PIC18F4550
vishnuk
PIC18F4550
PostPosted: Sat Aug 08, 2020 10:44 pm     Reply with quote
Sir, I need to use all pins of this PIC controller. I am doing project on Proteus software.
I can read all 12 analog pins. Why? When I am connecting pin it is coming error value.
AN0
AN1
AN4
AN5
AN8
AN9
AN10
Only above pins working. Others not.
This is my program. Please help me.
#define LCD_RS_PIN PIN_D0
#define LCD_RW_PIN PIN_D1
#define LCD_ENABLE_PIN PIN_D2
#define LCD_DATA4 PIN_D3
#define LCD_DATA5 PIN_D4
#define LCD_DATA6 PIN_D5
#define LCD_DATA7 PIN_D6
#include <18F4550.h>
#define ANO_TO_AN11_ANALOG
#device ADC=10
#fuses NOMCLR INTRC_IO
#use delay(clock=8000000)
#include <lcd.c>
float i;
void main(){
Char str[][7]={"sAN0","sAN1","sAN2","sAN3","sAN4","sAN5","AN6","AN7","AN8","AN9","AN10","AN11"};
 int g=1;
while(1){
  setup_oscillator(OSC_8MHZ);
  setup_adc(ADC_CLOCK_DIV_8);
  setup_adc_ports(AN0);
  set_adc_channel(0);
  lcd_gotoxy(3, 2);
  lcd_putc("CURRENT         A");
  i = read_adc();
  i= ((2500-i)/122);
  lcd_gotoxy(11, 2);
  printf(lcd_putc,"%f", i);
  delay_ms(10);
  while(g<11){
    setup_adc_ports(str[g]);
    set_adc_channel(g);
    lcd_gotoxy(3, 1);
    lcd_putc("VOLTAGE:           V");
    i = read_adc();
    i = i*0.00489;
    lcd_gotoxy(11, 1);
    printf(lcd_putc,"%f",i);
    g++;
  g=0;
PostPosted: Sun Aug 09, 2020 1:34 am     Reply with quote
First Proteus is not a way to know what a chip will really do. Read the
sticky at the top of the forum' It is badly flawed.
Then your setup_adc_ports is not going to work. The value given to this
has to be a _constant_, not a string as you are using. 'sAN0', is not a
string, it is a #defined macro, solved at compile time, not something
you can change in the code. If you want to use all the pins as analogs,
you need to set them up as analogs, and then just select the channel to
actually use.
If you want to change values as you show, you would need to declare the
array as an int32 array, not a character array, and have this contain the
values that the sANx defines contain.
However this is not going to work, since the PIC you are using does not
allow you to select just AN1 for example as an analog input. It is one
of the 'older' PIC's, that only allow you to select a range of pins for
analog, not individual pins (read the data sheet.....). So you would just
have to select all pins as analog:
AN0_TO_AN11
