RS485 communication problem
tunatopraktan
PostPosted: Tue Mar 23, 2021 3:23 am     Reply with quote
Hello friends,
I am working on a project that has 4 circuits. And they will communicate with each other. I have started from basic with two circuits. I am using standard <rs485.c> library.
I used " rs485_send_message(ID, length, data); " function to send data,
and " rs485_get_message(data, false) " function to receive data.
This is easy. But the problem is when i send the data to the slave, the slave does not understand the data. It is acting every time the same. For example when i send 0x6F, the slave is blinking one time. If i send 0x70, the slave is blinking one time again. Whatever i sent, this is same. The slave understands that something has come in but it does not know what it is.
My codes are below,
Thanks for your help.
////////        MASTER             ///////////
#include <16f877a.h>
#use delay(clock=20M)
#fuses HS, NOWDT, NOPUT, NOLVP, NOCPD, NOPROTECT, NODEBUG, NOBROWNOUT, NOWRT
#include <string.h>
#define RS485_ID 0x00
#define RS485_RX_ENABLE PIN_C5
#define RS485_ENABLE_PIN PIN_C5
#define RS485_USE_EXT_INT FALSE
#include <rs485.c>
  set_tris_b(0xFF);
  rs485_init();
  unsigned int i=0, t=0;
  while(true)
      if (input(pin_b1) == 1)
        rs485_send_message(0x01, 6, 0x6F);    // 0X6F is sent
        output_high(PIN_C1);
        delay_ms(20);
        output_low(PIN_C1);
      if (input(pin_b2) == 1)
        rs485_send_message(0x01, 6, 0x70);    //0X70 is sent
        delay_ms(20);
        output_low(PIN_C1);
////////////           SLAVE          /////////////////////7
#include <16f877A.h>
#include <string.h>
#define RS485_ID 0x01
#include <rs485.c>
   rs485_init();
   while(true)
      for(int t=0; t<50; t++)
         if(rs485_get_message(0x6F, false))   // when i receive 0x6F
         output_high(pin_c1);
         delay_ms(50);
         output_low(pin_c1);
         delay_ms(50);
         if(rs485_get_message(0x70, false))    // when i receive 0x70
         output_high(pin_c2);
         delay_ms(50);
         output_low(pin_c2);
         delay_ms(50);
         delay_ms(50);
         output_low(pin_c2);
         delay_ms(50);
         delay_ms(50);
      output_high(pin_c0);
      delay_ms(30);
      output_low(pin_c0);
      delay_ms(30);
PostPosted: Tue Mar 23, 2021 4:10 am     Reply with quote
You are misunderstanding how get/send message works.
get doesn't 'look' for a specific value, it receives a message. You then have
to decode this.
The value passed are pointers to where you want the message to be stored,
and a flag to select for a timeout or not.
send_message also wants a pointer to the data.
So your master needs something like:
   char message_buff[1];
   message_buff[0]=0x6F; //to send the 6F message
   rs485_send_message(0x01, 1, message_buff);    // send single byte
   //from message_buff
Then your slave needs something like:
   char message[8]; //minimum for a one byte message is 3
   set_tris_b(0xFF);
   rs485_init();
   while (TRUE)
      if (rs485_get_message(message, FALSE))
         //now we only get here if a message was available
         //message[0] will be the ID that sent the message
         //message[1] will be the message length
         //message[2] will be the message byte
         if (message[2]==0x6F)
            //here we have received a 0x6F message
         else if (message[2]==0x70)
             //here the 0x70 message
tunatopraktan
PostPosted: Thu Mar 25, 2021 5:08 am     Reply with quote
to decode this.
   //from message_buff
   set_tris_b(0xFF);
   rs485_init();
   while (TRUE)
Thank you very much for your help Ttelmah,
It was very helpful.
I have one more question?
If want to take feedback data from slave to master. Which way should i follow? And how can i understand the bus line is suitable?
PostPosted: Thu Mar 25, 2021 8:46 am     Reply with quote
You just send a message back.
The whole point of this system is that provided the RS485 is properly
configured so all the transceivers are in receive mode when not sending
any device on the bus can send a message to any other device. The code
automatically handles retrying if the bus is busy with another message
when you try to send.
You'd probably want to set the message buffer size to perhaps 8 characters
in all the chips, since the receive message always has the ID and message
length also put into the buffer.
tunatopraktan
PostPosted: Mon Mar 29, 2021 4:27 am     Reply with quote
Thanks for your help friend.
