E: BCF FF2.7
    0120: CLRF F75
    0122: CLRF F74
    0124: MOVLW 77
    0126: MOVWF F73
    0128: BCF F7F.6
    012A: BCF F7F.7
    012C: BSF F7F.2
    012E: MOVLB F
    0130: MOVLW 55
    0132: MOVWF F7E
    0134: MOVLW AA
    0136: MOVWF F7E
    0138: BSF F7F.1
    013A: BTFSC F7F.1
    013C: BRA 013A
    013E: BCF F7F.2
    0140: MOVF 00,W
    0142: IORWF FF2,F
    0144: SLEEP
    Configuration Fuses:
    Word 1: 1315 VREGSLEEP INTRC_HP SOSC_DIG NOXINST HSM PLLEN NOFCMEN NOIESO
    Word 2: 7E79 NOPUT NOBROWNOUT BORV18 ZPBORM WDT_SW WDT1048576
    Word 3: 0900 CANB MSSPMSK7
    Word 4: 0091 STVREN BBSIZ2K NODEBUG
    Word 5: C00F NOPROTECT NOCPB NOCPD
    Word 6: E000 NOWRTC NOWRTB NOWRTD
    Word 7: 4000 NOEBTRB
PostPosted: Wed Apr 14, 2021 8:04 pm     Reply with quote
Here are the fuses for your program when compiled with CCS vs. 5.103.
Note the write protection bits in the lowest nybbles of Words 6 and 7 are set
to 0xF. This disables write protection on certain blocks. In your version,
the blocks are write protected. Try adding NOWRT to your #fuses.
Word 3: 0900 CANB MSSPMSK7 NOMCLR
Word 6: E00F NOWRT NOWRTC NOWRTB NOWRTD
Word 7: 400F NOEBTR NOEBTRB
2xhp
PostPosted: Wed Apr 14, 2021 8:17 pm     Reply with quote
Thank you so much for looking into this!
Hmm ... looks like I don't have a NOWRT fuse option. Any other ways to get that set correctly short of upgrading the compiler version?
2xhp
PostPosted: Wed Apr 14, 2021 8:23 pm     Reply with quote
I just answered my own question:
#FUSES 7=0x400F
I'll test that and see if it works.
2xhp
PostPosted: Wed Apr 14, 2021 8:49 pm     Reply with quote
#FUSES 7=0x400F
So with the following:
#FUSES 6=0xE00F
#FUSES 7=0x400F
... it works.
Thank you PCM Programmer! Wish I could take you out to dinner or something.
