Pointers to an array
SeeCwriter
PostPosted: Mon Nov 30, 2020 10:41 am     Reply with quote
Can I create an array of 32-bit integers and assign that to a pointer? I don't have hardware to test this right now, and when I tried it a few years ago it didn't work. It compiled but the program didn't do what I wanted.
Example:
signed int32 *pData[];
const signed int32 mydata[] =
  0x01000002,
  0x02000001,
  0x03000046,
  0x05000390,
  0x05000000,
  0x06002F4A,
  0x0700054D,
  0x08C9BEFF,
  0x09573FFF,
  0x0A002047,
  0x0B0F8061,
  0x0F000081,
  0x04200000
  byte len = sizeof(mydata) >> 2;
  pData = mydata;
  Dosomething(pData, len);
void Dosomething( int32 *d, byte num )
I'm using v5.097 of PCWH and a 12LF1552 pic.
PostPosted: Mon Nov 30, 2020 11:51 am     Reply with quote
Historically, the problem would have been this one word. 'Const'.
The problem is that the PIC is a Harvard architecture processor. On this
the RAM, and program memory are in different memory spaces. Const
puts the variable into the program memory space. Result a RAM pointer
won't actually point to it....
Now you can use ROM instead of const, which tells the compiler to store
the data so a ROM * pointer can be constructed to it. However you do have
to declare your function so it expects a ROM * pointer.
If you look at my SSD1306 driver in the code library this uses ROM *
pointers, so you can see how these can be used. Beware though that
CCS 5.096 has an issue with these (fixed in 5.097, and OK on earlier
releases).
SeeCwriter
PostPosted: Mon Nov 30, 2020 12:04 pm     Reply with quote
I will check it out. Thanks.
