bootloader crc
georpo
bootloader crc
PostPosted: Sun Dec 13, 2020 12:48 pm     Reply with quote
I have seen that the loader_pcd checks each line checksum and then writes to program memory.
What if some lines are OK but some lines are bad data? Do I get a corrupt PIC?
In my tests, I send the hex file 2 times and write to 2 different locations of external flash, then compare the 2 files byte by byte and only if they are OK, I write them to the program memory.
This of course works but needs big flash etc.
How can I calculate the CRC of the hex file so I can send the hex file only once?
;DSPIC33FJ64GP804
;CRC=8C7D  CREATED="13-Dec-20 19:44"
George.
PostPosted: Sun Dec 13, 2020 12:57 pm     Reply with quote
See this thread for sample code:
http://www.ccsinfo.com/forum/viewtopic.php?t=58331
georpo
PostPosted: Sun Dec 13, 2020 1:14 pm     Reply with quote
Thanks PCM programmer!
I have the hex file in external flash.
Below are the last lines:
:1059E0008410020000000000F81202000000000015
:1059F000A415020000000000B8270200000000000B
:085A0000FFFF37000040FE002B
:00000001FF
;DSPIC33FJ64GP804
So, which is the last ASCII character that I will pass through the CRC16 code?
Is it the last 'F' before the 1st ';'?
George.
georpo
PostPosted: Sun Dec 13, 2020 1:51 pm     Reply with quote
I got it.
It includes the ";DSPIC33FJ64GP804" line but not the CRC line.
It WORKS!
Thanks!!!!!!
George.
